Semi Synth Gear Oil Seperation?
by J_ODIE. 04/18/19 04:26 AM
Acura/Honda Oil Consumption
by artbuc. 04/18/19 04:15 AM
xW-HTHS grade selection
by OilUzer. 04/18/19 03:28 AM
Oil color different cool versus hot?
by FordCapriDriver. 04/18/19 02:56 AM
Oil Choices
by tiger862. 04/18/19 01:12 AM
Honda/Acura HTO-06
by blackdiamond. 04/17/19 11:24 PM
Remote transmission filter newbie questions
by Zahndkile. 04/17/19 09:31 PM
Ford 3.0L transmission problem
by taztheman. 04/17/19 08:24 PM
PQIA Tax Day 2019 VOA's
by UG_Passat. 04/17/19 08:21 PM
bubbling paint/rust repair
by greenjp. 04/17/19 07:32 PM
2016 ford fusion lug nut size and torque spec?
by Corollaman. 04/17/19 07:32 PM
Better, Worse, or All The Same?
by 2015_PSD. 04/17/19 06:55 PM
Uber/Lyft Destroyed The Taxi Industry.
by Willclark. 04/17/19 06:39 PM
2012 Accord,Pennzoil Platinum High Mileage 10W30
by aquariuscsm. 04/17/19 06:26 PM
Kohler Command Twin 18HP - not charging
by 92saturnsl2. 04/17/19 06:26 PM
PARTS PLUS PH 2876 CUT OPEN
by 53' Stude. 04/17/19 06:18 PM
'13 Mazda5 oil change?
by pandus13. 04/17/19 05:02 PM
W_huisman, Arcoril, SpeedThrills, Lg9977, Slikk726
67838 Registered Users
39 registered members (billt460, A1O, Billbert, bbhero, Bailes1992, 6 invisible), 634 guests, and 25 spiders.
Topics287,672
Posts4,932,028
Members67,838
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Which CVT fluid is best for Nissan #4696014
03/15/18 07:11 PM
03/15/18 07:11 PM
Maryland
walterjay Offline OP
Maryland
I am ready to do a drain and refill of the cvt tranny fluid on my 2013 Nissan Rogue. I am trying to decide between Castrol and Valvoline. Which is the preferred fluid on this forum? I want to stay away from $20.00 a quart Nissan overpriced fluid.
Re: Which CVT fluid is best for Nissan [Re: walterjay] #4696018
03/15/18 07:14 PM
03/15/18 07:14 PM
Georgia
Charlie2015 Offline
Charlie2015  Offline
Georgia
I would recommend Valvoline CVT fluid if you want a good equivalent NS-2 CVT fluid.
1998 Honda Accord EX 2.3L Auto (Sold) 214k mi
2009 Scion tC Manual (Daily Driver) 165k mi
Re: Which CVT fluid is best for Nissan [Re: walterjay] #4696021
03/15/18 07:19 PM
03/15/18 07:19 PM
Los Gatos, CA
JeffKeryk Offline
JeffKeryk  Offline
Los Gatos, CA
I got a 2016 Altima with 70K miles from Hertz for a friend. I did 2 spill and fills with Valvoline Synthetic CVT fluid, about 4K miles apart. I'm pretty sure the trans was never serviced before. The 1st time is was black as heck; the service made a huge difference. The 2nd time the fluid was dark, but not nearly like the prior service. She runs real nice now. And this car calls for NS-3; I am not sure if your car needs NS-2 or NS-3. I believe either Castrol or Valvoline will be fine. I used Valvoline cuz it was fairly cheap on Amazon. Good luck.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Which CVT fluid is best for Nissan [Re: walterjay] #4696041
03/15/18 07:38 PM
03/15/18 07:38 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
Check your owners manual for the CVT fluid requirement.
Read the label on the Valvoline CVT fluid. The last time I saw their label it only covered up until the NS-2 specification.
CVT fluids that should work and cover NS-1 through NS-3 are:
Castrol Transmax CVT Product Code 467204
https://www.amsoil.com/lit/databulletins/g3273.pdf
https://www.redlineoil.com/Content/files/tech/NON-SLIP_CVT_PROD_INFO.pdf
The only limitations we have are the ones we place upon ourselves.
Re: Which CVT fluid is best for Nissan [Re: walterjay] #4696065
03/15/18 08:03 PM
03/15/18 08:03 PM
USA
slacktide_bitog Offline
USA
Get Castrol CVT fluid from Amazon. It's $35 for a case of 6 smile
A few times a year, the parts stores have a sale on Castrol ATF for $5/qt. The deal does include their CVT fluid, but the sale isn't going on right now.
Valvoline is good too, but it does cost a bit more than Castrol. Some Walmarts are carrying Valvoline for about $7/qt, with the parts stores charging about $10/qt
Re: Which CVT fluid is best for Nissan [Re: walterjay] #4696066
03/15/18 08:03 PM
03/15/18 08:03 PM
Upper midwest
Mainia Offline
Mainia  Offline
Upper midwest
Redline would be my choice, hard to pick any other when it comes to transmission fluids.
