4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
Is this a battery issue or starter issue or ?
by simple_gifts. 03/18/19 06:24 PM
f250 - Friction modifier needed... which brand
by NattyBoh. 03/18/19 05:35 PM
Michelin's New All-Weather Tire for HD Pickups
by SubLGT. 03/18/19 04:36 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
78 registered members (ad_infinitum, 4WD, 2010Civic, Agnosto, AdditiveOCD, 5 invisible), 1,420 guests, and 66 spiders.
Topics286,042
Posts4,901,388
Members67,551
Most Online2,967
Mar 10th, 2019
Who has a GOOD particle counter? #4697937
03/17/18 07:41 PM
03/17/18 07:41 PM
Waco, TX
Linctex Offline OP
Linctex  Offline OP
Waco, TX
(not the "interpolated" results Balckstone gives out)?
Re: Who has a GOOD particle counter? [Re: Linctex] #4697966
03/17/18 08:03 PM
03/17/18 08:03 PM
Middlesex County CT
simple_gifts Offline
Middlesex County CT
I asked a trusted BITOG'r who no longer posts and he indicated Polaris and Butler Cat labs do laser based particle counts.
I don't know what that actually means; I am just passing it on.
2004 Prius; 110K; ASL
2007 Yaris 86K 0w-40 Castrol
2006 B2300;132K;ALM
Was driving an ox cart; Now on the USS Enterprise
Re: Who has a GOOD particle counter? [Re: Linctex] #4698027
03/17/18 09:02 PM
03/17/18 09:02 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Just in case you havn't seen this
Pore Blockage vs Optical Particle Counts
"I sent them to a place that uses a SpectroLNS Q-200 Particle Counter, optical type. "
Doesnt say where it is, but maybe a PM would elicit that info? (might of course be the place already mentioned). Laser scanning is probably the current version of the technology.
I've been considering buying a consumer level laser scanner for air quality monitoring. Would be great if it did liquids too, but I suppose there's no demand. Might be able to snow the university into getting it, but probably not.
"When you have really opaque oil, the optical testers are your only choice, really. " is probably a mistake, since it doesn't seem to make sense.
Re: Who has a GOOD particle counter? [Re: Ducked] #4698104
03/17/18 10:10 PM
03/17/18 10:10 PM
Waco, TX
Linctex Offline OP
Linctex  Offline OP
Waco, TX
Correct.
Optical counters are worthless with opaque oil
Re: Who has a GOOD particle counter? [Re: Linctex] #4698125
03/17/18 10:25 PM
03/17/18 10:25 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
Correct.
You sure? How do they work? I've only used Malvern particle sizers in my past in pharma QC. The sample was diluted to a proper opacity/translucency to allow light to pass through an acceptable range and then the machine counted the particles. It shot a laser through the sample and then some hocus pocus about where the laser was deflected and whatnot and poof, you had a particle size analysis.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: Who has a GOOD particle counter? [Re: Linctex] #4698168
03/17/18 11:14 PM
03/17/18 11:14 PM
The land of USA-made Subies!
SubieRubyRoo Offline
Ryan from Blackstone said there was something obsolete on the pore blocking machine they used previously, IIRC.
I asked about ISO cleanliness codes, and he did say they could still do those.
Re: Who has a GOOD particle counter? [Re: SubieRubyRoo] #4698507
03/18/18 10:44 AM
03/18/18 10:44 AM
Waco, TX
Linctex Offline OP
Linctex  Offline OP
Waco, TX
Originally Posted By: SubieRubyRoo
Ryan from Blackstone said there was something obsolete on the pore blocking machine they used previously, IIRC. I asked about ISO cleanliness codes, and he did say they could still do those.
All I have read about Blackstone is they do the pore blockage on the 10 micron level only,
then they interpolate the data for the other points.
Re: Who has a GOOD particle counter? [Re: Linctex] #4700635
03/20/18 12:14 PM
03/20/18 12:14 PM
Linc that was older. I just talked with Ryan about two weeks ago and he said there were parts for their machine that were obsolete and they were not buying a new pore blocking machine.
Re: Who has a GOOD particle counter? [Re: simple_gifts] #4704389
03/23/18 04:09 PM
03/23/18 04:09 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
Here are the specifications for one such particle counter:
=%2Fmicroscope%2Fcix100%2Fspecifications]Olympus Particle Counter
"I can't change the direction of the wind, but I can adjust my sails to always reach my destination." Jimmy Dean
Re: Who has a GOOD particle counter? [Re: SubieRubyRoo] #4708026
03/26/18 11:07 PM
03/26/18 11:07 PM
Waco, TX
Linctex Offline OP
Linctex  Offline OP
Waco, TX
Thanks for the update, I'll have to give them a try :-)
