Good petroleum free tire dressing ?
by JDMiller. 07/21/19 07:52 PM
2008 Infiniti G37 P0011 and P0524
by The Critic. 07/21/19 07:23 PM
Zamboni
by Snagglefoot. 07/21/19 07:18 PM
air filter for rav4 hybrid
by NH73. 07/21/19 07:16 PM
MB C250 driver seat bottom cover replacement
by The Critic. 07/21/19 06:56 PM
Centric PQ Pro Brake Pads
by The Critic. 07/21/19 06:43 PM
Latency on fiber connectivity to Internet
by Donald. 07/21/19 05:41 PM
102K on Plugs - '13 Chevy Cruze LS
by 99Saturn. 07/21/19 03:38 PM
Shop light LED conversion bone head move.
by JTK. 07/21/19 02:27 PM
The Hunt Begins...
by MCompact. 07/21/19 02:10 PM
Cambodia Forest, River and Beach.
by Voleak. 07/21/19 02:01 PM
Foxwoods Resorts Casino 301 at NHMS
by bdcardinal. 07/21/19 01:29 PM
2017 Ram 1500 rear brake lines
by LAGA. 07/21/19 01:27 PM
yacco oils, better than motul (xcess)?
by pep808. 07/21/19 01:22 PM
Scotty K. has finally let me down
by Lolvoguy. 07/21/19 01:03 PM
Exxon/Mobil Synergy Supreme +
by incognito_2u. 07/21/19 12:51 PM
Son going to bring another vehicle home
by vavavroom. 07/21/19 12:43 PM
TV shows you enjoy
by 53' Stude. 07/21/19 12:14 PM
Kcpaz, Albush1, mwc951, bobdz, andrewv
68727 Registered Users
99 registered members (3311, 4WD, 08z06, 2015_PSD, 007, 8 invisible), 1,687 guests, and 21 spiders.
Topics292,206
Posts5,018,905
Members68,727
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Wood boards as a backup for Rhino ramps—how high? #4697437
03/17/18 10:01 AM
03/17/18 10:01 AM
CA, USA
paulri Online content OP
paulri  Online Content OP
CA, USA
I have a pair of 16,000 lb Rhino ramps I drive my cars up when I change the oil. Because of stories of ramps and jacks failing, I like to use a stack of boards that I have in my garage, as a backup plan. I put them in between the two tires on each side.
My question is—is there a given height that my stack of boards should go? Do I simply have to put my stacks high enough to allow me to have room, below the level of the boards, if the chassis falls? Or could the innards at the bottom of the car, drop lower than the frame itself, that is resting on the boards—in which case, I’d need to give myself a few extra inches of leeway here.
2005 Toyota Sienna LE; 163,000 miles
2006 Toyota Highlander Hybrid 118,000 miles
Re: Wood boards as a backup for Rhino ramps—how high? [Re: paulri] #4697459
03/17/18 10:27 AM
03/17/18 10:27 AM
Boise, Idaho
MRtv Offline
MRtv  Offline
Boise, Idaho
How high do you want? Each board is about 1.5 inches thick. So for whatever hight you need you can calculate from there. I put in four layers. It got my Versa up 6 inches. Perfect for my oil change on the Versa. Need higher? Add layers but know that wood can be heavy so you are adding weight as you add on height.
2014 Nissan Versa Note 1.6 liter engine. 1997 Ford F150 4x4 4.6 liter engine.
Re: Wood boards as a backup for Rhino ramps—how high? [Re: paulri] #4697460
03/17/18 10:27 AM
03/17/18 10:27 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
I’d recommend the full height to the chassis and tight against the chassis. May I recommend to pick up a set of jack stands on sale. They are are much easier to work with. (But rememeber to pull them out at the end of the job. )
If you want the job done right......do it yourself.
Re: Wood boards as a backup for Rhino ramps—how high? [Re: Snagglefoot] #4697465
03/17/18 10:34 AM
03/17/18 10:34 AM
CA, USA
CA, USA
https://www.walmart.com/ip/Torin-Jacks-3-Ton-Jack-Stand-Pair/14560047
Regular price is over 100 bucks. Is this a reputable company? WM has them for $24. 3 ton capacity would cover the Sienna as well.
