Anti-Counterfeiting packaging
by sloinker. 01/17/19 09:13 PM
Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Pennzoil Ultra Plat 5w30 1.4L T Chevy Cruze 10k
by SubieBlue. 01/17/19 08:03 PM
Coated rotors
by supton. 01/17/19 07:51 PM
Good samaritan
by JLTD. 01/17/19 07:15 PM
Doing suspension work. Need alignment?
by HawkeyeScott. 01/17/19 05:45 PM
100mg CBD Cannabis Gel
by Al. 01/17/19 05:36 PM
Electric Car "Green Test"
by redbone3. 01/17/19 05:06 PM
Want to try a uoa
by Dylan1303. 01/17/19 04:56 PM
Happy Birthday, Betty White!
by eljefino. 01/17/19 04:20 PM
Fram Ultra for Ecoboost 2.7
by Purpfox. 01/17/19 04:10 PM
Idle Speed / 1998 Olds 88
by Mark72. 01/17/19 03:28 PM
Heat blanket for your oil filter!
by MrWideTires. 01/17/19 03:24 PM
Proper oil viscosities.
by Bullwinkle007. 01/17/19 03:20 PM
44$ for 5 gals of home heating oil treatment!
by Audios. 01/17/19 03:05 PM
Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
PP 0W-20 vs PP HM 0W-20 - Difference in VI
by The Critic. 01/17/19 02:34 PM
Dickerson888, Frisky, polarisman340, jfradella, Bigyetti83
66964 Registered Users
113 registered members (209paulc, 2015_PSD, 40w8, 4WD, 2009Edge, 11 invisible), 1,614 guests, and 47 spiders.
Topics296,753
Posts4,958,231
Members66,964
Most Online2,577
Jan 14th, 2019
Anyone running a tune on the 1.4 turbo? #4695740
03/15/18 01:24 PM
03/15/18 01:24 PM
Northern Kentucky
901Memphis Offline OP
Northern Kentucky
https://www.trifectaperformance.com/foru...urbo-advantage/
I just happened to stumble across this while reading another thread about premium gas in the 1.4T and it looks intriguing to say the least... $300 ain't bad.
2012 Chevy Cruze LT 1.4T - 59k - Edge 0w30 SL + Mahle OX401D
2002 Buick Century 144k - Built 4T65e(Maxlife) - GTX 5w30 + Fram XG3980
Re: Anyone running a tune on the 1.4 turbo? [Re: 901Memphis] #4695743
03/15/18 01:25 PM
03/15/18 01:25 PM
Northern Kentucky
Northern Kentucky
TRIFECTA presents: Chevrolet Cruze 1.4T MY2011--2016 Cruze Limited Calibration (December 2015 Update) Specific power increases of up to +51 ft-lbs and +44 WHP peak to a completely stock Chevrolet Cruze 1.4T.
The TRIFECTA powertrain recalibration for the Chevrolet Cruze 1.4T blends class leading all-around performance with improved fuel efficiency.
For those vehicles with automatic transmissions: All TRIFECTA Powertrain Recalibrations include updated automatic transmission calibrations which provide smoother shifting, improved shift times, and improved shifting logic vs previous calibration revisions; updated featuresets include rolling anti-lag and 300 percent faster shifts than stock.
For those vehicles with manual transmissions: All TRIFECTA Powertrain Recalibrations offer "no lift shift", allowing the driver to shift the transmission at lightning quick speeds without losing turbocharger boost. The shift is executed as normally, with the clutch, but the accelerator is held to the floor to retain full boost.
With the current generation of TRIFECTA's flash loader solutions and the TRIFECTA Transparency featureset, when flashing your vehicle, the TRIFECTA flash loader does not increment the ECM write counter or increment entries in the flash history.
With the December 2015 update, TRIFECTA Driver Selectable Vehicle Modes, version 2 (DSVM II) is included. Select between SPORT and STOCK mode, on the fly with the cruise control arming switch. Cruise control system functionality is completely retained and unaffected by DSVM II.
In SPORT mode, the vehicle responds much more quickly to accelerator input. Automatic transmission shift patterns are optimized for maximum performance and responsiveness. During "everyday" driving manuevers, the vehicle feels very much like it did from the factory, but rolling into the pedal quickly reveals a vehicle that wants to GO. Attentive, but without being "twitchy", power delivery is linear and transmission shifts are purposeful. The vehicle produces maximum TRIFECTA power!
In STOCK mode, the vehicle behaves just like it did from the factory, under all driving conditions!
The Chevrolet Cruze 1.4T TRIFECTA powertrain recalibration delivers more than 130 horsepower per liter and more than 140 ft-lbs per liter powering a fuel efficient vehicle whose drivers are more inclined to use it while ensuring critical powertrain reliability. Enhancements made to the Chevrolet Cruze 1.4T Ecotec engine software to withstand the added stresses include:
Extended testing of more than 100,000 miles with 100 hrs + of wide open throttle testing
Powertrain calibration has been tested and validated for various environments, such as cold/heat, elevation, and variations in fuel quality
Octane Adaptive construct enables multi-phased timing tables: Five distinct timing tables replace the OE GM implementation of high/low octane tables
Multi-dimensional Airflow Coefficient tables, adds air pressure bias and knock history overlay for enhanced accuracy in boost scenarios
Virtualized torque prediction coefficients recalculation model added
Airflow based commanded fuel ratio strategies added
Multi-stage knock sensor decay and recovery rate tables added
TRIFECTA ECP.MK2 (Hybrid Speed Density) support and constructs added
The TRIFECTA Advantage Calibration is meant for 100% stock vehicles. No individualizations or support for parts that do not function on factory calibration (if you have such modifications, be sure to check with us prior to placing order). No remote tuning.
