2018 Ford 2.0 EcoBoost
by mpgo4th - 02/28/20 03:30 PM
RMD-- Is this the time to take it?
by csandste - 02/28/20 03:29 PM
Timken Rear Wheel Bearing - Any Good?
by Delta - 02/28/20 02:47 PM
121k 2011 GMC Terrain 2.4 ~ PP 6250 miles
by Matt1980 - 02/28/20 02:42 PM
Mopar coolant alternative?
by ram_man - 02/28/20 02:38 PM
Old (but new) filters
by RF12 - 02/28/20 01:54 PM
5.3 DOD/AFM Delete - Looking for LS Advice
by RoadDukie - 02/28/20 01:47 PM
Help picking battery powered mower
by Huie83 - 02/28/20 01:41 PM
Can I use 75w instead 70w gear oil?
by Polyalphaolefin - 02/28/20 11:57 AM
Alternative to Unaffordable New SUV?
by Fitz98 - 02/28/20 11:24 AM
What is this??
by DriveHard - 02/28/20 09:45 AM
Ultimax 18" Build
by DriveHard - 02/28/20 09:42 AM
spray paint the wheel bead
by CNT - 02/28/20 09:40 AM
'What car should we get...'
by wings&wheels - 02/28/20 09:30 AM
Free entertainment at the gas station.
by Chris142 - 02/28/20 09:17 AM
Using Redline SL-1 as a Maintenance Dose
by Boomer - 02/28/20 09:08 AM
ABchevy, RAOD, MichaelTx, duesenberg, Shevretti
70825 Registered Users
98 registered members (1978elcamino, 762fermeandyou, AlienBug, AC1DD, 55hambone, Aichiguy, 7 invisible), 2,122 guests, and 17 spiders.
Topics302,049
Posts5,208,058
Members70,825
Page 1 of 3 1 2 3
Wood boards as a backup for Rhino ramps—how high? #4697437 03/17/18 09:01 AM
paulri Online Content OP
OP Online Content
I have a pair of 16,000 lb Rhino ramps I drive my cars up when I change the oil. Because of stories of ramps and jacks failing, I like to use a stack of boards that I have in my garage, as a backup plan. I put them in between the two tires on each side.
My question is—is there a given height that my stack of boards should go? Do I simply have to put my stacks high enough to allow me to have room, below the level of the boards, if the chassis falls? Or could the innards at the bottom of the car, drop lower than the frame itself, that is resting on the boards—in which case, I’d need to give myself a few extra inches of leeway here.
2005 Toyota Sienna LE; 163,000 miles
2006 Toyota Highlander Hybrid 118,000 miles
Re: Wood boards as a backup for Rhino ramps—how high? [Re: paulri] #4697459 03/17/18 09:27 AM
M
MRtv Offline
M
How high do you want? Each board is about 1.5 inches thick. So for whatever hight you need you can calculate from there. I put in four layers. It got my Versa up 6 inches. Perfect for my oil change on the Versa. Need higher? Add layers but know that wood can be heavy so you are adding weight as you add on height.
2014 Nissan Versa Note 1.6 liter engine. 1997 Ford F150 4x4 4.6 liter engine.
Re: Wood boards as a backup for Rhino ramps—how high? [Re: paulri] #4697460 03/17/18 09:27 AM
Snagglefoot Offline
I’d recommend the full height to the chassis and tight against the chassis. May I recommend to pick up a set of jack stands on sale. They are are much easier to work with. (But rememeber to pull them out at the end of the job. )
If you want the job done right......do it yourself.
Re: Wood boards as a backup for Rhino ramps—how high? [Re: Snagglefoot] #4697465 03/17/18 09:34 AM
OP Online Content
https://www.walmart.com/ip/Torin-Jacks-3-Ton-Jack-Stand-Pair/14560047
Regular price is over 100 bucks. Is this a reputable company? WM has them for $24. 3 ton capacity would cover the Sienna as well.
