Air Fryer....whose got'em?
by Schmoe. 01/16/19 01:59 PM
ebates - anyone a member?
by Papa Bear. 01/16/19 01:29 PM
Ordered a 2019 X5 for the Wife
by gofast182. 01/16/19 12:48 PM
Today, I ride
by SirTanon. 01/16/19 12:02 PM
2019 Nissan Rogue SL
by JTK. 01/16/19 11:19 AM
Does GM oil life monitor % go down without driving?
by Corollaman. 01/16/19 10:37 AM
Ford tire wear issues?
by Redright9. 01/16/19 10:23 AM
New Battery
by CarlGR. 01/16/19 10:21 AM
It's January and I Need My Motorcycling "Therapy" !!
by LoneRanger. 01/16/19 10:13 AM
Are New Vehicles Too Expensive?
by SubLGT. 01/16/19 10:02 AM
Manual transmission fluid in Europe for Mazda
by zsero. 01/16/19 07:31 AM
Affected by the gov't shutdown?
by xBa380. 01/16/19 07:04 AM
Opinion Needed / 1998 Olds 88
by Mark72. 01/16/19 06:24 AM
Chevron Supreme color change
by OilUzer. 01/16/19 05:14 AM
Dual exhaust benefits
by OilUzer. 01/16/19 03:02 AM
M1 0w40
by Pinoak. 01/16/19 01:55 AM
M1 0w40
by Pinoak. 01/16/19 01:51 AM
The best in personal defense (Humor)
by StevieC. 01/15/19 11:10 PM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
97 registered members (240_Ed, AandPDan, 97f150, advocate, anndel, 2015_PSD, 11 invisible), 2,260 guests, and 30 spiders.
Topics296,643
Posts4,956,486
Members66,950
Most Online2,577
Jan 14th, 2019
Page 1 of 3 1 2 3
2000 5.3 knock, help diagnosing cause? #4696414
03/16/18 07:17 AM
03/16/18 07:17 AM
CT USA
Mc357 Offline OP
Mc357  Offline OP
CT USA
I have a loud knock at cold start up, or after sitting 6-8 hours on cold days.
the truck has over 180k miles.
The sound goes away within a few minutes. It sounds more like a knock than a lifter tick, and seems to deep of a sound for piston slap.
I am running 10w-30 Valvoline synthetic High mileage. here is a video of my truck the other morning.
thanks for any help
https://www.youtube.com/watch?v=nI0T4RsyoAw
Re: 2000 5.3 knock, help diagnosing cause? [Re: Mc357] #4696421
03/16/18 07:23 AM
03/16/18 07:23 AM
wv
krismoriah72 Offline
wv
There are alot of threads on here and other forums..i have read about half of them. The consensus is pretty much replace all the lifters or just get used to it.. no ill effects other than just aggravating you to death.
There are also youtube videos of 'fixes' with MMO or ATF or Seafoam etc etc etc..
Re: 2000 5.3 knock, help diagnosing cause? [Re: Mc357] #4696426
03/16/18 07:27 AM
03/16/18 07:27 AM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
I thought that problem was limited to the 5.3 w/AFM. Guess not, thats the noise.. a lifter gouging a cam lobe.. Gotta fix it, can't live with.
Is there a check engine light on?
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 152k ST HM 10w30
Re: 2000 5.3 knock, help diagnosing cause? [Re: Mc357] #4696429
03/16/18 07:29 AM
03/16/18 07:29 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
I can see your pressure gage went up to just over 40 psi when you started the engine, which is good. I agree that is stronger than normal GM piston slap. Wondering if one of the lifters is bad.
If you want the job done right......do it yourself.
Re: 2000 5.3 knock, help diagnosing cause? [Re: Mc357] #4696430
03/16/18 07:30 AM
03/16/18 07:30 AM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
But.. all GM engines have a bit of piston slap cold.. mine did that a little. Got the right oil and filter and its just about gone.
What oil brand and weight and what filter are you using?
