Walmart and Valvoline
by Bullwinkle007. 01/22/19 09:10 PM
Getting Our Kicks On Route 66
by 2015_PSD. 01/22/19 08:40 PM
Uploading a short film clip from an IPhone.
by Snagglefoot. 01/22/19 07:52 PM
Purolator L34631 (torn media)
by LDM. 01/22/19 07:51 PM
THIS close to getting a VDB today at TPA
by 14Accent. 01/22/19 07:48 PM
Supco Appliance Parts.
by George7941. 01/22/19 07:36 PM
Unusual Jury summons.
by Chris142. 01/22/19 06:31 PM
Vibration feeling after new tires installed?
by MONKEYMAN. 01/22/19 05:51 PM
Sudden Shake - ‘18 Accord
by Throt. 01/22/19 05:43 PM
05 Ford 500 Intake hole - melted
by Geauxtiger. 01/22/19 05:41 PM
How's K&N 1004 on Kia/Hyundai GDI
by SlavaB. 01/22/19 05:18 PM
more PSD woes with cold weather
by Donald. 01/22/19 05:10 PM
Can someone do a UOA on AmazonBasics oil?
by ThunderOne. 01/22/19 04:03 PM
Any analysis on the Mobil 1 0W-40 ESP Dexos 2?
by fnbrowning. 01/22/19 04:02 PM
Cat sick
by Eddie. 01/22/19 03:49 PM
Lubeguard
by hardheaded. 01/22/19 02:10 PM
OEM Cap & Rotor when changing spark plugs?
by paulri. 01/22/19 01:50 PM
A young boy...
by JLTD. 01/22/19 01:34 PM
73guna, Tedee, JayF, Sam002, Binco
67013 Registered Users
57 registered members (AdRock, bdcardinal, 209paulc, bernardch, 8 invisible), 1,120 guests, and 44 spiders.
Topics297,006
Posts4,963,335
Members67,013
Most Online2,821
Jan 21st, 2019
2000 Buick Century Code P1404 #4696920
03/16/18 04:39 PM
03/16/18 04:39 PM
Buffalo, New York
JimmyJohns Offline OP
Buffalo, New York
Hey guys
I just scanned my mothers car with one of those cheap bluetooth scanners, and discovered that she has code P1404 active. After some reading, it looks like it's the egr valve being stuck closed. I cleared the code to see if would come back, so I guess we will see.
But I wanted to ask for some advice on this, is it worth taking off the egr to clean it? Any backyard tricks anyone might have? Inspection is due in April, so I want to get this taken care of.
Re: 2000 Buick Century Code P1404 [Re: JimmyJohns] #4696928
03/16/18 04:50 PM
03/16/18 04:50 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Is your time worth $56 taking it off and cleaning it then possibly spending the %56 anyway and doing the job twice? You decide.
For that money on an 18 yrs old car I would change it and clean out the port at the same time.
Give it a couple of sharp taps (don't beat the thing just a rap) with a small dead blow on the side first and see if the code returns.
Re: 2000 Buick Century Code P1404 [Re: JimmyJohns] #4696929
03/16/18 04:52 PM
03/16/18 04:52 PM
Buffalo, New York
Buffalo, New York
Thanks for the advice.
I'm not trying to sound cheap, some things on vehicles can have a stupid solution, that's why I asked. I'll give her a tap, makes sense if theres carbon buildup
How would you go about cleaning out the port?
Re: 2000 Buick Century Code P1404 [Re: JimmyJohns] #4696953
03/16/18 05:23 PM
03/16/18 05:23 PM
Trav Offline
Trav  Offline
Long brass brush like this can be had from plumbing supply houses like FW Webb. Sometimes just a flexible wire will do and unfortunately sometimes things need to come apart but you can usually get it without.
https://www.amazon.com/Diameter-Brass-Br...8BTQ9PRR58WSTB1
Re: 2000 Buick Century Code P1404 [Re: JimmyJohns] #4697046
03/16/18 07:10 PM
03/16/18 07:10 PM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
The electric solenoids in those burn out after awhile. The only sure way to test it after verifying powers and grounds is to use a scan tool that can bi-directionally command the EGR to open and then tell you the amount of opening with a percentage number which would be the EGR opening position. The FSM will tell what the opening should be at a specified RPM.
Re: 2000 Buick Century Code P1404 [Re: JimmyJohns] #4697070
03/16/18 07:28 PM
03/16/18 07:28 PM
USA
oldhp Offline
oldhp  Offline
USA
Also, before you install the valve, start the engine just for a second to blow anything in there out.
2018 RAM 1500 3.6/8 speed.
2017 Jeep Sahara Unlimited 3.6
"U kan't fixe it......if'n it ain't broke."
Re: 2000 Buick Century Code P1404 [Re: JimmyJohns] #4697074
03/16/18 07:32 PM
03/16/18 07:32 PM
ME
eljefino Offline
eljefino  Offline
ME
My test rig works good and I don't have one of those alternative-lifestyle scan tools. laugh
If you yank the EGR valve, push its pintle with a pencil. Odds are good it's sticky and will free up. You can spray brake cleaner in there and free it up for a little while.
