1984 fury 318.
by red7404. 01/20/19 10:48 PM
Dual Wrench (Humor)
by StevieC. 01/20/19 10:33 PM
Got A Tip For Everyone
by NYEngineer. 01/20/19 10:30 PM
Ford Truck (Humor)
by StevieC. 01/20/19 10:10 PM
Lucas and fresh oil
by Ls1z. 01/20/19 09:42 PM
NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
46 registered members (anndel, billpace1956, carloz, Brad_C, Ammofirst, BikeWhisperer, 5 invisible), 1,059 guests, and 31 spiders.
Topics296,903
Posts4,961,302
Members66,997
Most Online2,688
Jan 19th, 2019
Piecing together bypass kit. #4696866
03/16/18 03:19 PM
03/16/18 03:19 PM
Central BC, Canada
CrazyMike Offline OP
Central BC, Canada
Hello! Truck is a 2016 Ford F450, 6.7 diesel. Looking to save money over an Amsoil kit, but I want to bounce my strategy here first. Perma Cool sandwich adapter
https://shop.perma-cool.com/1836-Sandwich-Adapter-1-16-thread-1836.htm
Going to do a LuberFiner LFP9750 on the complimenting remote mount. Will the Perma Cool adapter work without any modifications for this system, pretty sure flow restriction will be 1/16Ē, either on the filter base or built into the filter.
The truck had emissions intact, I have no interest to delete. There is no tuning, it has a large dry element with pre filter on the intake, I can go 6 months without changing, or longer. I have a Stage 3 Snow Performance methanol kit going in also, lower exhaust temps and reduced regen intervals. It also has an aftermarket coolant filter.
Last q, looking at the basic systems that feed bypas oil through the filler cap, doesnít this reduce oil pressure with XX amount of oil dumping into the oil pan instead of being fed back into the block? This is the primary reason I want to use the sandwich adapter, itís re-routed for filteration but is fed back into the block in the same manner as a stock system, I could be wrong but this to me doesnít show a drop in oil pressure. Thx for the time, and your comments.
Also to add, the reason for a bypass on a new truck, my dealership is very flexible with what I do, Iím not concerned with warranty. I donít plan to trade anytime soon, Iíll be keeping this truck at least 5-6 years. Maybe more if it doesnít have issues. With my hostile climate, it isnít hot but itís dusty, all year long up in central BC. Regardless of oil filter brand, oil brand, mineral, synthetic, or viscosity, miles between regens extend to 225-250 miles after a service, but the mileage between regens drop considerably by the time you hit 4,000miles on the oil. Lots of additives still present, but itís filthy. This has been the same over 4 trucks since 2011, all the same motors, with full emissions, stock air box or the large s&b air filter Iím running now. Fuel is the biggest factor on regen frequency, and sometimes the fuel isnít so good, but I do see this pattern with regen frequency that I donít see when traveling to places with much less dust. Thx again for the time, sorry for the novel.
Ford F450 6.7, Mercedes cars, lots of toys using oil.
Re: Piecing together bypass kit. [Re: CrazyMike] #4696882
03/16/18 03:40 PM
03/16/18 03:40 PM
Upstate NY
Fred_Garvin Offline
Fred_Garvin  Offline
Upstate NY
No that is not what you want that is to be used when installing a cooler. It will route oil to the cooler then return back to the oil galley. You wan to just sample oil supply. The simplest most low buck solution is to tap into the oil system at the oil pressure switch or sensor with a Tee and run to your bypass setup and return to the sump or valve cover.
Re: Piecing together bypass kit. [Re: CrazyMike] #4696903
03/16/18 04:15 PM
03/16/18 04:15 PM
Central BC, Canada
Central BC, Canada
Thx for the reply Fred, but I donít follow a few comments. To clarify, i do understand the adapters designed intent, but Iím not plumbing in an oil cooler to the sandwich adapter, just the bypass lines stepped down to a 1/4Ē-3/8Ē diameter line. I was hoping this adapter would just flow according to the 1/16Ē restriction. Also, you donít have concerns with oil pressure dropping if feeding back into the fill cap? I wanted to avoid that setup as Iíve commented in my OP, some clarity on why itís a non issue would be great. Thx.
Re: Piecing together bypass kit. [Re: CrazyMike] #4697052
03/16/18 07:14 PM
03/16/18 07:14 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
I bought a kit on eBay from Oil Charge Systems. All top quality components, Amsoil spin-on filter. Feeds the filtered oil back to the oil fill cap. No drilling, cutting, crimping. The oil lines are pre-made.
2015 Ford F250 w/Powerstroke
Re: Piecing together bypass kit. [Re: CrazyMike] #4697124
03/16/18 08:19 PM
03/16/18 08:19 PM
Upstate NY
Fred_Garvin Offline
Fred_Garvin  Offline
Upstate NY
Because a bypass filter is intended to bypass a small amount of oil through the filter and return it to sump. Bypass filters are generally very flow restrictive. They rely on high pressure differential to work properly. They are not designed for nor should they be used in a full flow setup which is what you would be doing if you routed the oil from that adapter to the filter and back again.
You will not see any noticeable amount of pressure loss in a properly designed bypass setup. The oil system should be capable of providing much more oil flow than the engine needs.
