Remote Start by Android Auto App ?
by LoneRanger. 04/19/19 04:53 PM
Continental PureContact LS
by The Critic. 04/19/19 03:31 PM
Dark/Black Rear Differential Oil - UOA?
by The Critic. 04/19/19 03:25 PM
Best oil for Honda Rancher?
by jayjr1105. 04/19/19 03:20 PM
Store bought kimchi?
by Quattro Pete. 04/19/19 03:15 PM
2020 KIA Soul Turbo
by Malo83. 04/19/19 03:03 PM
erratic Speedometer
by tookien. 04/19/19 02:59 PM
Another airbag recall
by mclasser. 04/19/19 02:44 PM
Which barb fitting is less likely to leak?
by zorobabel. 04/19/19 02:36 PM
Can these bucket style tappets be reused?
by atikovi. 04/19/19 01:34 PM
Scratched My New Car. Help Me Fix
by GeorgeKaplan. 04/19/19 01:23 PM
Talk about manual labor...
by AZjeff. 04/19/19 12:42 PM
Car didn't burn an ounce of oil... 7K OCI
by jayjr1105. 04/19/19 12:13 PM
Top 6 OEM Passenger Tire Sizes in 2018
by SubLGT. 04/19/19 11:12 AM
CRC intake valve cleaner, safe to use?
by Backstache. 04/19/19 10:06 AM
'94 Grand Am Steering Column Pivot Pins
by benjamming. 04/19/19 10:02 AM
Why the need to replace suspension springs?
by WyrTwister. 04/19/19 09:47 AM
incorrect mileage on reciept
by 1978elcamino. 04/19/19 09:17 AM
Oregon PowerSharp for chainsaw
by Fitter30. 04/19/19 09:16 AM
new tire 4 years old
by 1978elcamino. 04/19/19 08:51 AM
carve200, Harteeco, fatafox, CurtC, LockCracker
67850 Registered Users
98 registered members (bbhero, 2015_PSD, Anduril, Astro14, Avelectro, BeerCan, 14 invisible), 2,208 guests, and 31 spiders.
Topics287,749
Posts4,933,785
Members67,850
Most Online2,967
Mar 10th, 2019
Recommendation for Supercharged LS w Heads + Cam #4696400
03/16/18 07:57 AM
03/16/18 07:57 AM
Toronto, Ontario, Canada
octhis Offline OP
octhis  Offline OP
Hi guys,
I have a 2011 CTS-V that i'll be installing ported heads and a cam in in the next couple of weeks. The car is about to hit 150,000 km's
I've been using Mobil 1 0w40 with Delco filter and it's been recommended from the vendor that I purchased the parts from for me to use Redline 5w30 especially after first fill after cam install since it has more Zinc.
What are your recommendations?
Re: Recommendation for Supercharged LS w Heads + Cam [Re: octhis] #4696403
03/16/18 08:00 AM
03/16/18 08:00 AM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
I'd stick with what you have. You aren't flat tappet, why do you need more ZDDP?
2016 Grand Cherokee SRT - Ravenol SSL 0w-40, FRAM Ultra
Re: Recommendation for Supercharged LS w Heads + Cam [Re: octhis] #4696413
03/16/18 08:16 AM
03/16/18 08:16 AM
Sunny Florida
SteveSRT8 Offline
SteveSRT8  Offline
Sunny Florida
Certainly nuttin' wrong with that M1 0w-40!
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: Recommendation for Supercharged LS w Heads + Cam [Re: OVERKILL] #4696482
03/16/18 09:10 AM
03/16/18 09:10 AM
octhis Offline OP
octhis  Offline OP
I guess because of the higher lift cam is why it was recommended
Re: Recommendation for Supercharged LS w Heads + Cam [Re: octhis] #4696500
03/16/18 09:33 AM
03/16/18 09:33 AM
SE British Columbia, Canada
Snagglefoot Online content
Snagglefoot  Online Content
Certainly the mechanic has a vested interest in this. The zinc and phosphate numbers are up in the 2500 ppm range which is about 3 times normal SN oil.
Quick question for the others, why was API trying to get the zinc and phosphate numbers down. Was it a catalytic converter issues? Redline is basically a racing oil and wasn't meant for the street. What's the downside for Octhis in using the Redline?
If you want the job done right......do it yourself.
