Remote Start by Android Auto App ?
by LoneRanger. 04/19/19 04:53 PM
Continental PureContact LS
by The Critic. 04/19/19 03:31 PM
Dark/Black Rear Differential Oil - UOA?
by The Critic. 04/19/19 03:25 PM
Best oil for Honda Rancher?
by jayjr1105. 04/19/19 03:20 PM
Store bought kimchi?
by Quattro Pete. 04/19/19 03:15 PM
2020 KIA Soul Turbo
by Malo83. 04/19/19 03:03 PM
erratic Speedometer
by tookien. 04/19/19 02:59 PM
Another airbag recall
by mclasser. 04/19/19 02:44 PM
Which barb fitting is less likely to leak?
by zorobabel. 04/19/19 02:36 PM
Can these bucket style tappets be reused?
by atikovi. 04/19/19 01:34 PM
Scratched My New Car. Help Me Fix
by GeorgeKaplan. 04/19/19 01:23 PM
Talk about manual labor...
by AZjeff. 04/19/19 12:42 PM
Car didn't burn an ounce of oil... 7K OCI
by jayjr1105. 04/19/19 12:13 PM
Top 6 OEM Passenger Tire Sizes in 2018
by SubLGT. 04/19/19 11:12 AM
CRC intake valve cleaner, safe to use?
by Backstache. 04/19/19 10:06 AM
'94 Grand Am Steering Column Pivot Pins
by benjamming. 04/19/19 10:02 AM
Why the need to replace suspension springs?
by WyrTwister. 04/19/19 09:47 AM
incorrect mileage on reciept
by 1978elcamino. 04/19/19 09:17 AM
Oregon PowerSharp for chainsaw
by Fitter30. 04/19/19 09:16 AM
new tire 4 years old
by 1978elcamino. 04/19/19 08:51 AM
carve200, Harteeco, fatafox, CurtC, LockCracker
67850 Registered Users
110 registered members (2015_PSD, Anduril, ABCarr, AandPDan, Al, 2004tdigls, 12 invisible), 2,199 guests, and 28 spiders.
Topics287,749
Posts4,933,778
Members67,850
Most Online2,967
Mar 10th, 2019
How to do a piston soak correctly? #4697538
03/17/18 11:56 AM
03/17/18 11:56 AM
USA
marantz_fan Offline OP
USA
2001 Corolla. Have had it for about a year, but it was consuming oil at a ferocious rate: first 1 quart/400 miles, finally all four quarts/200 miles. Now, a dead cylinder #4, and the likely death of the car. Never had the resources to to do an engine rebuild, unfortunately.
In the hope that cylinder 4's problem is simply a stuck ring and not structural damage, I'm going to attempt a piston soak.
How much solvent to use? Enough so that the fluid goes over the top of the piston head? Will turning the ignition be enough to extract all the solvent after the soak, or do I have to find some kind of syringe to get the rest out? Leave the spark plugs loosely in the cylinder during the soak (and then remove them during extraction)?
Re: How to do a piston soak correctly? [Re: marantz_fan] #4697544
03/17/18 12:04 PM
03/17/18 12:04 PM
Colorado Springs
Drew99GT Offline
Drew99GT  Offline
Colorado Springs
Done many soaks on Corollas; fill the cylinders as much as possible. Turn the engine over with a ratchet every few hours, and YES, use a syringe with a long piece of aquarium tubing to suck out remaining fluid. Leave the plugs out.
I would use B12 Chemtool; it's the only product that made a noticeable difference in my Corolla.
After the product has been sucked out of each cylinder, I would fill the syringe with a small mount of oil, stick the hose back in each cylinder and squirt the cylinder walls. That will help build compression when you try and start the engine back up.
Re: How to do a piston soak correctly? [Re: marantz_fan] #4697563
03/17/18 12:29 PM
03/17/18 12:29 PM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
I would change the plugs afterwards.
The "thinking" man's friend.
Re: How to do a piston soak correctly? [Re: Lubener] #4697569
03/17/18 12:36 PM
03/17/18 12:36 PM
NY
demarpaint Offline
demarpaint  Offline
NY
And the oil. If possible do it when a spark plug change and oil change are due, and kill three birds with one stone.