Re: Piecing together bypass kit. [Re: CrazyMike] #4697126
03/16/18 08:21 PM
03/16/18 08:21 PM
Upstate NY
Fred_Garvin Offline
Fred_Garvin  Offline
Upstate NY
Sorry dupe
Re: Piecing together bypass kit. [Re: CrazyMike] #4697156
03/16/18 09:11 PM
03/16/18 09:11 PM
Central BC, Canada
Central BC, Canada
Interesting, thx for taking the time! I cancelled the order and will focus on a more traditional strategy. I thought the 1/16Ē flow restriction down stream on the filter block would of been all I needed to limit flow and keep the remaining volume focused at the oem full flow on the adapter.
Re: Piecing together bypass kit. [Re: CrazyMike] #4697169
03/16/18 09:31 PM
03/16/18 09:31 PM
Illinois
Crusher Offline
Crusher  Offline
Illinois
CrazyMike
I'm all for saving money, but how much money are you thinking you'll save? Although I run a Dual bypass filter setup on my gas engine, I run the same filters that you would run on your 6.7L PSD. I can tell you without exception that my Amsoil Dual bypass BMK 23-EA works [censored] Good! If I'm not mistaken your 6.7L PSD is about a 15-20k engine.
2011 King Ranch Ford Expedition EL 4x4 - 191,000 miles - Amsoil Signature Series 5w-20, BMK 23-EA Dual Bypass Filter
Re: Piecing together bypass kit. [Re: CrazyMike] #4697194
03/16/18 10:11 PM
03/16/18 10:11 PM
Central BC, Canada
Central BC, Canada
I hear you, the price considering I have the fittings, really all the equipment Iíd need for install, an Amsoil dual bypass is over $700 cdn delivered, the single pass is $600, where a sandwich adapter, EABP110 or LFP9750, and remote mount would be under $200 by comparison. Iím also not a fan of -40f and colder weather, where a block heater can heat water jackets and pan oil to make a cold start trouble free, but a full pass filter and itís internal bypass is 2í or more away from that heat source, Iím not so sure. Regardless, Iím not finding an adapter that will allow a bypass feed and return while keeping the filter attached to the block. I thought this permacool was the ticket.
Re: Piecing together bypass kit. [Re: CrazyMike] #4697200
03/16/18 10:22 PM
03/16/18 10:22 PM
Central BC, Canada
Central BC, Canada
FWIW, maybe price was the wrong wording, I find it a PITA to buy the whole kit when I have so many workable parts. The hoses, Iíve seen many premium quality hydraulic hoses grenade over the years in cold weather, maybe itís apples and oranges comparing that to an engineís oil pump.
Re: Piecing together bypass kit. [Re: CrazyMike] #4700485
03/20/18 08:17 AM
03/20/18 08:17 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
What exactly is the value of a bypass filter setup?
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Piecing together bypass kit. [Re: CrazyMike] #4700505
03/20/18 08:43 AM
03/20/18 08:43 AM
Midwest, Illinois
beanoil Offline
beanoil  Offline
Midwest, Illinois
A bypass can lower particle counts, and extend OCI. That's the short version.
In reality, for the majority of folks, it's really no more than bragging rights, especially if you continue to change at 5k and are keeping the oil clean by replacement vs. filtering.
But, crazy mike and I are from the same thought. I still want one too. I had one on my 6.0, more for insurance to keep the injectors happy. I bought a Racor for my 6.7 to mount on the frame close to the factory spin on. I'll buy the parts for the lines from anfittingsdirect, and tee off the temp sender above the filter. I have an Amsoil BP-89 I'm mounting in the factory oil cap.
The new Racor absolute looks like a solid unit and similar technology to a Frantz.
Racor Absolute
I bought an older model LFS801 for my truck.
Bypass Series
I agree that oilchargesystems is a solid company. Good folks, complete kits available.
beanoil: Tough under heat, real dirty afterwards.
Re: Piecing together bypass kit. [Re: beanoil] #4701042
03/20/18 05:50 PM
03/20/18 05:50 PM
ohio
xtell Offline
xtell  Offline
ohio
beanoil,
That Absolute unit does look nice. Similar to the way the Frantz Oil Refiner (newest version of the Frantz Filter) works. At 12 inches in height, that may be a squeeze in most engine bays. Alternative area mounting might be needed. Of course, now that I've seen one down the road I'm just going to have to get one for mounting on one of my trucks!!! Thanks beanoil for hooking me on to yet another filter!!! Like I really need another Bypass, well yea, I guess I do...
Re: Piecing together bypass kit. [Re: CrazyMike] #4760526
05/18/18 02:10 AM
05/18/18 02:10 AM
Virginia, usa
Shata Offline
Shata  Offline
Virginia, usa
No matter how you decide to build your bypass make sure you use small enough restriction to bypass filter. I want to say most people use like .030" hole restriction into the bypass. Someone correct me if im wrong here on size. But you want small hole specially off off the oil pressure sensor cause thats main oil gallery.
16 Silverado 2500 6.6 LML Dmax
15w-40 Mobil Delvac
Fram Ultra XG9100
Filter Mags: Fuel filter, Allison and engine.
CAT Coolant Filter, Wix Air Filter, K&N Cabin Filter
Re: Piecing together bypass kit. [Re: Shata] #4763396
05/20/18 07:27 PM
05/20/18 07:27 PM
ohio
xtell Offline
xtell  Offline
ohio
That"s right. I run a .030 restrictor fitting off of my sandwich adapter below the oil filter.
