Taking the leap to self-employment.....
Eventually
by clinebarger. 03/21/19 01:39 AM
Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
26 registered members (BlakeB, avi1777, AHernandez, Aero540T, billt460, 3 invisible), 517 guests, and 56 spiders.
Topics286,171
Posts4,903,558
Members67,572
Most Online2,967
Mar 10th, 2019
best non dexos oil for GM engines #4696907
03/16/18 05:23 PM
03/16/18 05:23 PM
Golden Meadow, LA
mobilaltima Offline OP
Golden Meadow, LA
buddies 2013 impala with the 3.6 DI engine, 150k miles out of warranty obviously. Those of you who have run non dexos oils in these GM DI engines, which have you had success and good UOA's with? Looking for utmost protection, car is driven to Midland, Texas every 2 weeks 1800 mile round trip, all interstate miles 80-85 mph, and then once in Texas, constant sandstorms and dusty conditions. The car and under the hood is solid brown every time he comes back from a trip lol. I know the air filter is very important, we will swap out the current STP air filter for an ACdelco, and we will keep the oil changes at 5k, just looking for an oil reccomendation.
2006 2500 Dodge 5.9 Cummins Mobil Delvac 15W40, Fleetguard Stratapore 90k miles
Early '99 F250 ECLB 7.3 Stroker, 223k miles
Re: best non dexos oil for GM engines [Re: mobilaltima] #4696921
03/16/18 05:40 PM
03/16/18 05:40 PM
Spring,Texas
Bud_One Offline
Bud_One  Offline
Spring,Texas
This link shows VWB 5W-30 showing good results at 5k miles.
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2243016
16 Civic-QSUD 0W-20, XG7317
14 Civic-Idemitsu Zepro 0W-20, XG7317
05 Chevy 2500HD-QSUD 10W-30, XG3675
97 Accord Wagon-Havoline ProDS 10W-30, TG7317
Re: best non dexos oil for GM engines [Re: mobilaltima] #4696932
03/16/18 05:57 PM
03/16/18 05:57 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
If looking for a non-Dexos non-ILSAC oil that is high in quality and should work in most PCMO applications, it's hard to go past a Euro rated A3/B4 0W40 such as M1 or Edge with OEM specs like MB 229.5, Porsche A40, etc
High HTHS > 3.5 cP (more protection reserve)
Low Noack Volatility < 10% (less oil consumption and a cleaner engine)
High TBN > 10 (for longer OCI)
with elevate ZDDP (zinc) ~ 1000 ppm level, which is an anti-wear agent to protect the metal, an anti-oxidant to protect the oil and a LSPI quencher to protect the engine. It's still cat friendly enough for the exhausts in German cars to last the distance.
I run Euro A3/B4 oils in my GM ecotec engine.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: best non dexos oil for GM engines [Re: mobilaltima] #4696983
03/16/18 06:48 PM
03/16/18 06:48 PM
Shippensburg, PA
novadude Offline
novadude  Offline
Shippensburg, PA
Why does it have to be non-dexos? I would say that any Dexos 1 Gen 2 5W-30 oil would be a really good choice for that application.
Re: best non dexos oil for GM engines [Re: mobilaltima] #4697002
03/16/18 07:11 PM
03/16/18 07:11 PM
Toronto Canada
WobblyElvis Offline
WobblyElvis  Offline
Toronto Canada
My son has the same engine in his Cadillac. Uses any synthetic oil he can find on sale. Usually a store brand that is non Dexos. 190,000 trouble free miles. Use a good air filter and there is no need to over change it. Check the oil level often and change oil regularly.
Re: best non dexos oil for GM engines [Re: mobilaltima] #4697077
03/16/18 08:36 PM
03/16/18 08:36 PM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
GTX 10W30
Noack 10%
18 KIA Sportage 2.4 AWD
M1HM 10W30, OEM
13 Hyundai Santa Fe Sport 2.0T
PPeL 5W30, OEM
Re: best non dexos oil for GM engines [Re: novadude] #4697115
03/16/18 09:11 PM
03/16/18 09:11 PM
Oshawa, Ont. Canada
irv Offline
irv  Offline
Oshawa, Ont. Canada
I'm curious about that as well? Being a 13, I would assume it calls for Dexos 1 oil? That is very easy to find and most oil companies meet that requirement.
