Tundra vibration
by pda1122
04/22/18 08:39 PM
Who says Corvettes are gas guzzlers?
by Patman
04/22/18 08:26 PM
Mobile rebate question
by Snowball
04/22/18 08:25 PM
Oil shear and 0w,5w,10w?
by Camprunner
04/22/18 05:42 PM
Looks like the Jeep needs axle bearings
by Nick1994
04/22/18 05:13 PM
Toyota OEM Cartridge Filter, Cut Open 12,669 Miles
by Nick1994
04/22/18 04:53 PM
S/C Range Rover, 5000kms 33 different oils UOA
by Vladiator
04/22/18 04:24 PM
Buying oil on price - Pricing Rant
by JHZR2
04/22/18 04:22 PM
Mix of 33 oils VOA
by Vladiator
04/22/18 04:19 PM
Sugar Binge Hangover ... :~/
by LoneRanger
04/22/18 04:18 PM
MagnaFlow 49253 Exhaust Header
by Ambition5253
04/22/18 04:14 PM
Difference between NGK BR6ES and BPR6ES ?!?
by webfors
04/22/18 04:08 PM
Griot's Garage Glass Polish leaving dried flakes
by mclasser
04/22/18 03:56 PM
Pennzoil Platinum 10W30
by turnbowm
04/22/18 03:55 PM
Adhesive for clay pot repair?
by callbay
04/22/18 03:40 PM
G35 rough start
by bowlofturtle
04/22/18 03:37 PM
Parts Master 67045 5K OCI Cut Open
by Ifixjetz1
04/22/18 03:03 PM
Best Subcompact Cars in the US & Global
by NewEnglander
04/22/18 02:41 PM
Super Tech Clearance purchase
by mctmatt
04/22/18 01:58 PM
Website Loading Issue
by sleddriver
04/22/18 01:51 PM
daylateetc, Kjammer, sonnyk, PWMDMD, usernameunknown
64820 Registered Users
108 registered (2007BMW335i, 2015_PSD, amcguru, 123Saab, andyd, 14 invisible), 1732 Guests and 47 Spiders online.
64820 Members
68 Forums
282151 Topics
#4697686 - 03/17/18 03:21 PM Topping up Peak Global
MoneyJohn Offline
Loc: Southern NY
Last summer, I drained the coolant repeatedly till I got clear water out. After that, I filled it up PEAK Global (+ water) upto the MAX line in the coolant reservoir. Just now I noticed, that the coolant level has dropped below MIN. My first guess is the air trapped in the system that was just let out over the period of the year.
I would like to top off this coolant. Should I stick to PEAK Global 50-50 or I can use another coolant?
Thanks
2015 Subaru Forester 2.5i Premium w/ EyeSight
2006 Nissan Sentra 1.8S Special Edition
#4697693 - 03/17/18 03:32 PM Re: Topping up Peak Global [Re: MoneyJohn]
Chewie Online   content
Loc: OH
Peak Global should be cheap and easy enough to obtain for you to use the same. Is there a particular reason you would want to add another coolant? Theoretically you should be able to add another all-makes all-models coolant, but I'd prefer to stick with the same.
2002 Lexus GS300 | 2JZ-GE | M1 HM 10W-40 | XG3600
#4697706 - 03/17/18 03:55 PM Re: Topping up Peak Global [Re: MoneyJohn]
Snagglefoot Online   content
Loc: Alberta
I suppose that could be true but take a close look below your water pump to make sure it’s not leaking.
#4697727 - 03/17/18 04:20 PM Re: Topping up Peak Global [Re: Chewie]
MoneyJohn Offline
Loc: Southern NY
Nobody in my neighborhood is carrying it, nor do I find it online. Available with NAPA and Walgreens only. NAPA stores in my neighborhood don't have it, nor is Walgreens and I do not want to go 15miles out of my way to get it. Hence the question. I am going to ask local Walgreens guy if he will get for me but speaking from past experience, they are no better than Walmart employees so won't keep my hopes high.
@SnaggleFoot, I took a quick look and didn't notice anything but I definitely will keep an eye once I top it up.
#4697756 - 03/17/18 04:49 PM Re: Topping up Peak Global [Re: MoneyJohn]
andrewp1998 Offline
Loc: MA USA
Peak on amazon>>>>>
https://www.amazon.com/Antifreeze-Coolan...ifetime+coolant
Could be the radiator cap , get an oem , cheap enough to replace.
Edited by andrewp1998 (03/17/18 04:54 PM)
2001 Honda civic HX vtecE- 5 spd,227k+
#4697806 - 03/17/18 06:01 PM Re: Topping up Peak Global [Re: MoneyJohn]
Warstud Online   content
Loc: MIchigan
What vehicle is this going in ?
#4697848 - 03/17/18 06:35 PM Re: Topping up Peak Global [Re: andrewp1998]
MoneyJohn Offline
Loc: Southern NY
Originally Posted By: andrewp1998
Peak on amazon>>>>>
Trust me, I searched on amazon with exact same terms and it didn't show up.
BTW, stopped by other Walgreens in my neighborhood and found it. Believe it or not, for $13.99 only. Topped up and now wait begins to see if there is any leak or something. Checked the radiator cap, it looks good.
#4697946 - 03/17/18 07:49 PM Re: Topping up Peak Global [Re: MoneyJohn]
Loc: MIchigan
It scares me that Peak G.L. is AMAL.
#4698283 - 03/18/18 06:08 AM Re: Topping up Peak Global [Re: Warstud]
Sayjac Offline
Loc: The Old North State
Guess you mean AMAM. In my observation PGL a favorite on bitog for several reasons that have been covered many times. Basically a LL (long service interval) OAT AF with no 2eha. The latter of which is found in DexCool and the "Dexclone universals" like Prestone that used to say All Makes All Models on the jug.
PGL having the benefits of LL OAT AF but no 2eha make it unique. 2eha a known plasticizer that may not be compatible with some engine gasket types, o-rings. The Asian AF's and even the new Mopar OAT AF avoid it's use in their products. So IMO and IME (for Toyota red), even though PGL can be considered to be a "universal AF" product, no rational reason to fear it's use.
As for topic, based on what I read I don't see anything to indicate an issue with PGL. Guess the OP needs to decide if PGL worth the hunt. If not, go to vehicle spec AF, which if signature vehicles indicate would be an Asian PHOAT (available as premix most likely).
#4709719 - 03/28/18 02:52 PM Re: Topping up Peak Global [Re: MoneyJohn]
BJD78 Offline
Loc: Nebraska
I use LL peak global in my Forester, I cannot see paying 3X as much for the same thing at the Subaru Stealer ship. I run PG it in all 3 of or vehicles since it is easy to find around here in Lincoln Ne.In the event I need it and cannot find it Zerox makes a global type LL antifreeze as well. Both are good and will go for 5 years easily.
2010 Forester:122K
2009 Sonata :189K
2010 Tucson:55K
OCI 5K to 7K using the cheapest dino oil I can buy,usually NAPA or TSC Travelers oil.
#4714714 - 04/03/18 02:14 AM Re: Topping up Peak Global [Re: MoneyJohn]
sierraskibum Offline
Loc: Reno NV
Order it from Amazon for $30.00 including shipping. Excellent choice of antifreeze but hard to find. Some Napa stores have it, but I have had to ask them to look for it in the back. They had it recently at the central warehouse here in 50 / 50 formula, but I wanted concentrate. They could probably order it as it is sold in Napa stores.