Alternately, PB has this set: https://www.pepboys.com/product/details/1154551/00773?quantity=1
Harbor Freight: https://www.harborfreight.com/3-Ton-Steel-Jack-Stands-61196.html
Not sure which companies can be trusted here. Rather not use chinesium as my backup plan.
Re: Wood boards as a backup for Rhino ramps—how high? [Re: paulri] #4697470
03/17/18 10:39 AM
03/17/18 10:39 AM
Georgia
AVB Offline
AVB  Offline
Georgia
$100 is [censored] wishful thinking, marketing. Those are around $25 anywhere you go.
Re: Wood boards as a backup for Rhino ramps—how high? [Re: paulri] #4697471
03/17/18 10:39 AM
03/17/18 10:39 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Because of stories of ramps and jacks failing, I like to PLACE REAL JACKSTANDS under the car to support it, if needed.
There, I fixed that for you.
Re: Wood boards as a backup for Rhino ramps—how high? [Re: paulri] #4697473
03/17/18 10:42 AM
03/17/18 10:42 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I'll vouch for these (That all pretty much come from china, no matter who sells them)
The ratings are utterly ridiculous - 3 tons (6,000 lbs) is wishful thinking at best.
Used properly in general auto use, they are just fine.
I like to place a 12" x 12" square of 3/4" plywood under each one
when used on any surface other than concrete.
Re: Wood boards as a backup for Rhino ramps—how high? [Re: paulri] #4697476
03/17/18 10:44 AM
03/17/18 10:44 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
My grandfather built something similar to these about 50 years ago.
They are nearly indestructible & will hold a semi-truck!
Re: Wood boards as a backup for Rhino ramps—how high? [Re: paulri] #4697478
03/17/18 10:47 AM
03/17/18 10:47 AM
Georgia
AVB Offline
AVB  Offline
Georgia
If you are worried about the ramps failing make some of the pine-o ramps. That is what we used when servicing semi's.
Re: Wood boards as a backup for Rhino ramps—how high? [Re: Linctex] #4697482
03/17/18 10:54 AM
03/17/18 10:54 AM
Texas
4WD Online confused
4WD  Online Confused
Texas
I see why he has wheels … mine are heavy enough that I put a gate handle on the end
Re: Wood boards as a backup for Rhino ramps—how high? [Re: paulri] #4697499
03/17/18 11:09 AM
03/17/18 11:09 AM
Kansas, USA
Kansas_Ron Offline
Kansas_Ron  Offline
Kansas, USA
Purchase 2, 2"x 10" x 12' boards. One board will make a ramp. Lowes will cut to lengths shown. Get some nails, or screws and adhesive. Cheap. simple, and heavy. I have used them for 8 years.
2000 Chevy Prizm
2015 Honda Civic
2017 Hyundai Elantra
Re: Wood boards as a backup for Rhino ramps—how high? [Re: Kansas_Ron] #4697507
03/17/18 11:17 AM
03/17/18 11:17 AM
Texas
4WD Online confused
4WD  Online Confused
Texas
One nice thing about these is they will not slide away when bringing a RWD vehicle up on them … the first 1-1/2” rise pins them down tight
Pine-O Ramps have their place …
Re: Wood boards as a backup for Rhino ramps—how high? [Re: paulri] #4697515
03/17/18 11:26 AM
03/17/18 11:26 AM
NJ
Leo99 Offline
Leo99  Offline
NJ
I use the harbor freight jack stands when I need to use jack stands.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: Wood boards as a backup for Rhino ramps—how high? [Re: paulri] #4697520
03/17/18 11:31 AM
03/17/18 11:31 AM
CA, USA
CA, USA
If wood is capable of holding up the car as the primary support, it should also be ok as a backup support, shouldn't it?
If possible, I'd like to get more input on my original question--assuming I'll continue using wood boards, how high do the boards have to get? Snagglefoot said take the boards up to the height of the chassis. Is that what is best or what everyone does, who uses boards?
Re: Wood boards as a backup for Rhino ramps—how high? [Re: paulri] #4697522
03/17/18 11:37 AM
03/17/18 11:37 AM
The Motor City
Kestas Offline
Global Moderator
Kestas  Offline
Global Moderator
The Motor City
My ramps are a stack of 2 x 12s. For safety I throw a short log or two under the car and chock a wheel. It's not worth taking short cuts when it comes to safety.
Page 1 of 3 1 2 3