My wife's 2017 3.6 Impala calls for D1 oil and I am currently running Pennzoil Ultra 5W-30 in it. The PP is also another great option but I chose the Ultra as it was on sale and only a couple bucks more than the Platinum.
2017 Chevy Impala 3.6 L.
2013 Ram 5.7 L Hemi Bighorn QC 4x4
2008 Chevy Malibu 2.4 L Ecotec
Pennzoil Platinum and/or Pennzoil Ultra Platinum in all 3.
Re: best non dexos oil for GM engines [Re: mobilaltima] #4697193
03/16/18 11:11 PM
03/16/18 11:11 PM
USA
slacktide_bitog Offline
USA
the dexos 1 gen 2 d1g2 is actually a legit spec for all the turbo DI nonsense out there.
But if you really must use a non-dexos oil, get Castrol Edge 0w30 or Rotella T6 5w30
Re: best non dexos oil for GM engines [Re: mobilaltima] #4697222
03/17/18 12:27 AM
03/17/18 12:27 AM
St. Charles County, Missouri
csandste Offline
csandste  Offline
I use MaxLife 5w30 in my out of warranty Buick Encore. I do so because I can't change at home and the price is good. If I had the direct injection version of the engine I would stay with Dexos 1 v 2. GM isn't going to spec different versions of Dexos for different engines, so the toughest spec applies to all cars.
My only DI engine was a Kia Rio, my only turbo engine is the Encore. If your engine has both, get the new Dexos.
2017 Kia Soul Plus-- VWB 5-30, 54,000 miles.
Re: best non dexos oil for GM engines [Re: mobilaltima] #4697226
03/17/18 12:33 AM
03/17/18 12:33 AM
Texas (south)
FermeLaPorte Offline
Texas (south)
M1 HM and Edge I think are not dexos and they are good oils. I think if you ever want to save money, I would use Motorcraft or SuperTech.
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
Re: best non dexos oil for GM engines [Re: mobilaltima] #4697254
03/17/18 04:01 AM
03/17/18 04:01 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
Any name brand 10W30 will do the job, and isn't Dexos since it's not a Dexos viscosity grade (but it should be).
M1 10W30, PP 10W30, Magnatec 10W30, etc
Re: best non dexos oil for GM engines [Re: mobilaltima] #4697663
03/17/18 02:33 PM
03/17/18 02:33 PM
Golden Meadow, LA
Golden Meadow, LA
I just assumed there might be oils out there, such as Euro spec'd oils, that offer better protection...as to why non-Dexos oils....this is BITOG last time I checked haha. What is the difference between A3/B3 oils and A3/B4 oils? I was considering using Mobil 1 High Mileage 10W30, which is API SN and A3/B3, should this work fine? There are no others specs listed for this oil such as GM6094M or GM4718M. I was also considering using this oil in an Equinox with a 2.4 Ecotec DI and a few Chevys 1500s with the 4.8 and 5.3 Vortec.
Re: best non dexos oil for GM engines [Re: mobilaltima] #4697777
03/17/18 05:22 PM
03/17/18 05:22 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
Yep ..... That's all I need, in fact I didn't even bother to ask, as you said this is BITOG.
The main difference is TBN.
A3/B4 has TBN > 10
A3/B3 has TBN > 8
To me A3/B4 is the original EP / AP / LongLife oil.
Now both A3/B3 & A3/B4 must also pass cam wear tests and piston deposit test, and for both the A3/B4 is held to a higher standard (less wear & less deposits). However for the M1 versions, I wouldn't be too concerned and I assume the major difference would be the TBN level. Mostly (I assume) to keep their HM line separate to their EP line.
I think M1 10W30 HM (SN & A3/B3) is a good looking oil, I would use it but we don't get it here.
