air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
40 registered members (Ag76, carlprop, clinebarger, Bailes1992, Chris142, anndel, 1 invisible), 788 guests, and 61 spiders.
Topics286,440
Posts4,908,208
Members67,622
Most Online2,967
Mar 10th, 2019
ES 350 coolant flush didn't go as expected #4696051
03/15/18 07:48 PM
03/15/18 07:48 PM
TX, USA
HampsHump Offline OP
TX, USA
Today I decided the flush my 2011 ES 350, 58K miles and replace it with fresh Asian red from Walmart. Here is what I did:
1. Drained the coolant by opening the valve under the radiator.
2. While draining I started the engine with heat on full blast till the radiator fan kicked in.
3. It was blowing cool air although the temp was set to 85/high.
3. It took a while but was able to drain the whole thing.
4. Flushed it with 2 gallons of distilled water using step 2
5. I started filling with fresh coolant- again using step 2. It took forever. At this point
I suspect air in the system. I located and unscrewed the bleed off valve just enough for air to escape.
6. I was able to fill it with just 1 gallon- the car requires 2.37 gallons.
7. I let it sit for a while and tried to refill with no luck. I could see fluid/air coming out of the bleed off valve.
Note: I heard an intermittent squeaking sound while i had the engine on filling with fresh coolant. The noise subsequently vanished
I took the car for a spin and the temp gauge was in its usual position- almost center. Everything looks normal, the AC heat was behaving accordingly.
What am I doing wrong? Is there something I am missing?
Thanks.
Re: ES 350 coolant flush didn't go as expected [Re: HampsHump] #4696063
03/15/18 08:00 PM
03/15/18 08:00 PM
Oshawa, Ontario Canada
JC1 Offline
JC1  Offline
You probably should have removed the thermostat which would have made the draining easier.
Not sure where your thermostat is located. Did you get the full capacity added after the initial drain and fill?
2015 Grand Caravan SXT Plus 5w-20 Valvoline SynPower/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: ES 350 coolant flush didn't go as expected [Re: JC1] #4696075
03/15/18 08:21 PM
03/15/18 08:21 PM
TX, USA
TX, USA
Don't know where the thermostat is as well. Does anybody know? A schematic or drawing would help.
Did not get the full capacity added.
Re: ES 350 coolant flush didn't go as expected [Re: HampsHump] #4696092
03/15/18 08:42 PM
03/15/18 08:42 PM
Where the wind comes sweepin'
Reddy45 Online shocked
Reddy45  Online Shocked
You can follow the radiator hoses to find the thermostat. More often than not the thermostat is where the upper radiator hose meets the engine block. The lower radiator hose typically feeds the water pump since gravity works in our favor.
A trick for bleeding the air from a coolant system is to jack the car up so that the overflow tank is the highest point in the system. Once it is jacked up you can lightly rev the engine to spin the water pump to push the bubble out.
Re: ES 350 coolant flush didn't go as expected [Re: HampsHump] #4696102
03/15/18 08:45 PM
03/15/18 08:45 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Some engines do best when vacuum filled, this sounds like one of them.
Edit: This one will do a good job and is good quality.
https://www.ecstuning.com/b-schwaben-parts/coolant-refill-air-purge-tool/003466sch01/
Re: ES 350 coolant flush didn't go as expected [Re: HampsHump] #4696135
03/15/18 09:18 PM
03/15/18 09:18 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Thanks.
Iím not sure why you started your engine while draining your radiator. Never heard of that. Fill me in.
If you want the job done right......do it yourself.
Re: ES 350 coolant flush didn't go as expected [Re: Snagglefoot] #4696150
03/15/18 09:30 PM
03/15/18 09:30 PM
midwest
JamesBond Offline
JamesBond  Offline
midwest
Yeah I've never heard of draining or filling with the engine running, this does not sound like a good idea to me. Was the coolant that you put in a pre-mix? It's difficult to get all the coolant out through the radiator drain so there was probably some water left in the engine.
Re: ES 350 coolant flush didn't go as expected [Re: JamesBond] #4696232
03/15/18 11:46 PM
03/15/18 11:46 PM
Albany, NY
ford46guy Offline
ford46guy  Offline
Albany, NY
Sure don't sound good for the WP seal.