Alternately, PB has this set: https://www.pepboys.com/product/details/1154551/00773?quantity=1
Harbor Freight: https://www.harborfreight.com/3-Ton-Steel-Jack-Stands-61196.html
Not sure which companies can be trusted here. Rather not use chinesium as my backup plan.
Re: Wood boards as a backup for Rhino ramps—how high? [Re: paulri] #4697470 03/17/18 09:39 AM
A
AVB Offline
A
$100 is [censored] wishful thinking, marketing. Those are around $25 anywhere you go.
Re: Wood boards as a backup for Rhino ramps—how high? [Re: paulri] #4697471 03/17/18 09:39 AM
L
Linctex Offline
L
Because of stories of ramps and jacks failing, I like to PLACE REAL JACKSTANDS under the car to support it, if needed.
There, I fixed that for you.
Re: Wood boards as a backup for Rhino ramps—how high? [Re: paulri] #4697473 03/17/18 09:42 AM
L
Linctex Offline
L
I'll vouch for these (That all pretty much come from china, no matter who sells them)
The ratings are utterly ridiculous - 3 tons (6,000 lbs) is wishful thinking at best.
Used properly in general auto use, they are just fine.
I like to place a 12" x 12" square of 3/4" plywood under each one
when used on any surface other than concrete.
Re: Wood boards as a backup for Rhino ramps—how high? [Re: paulri] #4697476 03/17/18 09:44 AM
L
Linctex Offline
L
My grandfather built something similar to these about 50 years ago.
They are nearly indestructible & will hold a semi-truck!
Re: Wood boards as a backup for Rhino ramps—how high? [Re: paulri] #4697478 03/17/18 09:47 AM
A
AVB Offline
A
If you are worried about the ramps failing make some of the pine-o ramps. That is what we used when servicing semi's.
Re: Wood boards as a backup for Rhino ramps—how high? [Re: Linctex] #4697482 03/17/18 09:54 AM
4WD Offline
I see why he has wheels … mine are heavy enough that I put a gate handle on the end
Re: Wood boards as a backup for Rhino ramps—how high? [Re: paulri] #4697499 03/17/18 10:09 AM
K
Kansas_Ron Offline
K
Purchase 2, 2"x 10" x 12' boards. One board will make a ramp. Lowes will cut to lengths shown. Get some nails, or screws and adhesive. Cheap. simple, and heavy. I have used them for 8 years.
2000 Chevy Prizm
2015 Honda Civic
2017 Hyundai Elantra
Re: Wood boards as a backup for Rhino ramps—how high? [Re: Kansas_Ron] #4697507 03/17/18 10:17 AM
4WD Offline
One nice thing about these is they will not slide away when bringing a RWD vehicle up on them … the first 1-1/2” rise pins them down tight
Pine-O Ramps have their place …
Re: Wood boards as a backup for Rhino ramps—how high? [Re: paulri] #4697515 03/17/18 10:26 AM
L
Leo99 Online Content
Online Content
L
I use the harbor freight jack stands when I need to use jack stands.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 392,000 miles
2015 Camry 90,000 miles
Re: Wood boards as a backup for Rhino ramps—how high? [Re: paulri] #4697520 03/17/18 10:31 AM
OP Online Content
If wood is capable of holding up the car as the primary support, it should also be ok as a backup support, shouldn't it?
If possible, I'd like to get more input on my original question--assuming I'll continue using wood boards, how high do the boards have to get? Snagglefoot said take the boards up to the height of the chassis. Is that what is best or what everyone does, who uses boards?
Re: Wood boards as a backup for Rhino ramps—how high? [Re: paulri] #4697522 03/17/18 10:37 AM
K
Kestas Offline
Global Moderator
Global Moderator
K
My ramps are a stack of 2 x 12s. For safety I throw a short log or two under the car and chock a wheel. It's not worth taking short cuts when it comes to safety.
Page 1 of 3 1 2 3