God Bless Our Troops
Re: How to do a piston soak correctly? [Re: Lubener] #4697573
03/17/18 12:37 PM
03/17/18 12:37 PM
USA
USA
I tried the induction method as per some Youtube videos for some other (non-Corolla) cars, but the engine instantly stalls when any of the vacuum lines are removed.
Re: How to do a piston soak correctly? [Re: Drew99GT] #4697575
03/17/18 12:40 PM
03/17/18 12:40 PM
USA
USA
Thanks, will try that. Somebody over on a Saturn forum has an old piston soaking thread, but he says to use stuffed rags in the cylinders, and for some reason he says to keep them stuffed even when turning the engine. But I can't figure out why; wouldn't that prevent the solvent from escaping the cylinder?
Re: How to do a piston soak correctly? [Re: demarpaint] #4697583
03/17/18 12:48 PM
03/17/18 12:48 PM
USA
USA
My problem might be too bad for that. The cylinder died when I tried to make it up a steep hill, which pretty much shut the engine off at the time -- but I had just filled the crankcase with 4 quarts the night before and there was oil in the engine. I managed to get the engine going just long enough to get it to a parts store, and installed new plugs right in their parking lot, but it made no difference and there looks to be oil and perhaps even coolant on the threads of the new plugs. The constant oil burning for the past year has caused repeated misfires and maybe damaged the cat (hopefully not). I can top more oil in the crankcase, but it would basically be just new oil that would be drained if an oil change was done. Check engine light is now flashing while driving and the engine is gasping and trying to stall. I'm half-worried that there might now be fuel in the cylinders and could cause an engine fire, but maybe I'm just being paranoid (or that I just don't know much about cars.)
After the soak, should I try to use some plug spacers to prevent fouling?
Re: How to do a piston soak correctly? [Re: marantz_fan] #4697604
03/17/18 01:13 PM
03/17/18 01:13 PM
Western Ma.
rollinpete Offline
rollinpete  Offline
Western Ma.
Sorry to say but 4 quarts 200 miles, I doubt a piston soak will help.
I would think there's some bigger issues there.
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive187k miles
03 Saturn Ion 2.2 L4 5spddrive238K miles
PP, PPHM 50/50 5w30 and Fram Ultra x 2
Currently under the influence of oil shocked2
Re: How to do a piston soak correctly? [Re: marantz_fan] #4697605
03/17/18 01:14 PM
03/17/18 01:14 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Re: How to do a piston soak correctly? [Re: marantz_fan] #4697609
03/17/18 01:18 PM
03/17/18 01:18 PM
Central Virginia
Silverado12 Offline
Silverado12  Offline
Central Virginia
Yeah, that engine is done. I wouldn't waste money on chemicals; it has a broken ring and/or scored cylinder(s).
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: How to do a piston soak correctly? [Re: marantz_fan] #4697610
03/17/18 01:20 PM
03/17/18 01:20 PM
USA
mk378 Offline
mk378  Offline
USA
Or a burnt valve.
Anyway forget soaking, look at replacement.
Re: How to do a piston soak correctly? [Re: marantz_fan] #4697624
03/17/18 01:39 PM
03/17/18 01:39 PM
Watertown, New York
cronk Offline
cronk  Offline
Watertown, New York
If there is oil and coolant on the plugs, you likely have a blown head gasket.
No amount of chemical soaking is going to fix that.
2008 Ford F350
2003 Chevy Cavalier
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
Re: How to do a piston soak correctly? [Re: marantz_fan] #4698099
03/17/18 10:05 PM
03/17/18 10:05 PM
New England
gathermewool Offline
New England
What are the DTC's for the flashing CEL? Is it only for cylinder 4 misfire?
Compression? Leakdown?
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter (64,774 miles)
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Edge 0W-20 + FU filter (40,803 miles)
Re: How to do a piston soak correctly? [Re: gathermewool] #4698139
03/17/18 10:37 PM
03/17/18 10:37 PM
USA
USA
My local shop said the compression for the other three cylinders were more or less ok, but that #4 was 50. They didn't tell me what the latest scan revealed, but for most of the past year a constant check engine light was for various misfires on some or all of the cylinders.
Re: How to do a piston soak correctly? [Re: marantz_fan] #4698481
03/18/18 10:25 AM
03/18/18 10:25 AM
Colorado Springs
Drew99GT Offline
Drew99GT  Offline
Colorado Springs
Have them do a leakdown test and see where the cylinder is leaking from. Has it been consuming antifreeze recently?
