103 registered members (2002 Maxima SE, Anton_N, 2015_PSD, 2012AccentSE, AlaskaMike, Alfred_B, 10 invisible),
1,971
guests, and 54
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,481
Posts5,136,335
Members70,072
Most Online3,589 Nov 2nd, 2019
Wood boards as a backup for Rhino ramps—how high?
#4697437
03/17/18 09:01 AM
paulri
OP
OP
Posts: 1,330 |
I have a pair of 16,000 lb Rhino ramps I drive my cars up when I change the oil. Because of stories of ramps and jacks failing, I like to use a stack of boards that I have in my garage, as a backup plan. I put them in between the two tires on each side.
My question is—is there a given height that my stack of boards should go? Do I simply have to put my stacks high enough to allow me to have room, below the level of the boards, if the chassis falls? Or could the innards at the bottom of the car, drop lower than the frame itself, that is resting on the boards—in which case, I’d need to give myself a few extra inches of leeway here.
2005 Toyota Sienna LE; 163,000 miles 2006 Toyota Highlander Hybrid 118,000 miles
Re: Wood boards as a backup for Rhino ramps—how high?
[Re: paulri]
#4697459
03/17/18 09:27 AM
MRtv
Posts: 340 |
How high do you want? Each board is about 1.5 inches thick. So for whatever hight you need you can calculate from there. I put in four layers. It got my Versa up 6 inches. Perfect for my oil change on the Versa. Need higher? Add layers but know that wood can be heavy so you are adding weight as you add on height.
2014 Nissan Versa Note 1.6 liter engine. 1997 Ford F150 4x4 4.6 liter engine.
[Re: paulri]
#4697460
03/17/18 09:27 AM
Snagglefoot
Posts: 5,285 |
I’d recommend the full height to the chassis and tight against the chassis. May I recommend to pick up a set of jack stands on sale. They are are much easier to work with. (But rememeber to pull them out at the end of the job. )
If you want the job done right......do it yourself.
[Re: paulri]
#4697470
03/17/18 09:39 AM
AVB
Posts: 1,457 |
$100 is [censored] wishful thinking, marketing. Those are around $25 anywhere you go.
[Re: paulri]
#4697471
03/17/18 09:39 AM
Linctex
Posts: 9,661 |
Because of stories of ramps and jacks failing, I like to PLACE REAL JACKSTANDS under the car to support it, if needed. There, I fixed that for you.
"The evidence demands a verdict". (Re:VOA)"it's nearly impossible to actually know the particular additives that are in there at what concentrations."
[Re: paulri]
#4697473
03/17/18 09:42 AM
Linctex
Posts: 9,661 |
I'll vouch for these (That all pretty much come from china, no matter who sells them) The ratings are utterly ridiculous - 3 tons (6,000 lbs) is wishful thinking at best. Used properly in general auto use, they are just fine. I like to place a 12" x 12" square of 3/4" plywood under each one when used on any surface other than concrete.
[Re: paulri]
#4697476
03/17/18 09:44 AM
Linctex
Posts: 9,661 |
My grandfather built something similar to these about 50 years ago. They are nearly indestructible & will hold a semi-truck!
[Re: paulri]
#4697478
03/17/18 09:47 AM
AVB
Posts: 1,457 |
If you are worried about the ramps failing make some of the pine-o ramps. That is what we used when servicing semi's.
[Re: Linctex]
#4697482
03/17/18 09:54 AM
4WD
Posts: 10,897 |
I see why he has wheels … mine are heavy enough that I put a gate handle on the end
[Re: paulri]
#4697499
03/17/18 10:09 AM
Kansas_Ron
Posts: 51 |
 Purchase 2, 2"x 10" x 12' boards. One board will make a ramp. Lowes will cut to lengths shown. Get some nails, or screws and adhesive. Cheap. simple, and heavy. I have used them for 8 years.
2000 Chevy Prizm 2015 Honda Civic 2017 Hyundai Elantra
[Re: Kansas_Ron]
#4697507
03/17/18 10:17 AM
4WD
Posts: 10,897 |
 Purchase 2, 2"x 10" x 12' boards. One board will make a ramp. Lowes will cut to lengths shown. Get some nails, or screws and adhesive. Cheap. simple, and heavy. I have used them for 8 years. One nice thing about these is they will not slide away when bringing a RWD vehicle up on them … the first 1-1/2” rise pins them down tight Pine-O Ramps have their place …
[Re: paulri]
#4697515
03/17/18 10:26 AM
Leo99
Posts: 4,254 |
I use the harbor freight jack stands when I need to use jack stands.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP) 2004 Corolla 125,000 miles 2004 Rav4 392,000 miles 2015 Camry 90,000 miles
[Re: paulri]
#4697520
03/17/18 10:31 AM
paulri
OP
OP
Posts: 1,330 |
If wood is capable of holding up the car as the primary support, it should also be ok as a backup support, shouldn't it?
If possible, I'd like to get more input on my original question--assuming I'll continue using wood boards, how high do the boards have to get? Snagglefoot said take the boards up to the height of the chassis. Is that what is best or what everyone does, who uses boards?
[Re: paulri]
#4697522
03/17/18 10:37 AM
Kestas
Global Moderator
Global Moderator
Posts: 13,406 |
My ramps are a stack of 2 x 12s. For safety I throw a short log or two under the car and chock a wheel. It's not worth taking short cuts when it comes to safety.
