White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
FRAM end cap differences EG and TG vs XG
by wemay. 01/19/19 09:25 PM
Valvoline modern Engine
by Pinoak. 01/19/19 09:02 PM
30 Vintage Photos
by StevieC. 01/19/19 08:23 PM
Low mileage, when to change oil?
by Metfanant. 01/19/19 08:05 PM
Filter with bypass when OEM has built-in bypass
by rubberchicken. 01/19/19 07:43 PM
Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
dougway, Jetsfan421, Fordman420, 72sbc, ejmiller
66982 Registered Users
35 registered members (c502cid, carlprop, Black_Thunder, Blkstanger, BlakeB, bubbatime, 4 invisible), 882 guests, and 30 spiders.
Topics296,866
Posts4,960,375
Members66,982
Most Online2,688
Jan 19th, 2019
Brake related vibration #4697755
03/17/18 03:47 PM
03/17/18 03:47 PM
southern mo
ram_man Offline OP
ram_man  Offline OP
southern mo
Hey everyone. So sometimes at highway speeds on the 14 dart if I hit the brakes Iíll get a front end vibration. Here is the kicker the car will shake in the steering wheel even after letting off the pedal for several seconds. I installed power stop evolution brakes about 2 months ago and new rotors from advanced auto parts. When jacking the car up the wheel spin freely. The pads seems to be moving ok as well. To me it sounds like the pads arenít moving back enough to clear the rotor . Any thoughts?
2014 dodge dart GT
1995 Dodge ram 1500
Re: Brake related vibration [Re: ram_man] #4697766
03/17/18 04:07 PM
03/17/18 04:07 PM
Georgia
AVB Offline
AVB  Offline
Georgia
I would check the steering and suspension components. It sounds like the brakes start a reverberation that continues after you release the brakes.
Re: Brake related vibration [Re: ram_man] #4697784
03/17/18 04:27 PM
03/17/18 04:27 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Didn't you already have a massive thread about this?
2018 RAM 1500 Big Horn EcoDiesel
2016 Grand Cherokee SRT
Re: Brake related vibration [Re: ram_man] #4697922
03/17/18 06:27 PM
03/17/18 06:27 PM
San Antonio, TX
jorton Offline
jorton  Offline
San Antonio, TX
When I did my jeep Patriot I wire brushed friction points on brackets and calipers, and lubed same points with disc brake grease. Cleaned and lubed caliper pins too. And I cleaned the new rotors with spray and blue towels. I used Wagner rotors and pads. Vehicle brakes like new.
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
Re: Brake related vibration [Re: OVERKILL] #4698057
03/17/18 08:28 PM
03/17/18 08:28 PM
southern mo
ram_man Offline OP
ram_man  Offline OP
southern mo
No? I donít think I did. Iíve had tire vibrations and warped rotors but these symptoms are different than that. When I did the pads I installed new hardware and new brake lube on contact points.
2014 dodge dart GT
1995 Dodge ram 1500
Re: Brake related vibration [Re: ram_man] #4698062
03/17/18 08:31 PM
03/17/18 08:31 PM
St. Louis
MONKEYMAN Offline
MONKEYMAN  Offline
St. Louis
Did you index the rotors and check for run-out? I had to finally install a shim on passenger side of my Saturn to keep from getting pulsation after a brake job. I attribute that to a little rust or hitting curbs when parking.
Truth alone triumphs, not untruth.
2017 Elantra SE
Re: Brake related vibration [Re: MONKEYMAN] #4698082
03/17/18 08:47 PM
03/17/18 08:47 PM
southern mo
ram_man Offline OP
ram_man  Offline OP
southern mo
I did not but that was going to be the first thing I check tomorrow morning was run out. After then Iím just going to reverify that everything is moving smoothly and then after that Iím not sure.
2014 dodge dart GT
1995 Dodge ram 1500
Re: Brake related vibration [Re: ram_man] #4698092
03/17/18 08:59 PM
03/17/18 08:59 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
It sounds like a continuation of the same symptoms, no? IE, you still have a vibration of some sort, seemingly initiated when you brake (like your warped rotor thread) but now with the vibration continuing after you let off the brakes. Ergo, it sounds like an extension of that previous thread to me shrug
Re: Brake related vibration [Re: ram_man] #4698096
03/17/18 09:04 PM
03/17/18 09:04 PM
southern mo
ram_man Offline OP
ram_man  Offline OP
southern mo
You would have to drive it to understand I guess. I had a tire vibration thatís been fixed and Iíve had a bad set of pads cause a vibration........ but the vibrations were in the tires case at speed rin the brakes case when braking. This issue will shake when braking and then continue when I let off the brakes for several seconds . Itís almost like the brake pads run the rotors for a bit until they retract far enough back to clear. Tonight I did a couple semi aggressive slow downs and then it hasnít done it since. So I think checking run out is the best idea so far. Very weird.....
2014 dodge dart GT
1995 Dodge ram 1500
Re: Brake related vibration [Re: ram_man] #4698109
03/17/18 09:14 PM
03/17/18 09:14 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
You have to appreciate that one individual having three separate threads about three apparently separate vibration issues on the same vehicle is exceptionally coincidental.
Checking run-out sounds like a good place to start.
Re: Brake related vibration [Re: OVERKILL] #4698165
03/17/18 10:07 PM
03/17/18 10:07 PM
southern mo
ram_man Offline OP
ram_man  Offline OP
southern mo
Iíll agree with that. What Iíve learned about these darts is theyíre incredibly particular and mine has the sport suspension and 18in wheels so itís even more so . It something isnít 100% it lets you know. But Iíd say the tire issue immediately went away when the road force numbers got low. The brake pad issue stopped with new pads . BUT Iíd be willing to accept the idea that the previous brake pad issue and this are related. But I do believe without a doubt the tire issue was a separate issue.
2014 dodge dart GT
1995 Dodge ram 1500
Re: Brake related vibration [Re: ram_man] #4698184
03/17/18 10:38 PM
03/17/18 10:38 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Sounds fair.
What rotors are on it presently?
Re: Brake related vibration [Re: OVERKILL] #4698201
03/17/18 11:15 PM
03/17/18 11:15 PM
southern mo
ram_man Offline OP
ram_man  Offline OP
southern mo
Sounds fair.
Car quest wearever from advance auto parts.
2014 dodge dart GT
1995 Dodge ram 1500
Re: Brake related vibration [Re: ram_man] #4698495
03/18/18 09:36 AM
03/18/18 09:36 AM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Sounds fair.
Ahh, OK, so some cheapies. Keep us updated on the runout test, interested to see what it shows.
Re: Brake related vibration [Re: OVERKILL] #4698550
03/18/18 10:31 AM
03/18/18 10:31 AM
southern mo
ram_man Offline OP
ram_man  Offline OP
southern mo
Sounds fair.
Seems like anything at the part stores is cheap stuff these days.
2014 dodge dart GT
1995 Dodge ram 1500