Run the car with the valve off-- its absence will help clear the passages.
It should be noisy, showing the path to the valve is clear.
It should also idle high and/ or lumpy, showing the path to the intake is clear.
A bike brake cable in a drill is cliche but actually really works for clearing this stuff out.
Re: 2000 Buick Century Code P1404 [Re: JimmyJohns] #4697101
03/16/18 07:57 PM
03/16/18 07:57 PM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
I had the same code two years ago on my 3.8. Cost me a gasket, I cleaned it up and its been fine since.Took 15 minutes.
The "thinking" man's friend.
Re: 2000 Buick Century Code P1404 [Re: Lubener] #4697128
03/16/18 08:24 PM
03/16/18 08:24 PM
North Carolina
Egg_Head Offline
Egg_Head  Offline
North Carolina
Try all the previous suggestions, if you need to replace buy the OE GM part and not aftermarket. Good luck, usually a good cleaning is the trick.
1979 Garelli Rally Sport
2009 Cub Cadet LT1042
2002 BMW 540 M Sport (totaled)
2011 MB E350 4Matic wagon
1979 CJ-7
Re: 2000 Buick Century Code P1404 [Re: JimmyJohns] #4697161
03/16/18 09:16 PM
03/16/18 09:16 PM
Buffalo, New York
Buffalo, New York
Wow, what a bunch of great replies. OEM would be AC Delco right?
Running it with it off is a great idea, I can't believe I didn't remember that, I used to work in a diesel and they used to take off the EGR on a cummins, clean it and run it to blow the [censored] out.
I'll pop it off and see what it does like you suggested eljefino.
Glancing at it I see mine is a little different than the one on this car, the one on this car is at a right angle, and I see a tube coming out the bottom, are these bolts/nut hard to get off since they have hot exhaust??
Re: 2000 Buick Century Code P1404 [Re: JimmyJohns] #4697263
03/17/18 03:48 AM
03/17/18 03:48 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
They are not torqued all that tight, you shouldn't have any problems. Give the threads a shot of BP Blaster first.
Re: 2000 Buick Century Code P1404 [Re: JimmyJohns] #4697270
03/17/18 04:15 AM
03/17/18 04:15 AM
South Central PA
Delta Offline
Delta  Offline
South Central PA
I think there was a video on Youtube from South Main Auto on this exact issue, I think it was an Equinox with the 3.4, but same looking valve. As Trav said, he started tapping it and it worked. Those things gets crudded up over time and stop working. Had the same problem on our 2008 Equinox, but it was an oil burner. We traded it in before I replaced it, but a month or so later I looked up the vin and it showed the GM dealer replaced it.
'17 VW GTI 2.0T - 6MT - 12K - PPE 5w40
'15 Camry SE - 2.5 - 21K - PP 0w20
'99 S10 - 2.2 5MT - 157K - PP 10w30
Re: 2000 Buick Century Code P1404 [Re: JimmyJohns] #4697829
03/17/18 05:23 PM
03/17/18 05:23 PM
Buffalo, New York
Buffalo, New York
I love South Main Autos videos, awesome guy and great work and a good resource to learn from. I loved the video where he went to his brothers diesel shop where he was doing an in-frame overhaul on a cummins.
Anyway, I digress, I gave it a few good taps with a rubber mallet, cleared the code and we shall see. I'll scan it in a few days to make sure the drive cycle is completed, at the moment if I don't have to replace it I would rather not even though they are relatively cheap.
Re: 2000 Buick Century Code P1404 [Re: JimmyJohns] #4705712
03/24/18 06:24 PM
03/24/18 06:24 PM
Buffalo, New York
Buffalo, New York
Little update
I remembered when I did the intake gaskets, I grabbed the EGR valve when I grabbed the intake I needed.
So today I put that on, but I noticed that the tube going into the EGR was a little bent, so I hope thats not an issue, I tried to straighten it some. I started the car with it off, but it didn't want to stay running unless I put my foot on it, so I hope that isn't indicative of an issue.
This valve looked a lot cleaner, but the angle that the bottom is at, I can't really get anything in there to move the pintle. I sprayed it and let it sit in some brake clean for a little while.
It got dark so tomorrow I'll clear the code and see whats what. I also wanted to try this "Fix" that I found, I have no idea if it holds merit, or makes sense, but it's easy enough that I'll try it.
The fix goes like this:
1. Disconnect the wire harness from the EGR valve.
2. Turn key ON and erase the trouble code(s) from the car's computer AND TURN KEY OFF IMMEDIATELY WHEN THE SCANNER SAYS CODES HAVE BEEN ERASED. DO NOT TURN KEY ON BEFORE YOU RE-CONNECT EGR WIRE HARNESS.
3. Re-connect EGR wire harness and your problem should be fixed.