Re: Recommendation for Supercharged LS w Heads + Cam [Re: octhis] #4696642
03/16/18 11:49 AM
03/16/18 11:49 AM
Displaced Texan in Mexico City
Gimpy1 Offline
Gimpy1  Offline
I have a gallon container of Redline 5W30 right in front of me. On the back label it says "NOT for break-in of engines-allow 2000 miles" So even Redline is telling you to wait. You might want to use a dedicated break in oil. Just my 2 pennies.
Re: Recommendation for Supercharged LS w Heads + Cam [Re: octhis] #4696697
03/16/18 12:54 PM
03/16/18 12:54 PM
San Rafael, CA
dogememe Online content
dogememe  Online Content
San Rafael, CA
Royal Purple HPS
2010 Ford Escape 2.5 ~95K Miles
Royal Purple 5W-30 ~ Wix 51348
1995 Chevy Silverado 5.7 ~277K Miles
Delo 10W-30 ~ ACDelco PF52
Re: Recommendation for Supercharged LS w Heads + Cam [Re: octhis] #4696702
03/16/18 01:01 PM
03/16/18 01:01 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Motor is broken in except for cam and valve components. Redline fine for track days and strip time. I'd say break-in of cam bits should be on high quality dino/semi like Brad Penn, Delo 400 15W-30 SD (severe duty), or VR-1 silver bottle. Enough ZDDP that if you get a momentary skid, it might recover... If there is a real cam issue, no oil will save you.
Dino's and semi's have a more widely varying oil structure. We're not worried about NOACK here. The oil will be out before aging is a concern. But having that molecular spread is good for new parts meeting each other for the first time smile
Re: Recommendation for Supercharged LS w Heads + Cam [Re: octhis] #4696714
03/16/18 01:13 PM
03/16/18 01:13 PM
Pennsylbammyvania
dailydriver Offline
dailydriver  Offline
Pennsylbammyvania
As well as most likely significantly higher spring seat pressures than factory.
Everyone keeps repeating the "IF it's not flat tappet, then it does NOT need more anti-wear/anti-friction additives" BITOG mantra, but there could STILL BE situations where they ARE called for. wink
(This is NOT one of the majority mundane, 'point A to point B' grocery-getter applications on here, being an aftermarket cam/heads/springs/etc. setup, PLUS I'm going to guess, MORE BOOST from a smaller pulley being installed, AND a fairly radical tune on top of all of that to help take advantage of it all!)
Octhis' might just be one of these scenarios, depending on just how radical that aftermarket valve train is in actuality.
The extra moly in the RL can only help that, even if the ZDDP is a slight overkill.
2016 Ford Fiesta ST 17K miles
Ravenol DXG 5W-30
Amsoil Ea15K51 filter
Ravenol MTF-2 in the IB6 transaxle
Re: Recommendation for Supercharged LS w Heads + Cam [Re: octhis] #4696890
03/16/18 04:59 PM
03/16/18 04:59 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
What are the specs on the cam? Generally roller cams are far less demanding (by virtue of being roller) in the AW department, even with faster ramps and higher lift.
M1 0w-40 is already higher in the AW department than the factory recommended SN 5w-30, so you've already stepped it up from stock AW levels.
Re: Recommendation for Supercharged LS w Heads + Cam [Re: OVERKILL] #4696970
03/16/18 06:39 PM
03/16/18 06:39 PM
octhis Offline OP
octhis  Offline OP
The cam has over .600 lift and dual spring kit.
Re: Recommendation for Supercharged LS w Heads + Cam [Re: dailydriver] #4696973
03/16/18 06:42 PM
03/16/18 06:42 PM
octhis Offline OP
octhis  Offline OP
You understand exactly what i'm up to.
The car right now has more boost and cooling mods. It's putting down about 570whp. I'll be increasing boost a bit further with the cam and heads along with shifting at a higher rpm than I do now.
Re: Recommendation for Supercharged LS w Heads + Cam [Re: Snagglefoot] #4696975
03/16/18 06:44 PM
03/16/18 06:44 PM
octhis Offline OP
octhis  Offline OP
I don't have converters anymore, but from what I remember, Zinc and phosphate is also bad for the o2's
Re: Recommendation for Supercharged LS w Heads + Cam [Re: octhis] #4697034
03/16/18 07:48 PM
03/16/18 07:48 PM
Whoops. Meant SPE, not API.
Re: Recommendation for Supercharged LS w Heads + Cam [Re: octhis] #4697407
03/17/18 09:33 AM
03/17/18 09:33 AM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Do you happen to know open pressure? Is this an Ed Curtis setup?
