White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
FRAM end cap differences EG and TG vs XG
by wemay. 01/19/19 09:25 PM
Valvoline modern Engine
by Pinoak. 01/19/19 09:02 PM
30 Vintage Photos
by StevieC. 01/19/19 08:23 PM
Low mileage, when to change oil?
by Metfanant. 01/19/19 08:05 PM
Filter with bypass when OEM has built-in bypass
by rubberchicken. 01/19/19 07:43 PM
Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
dougway, Jetsfan421, Fordman420, 72sbc, ejmiller
66982 Registered Users
35 registered members (c502cid, carlprop, Black_Thunder, Blkstanger, BlakeB, bubbatime, 4 invisible), 882 guests, and 30 spiders.
Topics296,866
Posts4,960,375
Members66,982
Most Online2,688
Jan 19th, 2019
Something is leaking from somewhere (photo) #4696956
03/16/18 05:26 PM
03/16/18 05:26 PM
Melbourne, Florida
RichardS Offline OP
RichardS  Offline OP
Melbourne, Florida
Itís clearly coming out of the protective boot around the drive shaft on the drivers side, but a similar color and consistency fluid can be found on the passenger side on the underside of the hood.
I donít lose a noticeable amount of motor oil or PS fluid in between oil changes, and I empty/refill the PS reservoir with each oil change.
What fluid am I losing, and where do you think itís leaking from?
2008 Dodge Caliber SE 2.0 117k
4qt Imeditsu 0w-20, 1/2qt Mobil SS 5w-20 Fram HM
2003 Buick Century 107k
4.5q Havoline 5w-30 HM Fram XG
Re: Something is leaking from somewhere (photo) [Re: RichardS] #4696963
03/16/18 05:32 PM
03/16/18 05:32 PM
California, USA
casamagana Offline
casamagana  Offline
California, USA
Pin hole in axle boot. I see grease.
'15 Hemi 6spd Challenger, '89 Chev R3500 dually-454 tbi,
'67 Firebird-406 sbc-th350, 3.73 8.5"axle, [email protected]/8th
'66 Bug, '87 Banshee, '85 ATC 350X
Re: Something is leaking from somewhere (photo) [Re: RichardS] #4696969
03/16/18 05:39 PM
03/16/18 05:39 PM
USA
mk378 Offline
mk378  Offline
USA
Yes the CV joints are packed with grease, and the boot is supposed to keep the grease in.
Re: Something is leaking from somewhere (photo) [Re: RichardS] #4696984
03/16/18 05:50 PM
03/16/18 05:50 PM
USA
147_Grain Offline
147_Grain  Offline
USA
CV Axle grease.
Re: Something is leaking from somewhere (photo) [Re: RichardS] #4696987
03/16/18 05:51 PM
03/16/18 05:51 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Yes, leaking CV boots. They may or may not be spit or even have a hole, at that age the grease can thin out dramatically and can leak past the clamps also.
Re: Something is leaking from somewhere (photo) [Re: RichardS] #4696993
03/16/18 05:57 PM
03/16/18 05:57 PM
texas
danez_yoda Offline
danez_yoda  Offline
texas
get new boots before it starts clicking.
Re: Something is leaking from somewhere (photo) [Re: RichardS] #4696999
03/16/18 06:04 PM
03/16/18 06:04 PM
IL
qjohn Offline
qjohn  Offline
IL
If it is leaking from the end of the boot underneath the big clamp, then just tighten the clamp or put on another clamp. If the boot has a hole, replace the boot or axle assembly.
Re: Something is leaking from somewhere (photo) [Re: RichardS] #4697032
03/16/18 06:47 PM
03/16/18 06:47 PM
Melbourne, Florida
RichardS Offline OP
RichardS  Offline OP
Melbourne, Florida
Thanks everybody! I knew I should have taken better photos while I was under there.
I was only on the drivers side - but it seemed to be along the end of the boot closest the center of the car , and not anywhere along the middle of the boot.
I just got hub assemblies in the mail today - so I suppose I should delay their installation until I order new boots.
Yay/boo for new projects and learning new things!
Re: Something is leaking from somewhere (photo) [Re: RichardS] #4697036
03/16/18 06:54 PM
03/16/18 06:54 PM
Trav Offline
Trav  Offline
What car is this? Get poly boots if available and Redline CV02 grease, you will need about 14oz per side (7oz per joint).
Re: Something is leaking from somewhere (photo) [Re: RichardS] #4697045
03/16/18 07:08 PM
03/16/18 07:08 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
Two months ago I had to have the axle on the passenger side of my 2007 Fusion replaced for the same reason yours will need to be replaced. I noticed grease close to the boot and it had a very small hole in it.
2007 Ford Fusion 236,000 miles
M1 0-20 EP
2017 Ford Fusion 62K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: Something is leaking from somewhere (photo) [Re: RichardS] #4697058
03/16/18 07:16 PM
03/16/18 07:16 PM
Melbourne, Florida
RichardS Offline OP
RichardS  Offline OP
Melbourne, Florida
Trav,
This is on the Buick. I noticed it while replacing the struts. I only see poly available for the outer on rockauto, but there may be poly options at the local auto parts stores.
tig1,
Hopefully I donít need all that fun stuff, and itís just a boot replacement.
Re: Something is leaking from somewhere (photo) [Re: RichardS] #4697068
03/16/18 07:26 PM
03/16/18 07:26 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
Originally Posted By: RichardS
Trav,
tig1,
Hopefully I don’t need all that fun stuff, and it’s just a boot replacement.
Hope your right. However I had gallbladder surgery about that time and had to have it done. With labor, the cost was close to that of replacing the axle, so they put in a 3 year warrantied axle for me.
M1 0-20 EP
M1 0-20 EP
M1 10-30 in all OPE
MC filters
Re: Something is leaking from somewhere (photo) [Re: RichardS] #4697098
03/16/18 07:54 PM
03/16/18 07:54 PM
Trav Offline
Trav  Offline
Trav,
tig1,
Poly for the outer are great as those have the greatest range of motion, the inner are okay with neoprene.
Re: Something is leaking from somewhere (photo) [Re: RichardS] #4697397
03/17/18 08:13 AM
03/17/18 08:13 AM
Margate England
Claud Offline
Claud  Offline
Margate England
Why do you do that?.
Claud.
Re: Something is leaking from somewhere (photo) [Re: Claud] #4697402
03/17/18 08:19 AM
03/17/18 08:19 AM
Trav Offline
Trav  Offline
Most US cars don't use high end synthetic PS fluid like CHF 11S or CHF 202 so exchanging the fluid in the reservoir does help to keep the fluid in better condition longer.