95 Tbird V8 240K PP SYNTH ULTRA 5W30
98 MGM 160K M1 HM 5W20
96 Explorer EB V6 159K PP SYNTH HM 5W30
95 Conti 155K MC 5W20
11 GS350 90K PP HM 5W30
Re: ES 350 coolant flush didn't go as expected [Re: HampsHump] #4696237
03/15/18 11:50 PM
03/15/18 11:50 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
T
So when you say it didn't go as expected, you mean you didn't succeed in wrecking your engine, as would be expected by draining it when running?
Can't win them all. Sometimes they are harder to kill than you'd think.
For example, my Lada suffered total coolant loss due to a water pump failure (my fault) but apparently survived my gf limping it off the motorway and parking it up, completely undamaged.
Assuming you dodged that bullet, you then "took it for a spin" knowing it was more than half empty, and apparently you dodged that bullet too.
Have you considered taking up Russian Roulette on a professional basis, Deer Hunter stylee?
You've apparently got air in it. You'll have to try and "burp" it out by squeezing the lower hose suddenly (or do a vacuum fill, as suggested, but I dunno about them). You might try the funnel in the radiator cap trick, but don't run it for very long more than half empty and don't go for any blasts down the freeway, unless you're still feeling lucky.
I THINK I had stubborn air bubbles in my car, some of which I got out with the funnel trick, but some remained, making me think I had a bad head gasket.
Or I had a bad head gasket, but it seems to have got better so it was probably bubbles.
EDIT : You get big syringe-style things here that are designed for unblocking drains. I might try one of those as a "burper" next time, though there is probably something better built for the job available in the US.
Re: ES 350 coolant flush didn't go as expected [Re: HampsHump] #4696252
03/16/18 12:18 AM
03/16/18 12:18 AM
CA
The Critic Offline
The Critic  Offline
CA
http://carspecmn.com/toyota-and-lexus-3-5l-v6-2gr-fe-coolant-bleeding-trick/
I usually vacuum fill these, but there is a bleed screw.
Donít mess with the t-stat, it is a pain to reach on these cars. I replace the t-start when I sell a WP.
Not sure why you are replacing the coolant. I never recommend coolant before 100k, never seen the benefit of early coolant changes on the newer Asian products with blue or pink coolant.
2011 Toyota Prius 1.8L - 185K - SuperTech Dexos Full Syn 0W-20
2007 Honda Accord 2.4 - 135K - Mobil 1 EP HM 5W-30
Re: ES 350 coolant flush didn't go as expected [Re: HampsHump] #4696308
03/16/18 04:47 AM
03/16/18 04:47 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
After owning several Toyota/Lexus vehicles, I never flushed the cooling systems. I ONLY drain & refilled the cooling system with either Toyota RED or PGL. I have also read and understood that Toyota doesn't recommend full flushing as it MAY trap air.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: ES 350 coolant flush didn't go as expected [Re: HampsHump] #4696511
03/16/18 09:40 AM
03/16/18 09:40 AM
Texas
JustinH Offline
JustinH  Offline
Texas
I did a coolant change on a matrix at 100k miles, and it took like 90 minutes of idling with the radiator cap off to get all the air out of the system.
I would not mess with another toyota unless I had an air powered bleed tool.
You drained the coolant with the engine running? Wowzers, no worries about killing the engine?
'11 Hyundai Sonata GLS
'11 Scion XB
Re: ES 350 coolant flush didn't go as expected [Re: JustinH] #4696658
03/16/18 12:09 PM
03/16/18 12:09 PM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
The exact reason why Toyota/Lexus only requires a drain and refill of the radiator.
"Retired"
'15 Honda Civic LX
Re: ES 350 coolant flush didn't go as expected [Re: JustinH] #4696981
03/16/18 06:48 PM
03/16/18 06:48 PM
Trav Offline
Trav  Offline
That's bad all the way round, WP bearings and seals don't get cooled (that was probably the noise) cylinder heads get hot and the worst part is if the coolant temp sensor is in the radiator it never shows got even though the engine is hotter than a pistol.
Vacuum filling is the only real quick and easiest way unless you want to start pulling hoses and housings trying to back feed the system.
Re: ES 350 coolant flush didn't go as expected [Re: HampsHump] #4697528
03/17/18 11:46 AM
03/17/18 11:46 AM
California
nthach Offline
nthach  Offline
California
If thereís two things Toyotas hate, itís running low on oil or coolant even for a few minutes. While I never had a problem with a Sienna and LS400 filling the cooling system via the factory-provided fill point, a vacuum filler like an AirLift is recommended as Trav says.
I have one for the parentís old Nissan but itís a invaluable tool for a Prius where itís imperative to have no air in the cooling loops or you risk expensive repairs.