Re: Which CVT fluid is best for Nissan [Re: walterjay] #4696072
03/15/18 08:15 PM
03/15/18 08:15 PM
North Texas
ARB1977 Offline
ARB1977  Offline
North Texas
What about Amsoil CVT?
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: Which CVT fluid is best for Nissan [Re: walterjay] #4696078
03/15/18 08:26 PM
03/15/18 08:26 PM
Watertown, New York
cronk Offline
cronk  Offline
Watertown, New York
Been running Amsoil CVT in the wife's Quest for the past year and am pleased with it's performance so far. Cost less than the oem stuff!
2008 Ford F350
2003 Chevy Cavalier
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
Re: Which CVT fluid is best for Nissan [Re: walterjay] #4696096
03/15/18 08:43 PM
03/15/18 08:43 PM
Maryland
Maryland
Thank you everyone for your response. Amsoil would be my first choice but I am on a budget. I have used Valvoline Max products for years with great results, but since this is a CVT I am living with a different animal. After comparing products, I am going to choose the Castrol for two reasons. It is a good price but also it covers NS-2 and 3 requirements. My car specs NS-2 but with the higher NS rating of Castrol over Valvoline I feel that it may give me a broader range of protection. I am sure that all of the other products listed are excellent choices, I think that the Castrol is my best bet considering all.
Thanks again to everyone for your input.
Re: Which CVT fluid is best for Nissan [Re: walterjay] #4696108
03/15/18 08:51 PM
03/15/18 08:51 PM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
Go to: Amaliestore.com I got CVT fluid for my friend's application (Mitsubishi) and it was perfect.
At 92K the fluid was the color of dark maple syrup. The pan drop and filter change changed half the fluid. The new filter was unnecessary.
Amaliestore ships free after a 39$ threshold is reached. Buy oil if need be.
Re: Which CVT fluid is best for Nissan [Re: walterjay] #4696176
03/15/18 10:09 PM
03/15/18 10:09 PM
Virginia
bbhero Online sick
bbhero  Online Sick
Virginia
$20 a qt... Is high. Bit for saving 4-6 bucks a qt on a $6000 dollar transmission is that good math?? I say no. OEM is best.
In my cars Manual it has in bold type to use NS-2 Nissan fluid. There is a reason for that I believe.
Having stated this.. my car has 220,220 miles on original CVT fluid. Runs great still..
The CVT fluid has a deterioration number that is 235,000. Which when this number is met it us time to change the fluid. Only dealer scanner can get that number.
I hope that whatever you do works good for your vehicle.
Nissan Altima 3.5 Coupe
Carquest Full synthetic HM 5w30 84356 Carquest blue
"Treat your family like your friends and treat your friends like your family."
Re: Which CVT fluid is best for Nissan [Re: bbhero] #4696204
03/15/18 10:44 PM
03/15/18 10:44 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
Would you mind enlightening us on this claim? ANd if you have it sampled and analyzed, we would sure like to see the TAN number.
You're lucky. Mine looked like well used diesel oil at 35k miles.
Re: Which CVT fluid is best for Nissan [Re: MolaKule] #4696210
03/15/18 10:53 PM
03/15/18 10:53 PM
Virginia
bbhero Online sick
bbhero  Online Sick
Virginia
Not a claim... It comes from an experienced Nissan mechanic with many years there... And I have read in a couple of different places where others have stated the exact same thing... Who knows what their onboard system set up is.... And what that number means and how much it is.... And when fluid is changed... The onboard system has to be reset back. Numbers of people have had their CVT analyzed. Numbers vary.. One person had a deterioration number of 66k at 60k miles. While another had one at 4900 at 47k miles..
And my CVT looks like motor oil with less than 1500 miles on it. Has of today.
Re: Which CVT fluid is best for Nissan [Re: walterjay] #4696216
03/15/18 11:11 PM
03/15/18 11:11 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
I was asking specifically, "What is this The CVT fluid deterioration number of 235,000?"
And, "One person had a deterioration number of 66k at 60k miles. While another had one at 4900 at 47k miles."
What are you referring to, and how were these "deterioration" numbers determined?
Re: Which CVT fluid is best for Nissan [Re: MolaKule] #4696222
03/15/18 11:25 PM
03/15/18 11:25 PM
Virginia
bbhero Online sick
bbhero  Online Sick
Virginia
By the dealership SCAN tool.... Yes. They have scan tool that analyzes the CVT fluid from the onboard ECM.
That deterioration number.... Is set in the computer. Once certain perameters are met by sensors in the transmission and that number is reached aka 235k... It's time to change that fluid out.
Look... This is all " space age" stuff to me as well..... In my owners manual it clearly mentions having... "CVT fluid analyzed" at 60k 75k 105k 120k miles.... That's what that means... The fluid analysis comes from the onboard ECM and provides that deterioration number. Strange stuff. But that really is what it is..
Page 1 of 3 1 2 3
