Catch Can on the Caravan (250km)
by StevieC. 01/20/19 01:21 PM
B164 Bypass dissection.
by Purpfox. 01/20/19 12:02 PM
Pics - 2005 Highlander 3.3L 158k miles
by dkryan. 01/20/19 11:21 AM
Chinese nuclear momentum
by OVERKILL. 01/20/19 10:35 AM
Winter finally arrived
by StevieC. 01/20/19 10:27 AM
Octane rating of UL94 avgas
by Altydoc. 01/20/19 09:55 AM
Any bowlers out there?
by 53' Stude. 01/20/19 08:10 AM
Future of subcompact cars?
by Char Baby. 01/20/19 07:15 AM
Are u a roller coaster fan?
by ZZman. 01/20/19 07:03 AM
DUST - a couple of short Sci Fi films
by Shannow. 01/20/19 05:46 AM
5W30 Synthetic Oils With HTHS of 3.5 ?
by ChrisD46. 01/20/19 04:02 AM
White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Rob_from_Madison, SubieSTI, ebersvc, junk1020, fairparts99
66987 Registered Users
106 registered members (77GrandPrix, 4WD, 1.8Tango, 18 invisible), 2,375 guests, and 33 spiders.
Topics296,880
Posts4,960,779
Members66,987
Most Online2,688
Jan 19th, 2019
Sticky door latch 2nd generation Golf #4697998
03/17/18 07:35 PM
03/17/18 07:35 PM
California
vavavroom Offline OP
California
My dad wants to give my son for his birthday a 1987 Golf. At 31 years old, this car is twice the age of my son. The Golf is in good shape with just a few minor problems other than being a Volkswagen. I would get my son a newer and safer vehicle, but his heart is set on grandpa's old car. It's got only 27,000 miles on the engine.It is the four-door GL base model with the 1.8l gas engine. The car went into storage when I left for uni in 1995. The car will need an oil and filter change, new spark plugs, air filter, new drive belt, timing belt and tensioner, water pump and thermostat, and new tires. The blinker bulbs in the front bumper are burned out. To replace them the grille, headlights and finally, thanks to German engineering, the bumper has to come out. My son will be able to do most of the work himself. The outside driver side door handle does not operate smoothly but feels very notchy with a lot of resistance when you pull the outside handle. Does anybody here know if this indicates a problem with the door latch cable linkage or is there another common cause?
Re: Sticky door latch 2nd generation Golf [Re: vavavroom] #4698016
03/17/18 07:52 PM
03/17/18 07:52 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
IIRC these don't use a cable for the outside handle. The mechanism is probably corroded, remove the trim on the outside of the handle and remove the screw in the front and the rear one from the side panel just above he latch.
Remove the handle and clean/lube the mechanism, reinstall. 20 min job.
Re: Sticky door latch 2nd generation Golf [Re: vavavroom] #4698021
03/17/18 07:58 PM
03/17/18 07:58 PM
Phoenix
dishdude Online content
dishdude  Online Content
Phoenix
If these are the fixed handles with the little lever inside that releases the door, they always break. Pull the panel off and take a look.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI
Re: Sticky door latch 2nd generation Golf [Re: vavavroom] #4698071
03/17/18 08:38 PM
03/17/18 08:38 PM
California
California
Yes, this is the fixed type handle with a trigger. It makes sense that there is no Bowden cable. I don't think it could get that sticky. Thanks for the information. It's going to be a month or so before I can report any findings.
