Last summer, I drained the coolant repeatedly till I got clear water out. After that, I filled it up PEAK Global (+ water) upto the MAX line in the coolant reservoir. Just now I noticed, that the coolant level has dropped below MIN. My first guess is the air trapped in the system that was just let out over the period of the year.
I would like to top off this coolant. Should I stick to PEAK Global 50-50 or I can use another coolant?
Thanks
Thanks
