Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
42 registered members (carlprop, bbhero, Ag76, ArrestMeRedZ, Agnosto, 4 invisible), 912 guests, and 58 spiders.
Topics286,170
Posts4,903,517
Members67,572
Most Online2,967
Mar 10th, 2019
Kendall GT-1 Euro #4695779
03/15/18 03:12 PM
03/15/18 03:12 PM
Oregon
1JZ_E46 Offline OP
1JZ_E46  Offline OP
Oregon
Does anyone have any experience with Kendall GT-1 Euro? I have been using Castrol EDGE 0W-40 in my X5 with good results (and a [censored] of a value). However, I'd like to see if switching oils will result in less consumption (primarily through the valve stem seals). EDGE 0W-40 has a healthy slug of PAO, which has excellent properties compared to Group III basestock, however, it has a shrinking effect on seals. I'd like to see if a Group III-based oil (that still retains LL-01) reduces consumption.
I would probably go with the 5W-30. It is on the thick side with a 3.6 HTHS and a 12.2 KV100... It appears the 5W-40 just has more VII since it has the same cold properties as the 5W-30. It's under $6 a quart (still affordable for a 9 quart sump), it has all the same euro manufacturer approvals, and everyone seems to love Kendall's GF-5 oils around here.
Thoughts? Thanks guys!
2007 X5 4.8i: M1 HM 10W-30
2016 Countryman S: Castrol 0W-40
Re: Kendall GT-1 Euro [Re: 1JZ_E46] #4695853
03/15/18 04:16 PM
03/15/18 04:16 PM
Oregon
1JZ_E46 Offline OP
1JZ_E46  Offline OP
Oregon
One thing I just noticed, when you pop in the KV40 and KV100 viscosities of 5W-30 into a VI calculator, you only get a VI of 150. Much lower than the 164 advertised. I'm guessing there is a typo on the KV40 viscosity listed (since it is the same as 5W-40)... it should be around KV40 should be around 74 to get a VI of 164.
Re: Kendall GT-1 Euro [Re: 1JZ_E46] #4696634
03/16/18 11:43 AM
03/16/18 11:43 AM
Oregon
1JZ_E46 Offline OP
1JZ_E46  Offline OP
Oregon
Confirmed that TDS is wrong with rep at P66 today. KV40 and KV100 are 70.0 and 11.8.
Also, some other 5W-30 LL-01 options that are toooo spendy are Castrol EDGE 5W-30 A3/B4 ($7.60/qt) and Liqui-Moly Special Tec LL 5W-30 (~$5.80/qt). A fair amount more expensive than my $4.50/qt EDGE 0W-40.