Re: 2000 5.3 knock, help diagnosing cause? [Re: Mc357] #4696438
03/16/18 07:35 AM
03/16/18 07:35 AM
Idaho
CT8 Online content
CT8  Online Content
Idaho
18 year old vehicle. Milk it.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: 2000 5.3 knock, help diagnosing cause? [Re: LeakySeals] #4696442
03/16/18 07:37 AM
03/16/18 07:37 AM
CT USA
Mc357 Offline OP
Mc357  Offline OP
CT USA
The check engine light comes on if I keep it above 2000 RPMs for very long so if I go down the highway and I go over 70 I will get a flashing check engine then it stays solid if it's very cold out and I'm going 35 or 40 I will also get a check engine if the RPMs go above 2000 for more than a few seconds the code is p0300 random multiple misfire.
I just put new iridium ac Delco in and it did not help
Re: 2000 5.3 knock, help diagnosing cause? [Re: LeakySeals] #4696445
03/16/18 07:40 AM
03/16/18 07:40 AM
CT USA
Mc357 Offline OP
Mc357  Offline OP
CT USA
I am using Valvoline 10 30 weight high-mileage synthetic.
I just changed the filter the other day to a super tech cheap filter before that I had the AC Delco ecore filter in it the larger of the two
Have only put a couple of thousand miles on this truck since I bought it I was planning on doing frequent oil changes to see if that clears up the problem but it sounds a little louder than a lifter I thought
Re: 2000 5.3 knock, help diagnosing cause? [Re: Mc357] #4696452
03/16/18 07:44 AM
03/16/18 07:44 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Hmmm well, it could be piston slap as these engines(especially the larger 6.0/6.2L) were known for piston slap, usually earlier on than 180K miles.
But from the video, it also sounds to my ears like a bearing under the hood that goes away...IDK, alternator bearing and belt???
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: 2000 5.3 knock, help diagnosing cause? [Re: Mc357] #4696456
03/16/18 07:48 AM
03/16/18 07:48 AM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
Short pistons rock in the bore till they expand. Nothing gonna stop that.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: 2000 5.3 knock, help diagnosing cause? [Re: Mc357] #4696474
03/16/18 07:58 AM
03/16/18 07:58 AM
Chester County/Pa.
BAJA_05 Offline
BAJA_05  Offline
Chester County/Pa.
I had drain back with Super Tech filters from day one -- went with a Fram Ultra and fixed it on my neighbors Ram. Those 5.3L motors are known for your noise -- I would still get that filter off moving forward.
2017 VW Jetta SE TSI 1.4L Turbo (hers)
M1 Euro 0W40 & FU (19K)
2008 Acura TL 3.2L PPPP 0W20 & FU (108K)
2005 Subaru Baja AWD 2.5L N/A 5spd.
QSHM 5W30 & FU (96K)
2000 Ram 4X4 5.9L (93K) PYB 10W30 & FU
Re: 2000 5.3 knock, help diagnosing cause? [Re: Mc357] #4696479
03/16/18 08:06 AM
03/16/18 08:06 AM
Snagglefoot Offline
Snagglefoot  Offline
It's worth trying 5-30 oil and a Fram Ultra. What was the temperature the morning you started it? I heard it was a bit cold in your part of the woods lately.
Re: 2000 5.3 knock, help diagnosing cause? [Re: Mc357] #4696480
03/16/18 08:08 AM
03/16/18 08:08 AM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
This is the collapsed lifter eating the cam lobe noise. Sounds more like belt squeal than a rattle or a lifter tick..
https://www.youtube.com/watch?v=Zlvz5oLESug
Re: 2000 5.3 knock, help diagnosing cause? [Re: Snagglefoot] #4696484
03/16/18 08:11 AM
03/16/18 08:11 AM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
I stopped using the Ultra on my 6.0 because piston slap got worse. I tried a better flowing lower efficiency filter and that helped a lot.
Re: 2000 5.3 knock, help diagnosing cause? [Re: Snagglefoot] #4696487
03/16/18 08:16 AM
03/16/18 08:16 AM
CT USA
Mc357 Offline OP
Mc357  Offline OP
CT USA
In the 20s I believe. 26 maybe?
I may change my oil again this weekend. It's a shame to dump oil under 3k miles. And I just bought 2.5 gallons of delo 10w30. But I can buy some 5w30 if it may help.
Maybe a napa gold filter?
Page 1 of 3 1 2 3