Additional information:
-This powertrain calibration includes a TRIFECTA powertrain calibration file specific to your vehicle and includes a flash loader device
-Premium fuel is recommended for maximum power output, but not required
-Advertised gains are quoted as 'up to' and may be less for a vehicle operated at altitudes higher than near sea level.
-Powertrain calibrations currently exist for the US, CA, EU, RUS/CIS, MEC, and Asia areas, with more regions to follow.
Re: Anyone running a tune on the 1.4 turbo? [Re: 901Memphis] #4695796
03/15/18 02:23 PM
03/15/18 02:23 PM
VW Fanboy Island
maxdustington Offline
VW Fanboy Island
Whenever I think about a tune on a turbo car I always wonder how much the stock clutch or auto trans can take and for how long. 50 both ways? That seems like a lot for just a tune on a car that has 138hp/150tq. For $300 that is a no brainer, but I would gauges to monitor EGT and boost.
03 Jetta AWP/09A 205k kms
Edge 0W40 + Mann 719/30
Re: Anyone running a tune on the 1.4 turbo? [Re: 901Memphis] #4695806
03/15/18 02:26 PM
03/15/18 02:26 PM
Northern Ontario, Canada
Danno Offline
Danno  Offline
Given the issues with piston cracking on the 1.4L, if it were my car, that's the last thing I would want to do is to tune it.
http://www.cruzetalk.com/forum/34-gen1-1...pistons-14.html
2016 Sorento SX V6 AWD
2015 KIA RIO SX
2010 Mazda 3 2.0L
2009 Venza V6 AWD
2013 Sonata 2.4L RIP in write-off crash
Re: Anyone running a tune on the 1.4 turbo? [Re: 901Memphis] #4695814
03/15/18 02:30 PM
03/15/18 02:30 PM
Blaine, MN
gberg Offline
gberg  Offline
Blaine, MN
It's entirely worth the money and really wakes up the car. I bought their BF deal they had for my Sonic 1.4T. It was 100 dollars off so I paid 298 for the Elite version. Huge increase in mid-range power. The cruise on/off button system works as advertised and the difference is very noticeable.
My biggest issue with it since I have an RS manual first gear is very short and cold/wet weather traction becomes a large problem even on brand new tires...
Re: Anyone running a tune on the 1.4 turbo? [Re: 901Memphis] #4695854
03/15/18 03:16 PM
03/15/18 03:16 PM
Pennsylbammyvania
dailydriver Offline
dailydriver  Offline
Pennsylbammyvania
I am REALLY curious/wondering just how they accomplished THIS^^^ above?!? ???
Maybe the GM ECMs are not as sensitively 'written' so as to pick this up, like the Ford ones are, and like the Ford techs are trained to check on as a matter of course with their 'mod detective' program? shrug
IF TRIFECTA was able to do this in a way which will even get around the FORD systems, Cobb, SCT, and Livernois had better take heed, and develop the same. wink drive
2016 Ford Fiesta ST 14K miles
Ravenol DXG 5W-30
Amsoil Ea15K51 filter
Ravenol MTF-2 in the IB6 transaxle
Re: Anyone running a tune on the 1.4 turbo? [Re: gberg] #4695859
03/15/18 03:18 PM
03/15/18 03:18 PM
Pennsylbammyvania
dailydriver Offline
dailydriver  Offline
Pennsylbammyvania
The Sonic RS manual was the only other new car I was considering when I was shopping for the ST. wink thumbsup
Ravenol DXG 5W-30
Re: Anyone running a tune on the 1.4 turbo? [Re: 901Memphis] #4695868
03/15/18 03:25 PM
03/15/18 03:25 PM
Central Virginia
Silverado12 Offline
Silverado12  Offline
Central Virginia
FWIW I had a Chevy Cruze and it does lack a little power during hard acceleration. However, I wouldn't tune it as these engines seem to be relatively fragile when beat on. They hold up really well if left alone, though. Mine was 100% trouble free and I bought it as a used rental so God knows how it was driven before I got it.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: Anyone running a tune on the 1.4 turbo? [Re: 901Memphis] #4695882
03/15/18 03:47 PM
03/15/18 03:47 PM
Northern Kentucky
Northern Kentucky
I have a 4 year power train warranty I bought through the dealer, I'm guessing that a tune would void it huh?
Re: Anyone running a tune on the 1.4 turbo? [Re: 901Memphis] #4695907
03/15/18 04:19 PM
03/15/18 04:19 PM
New England
gathermewool Offline
New England
Unless there are literally 100's of 1.4T owners who have run this for 100k+ miles without issue, I wouldn't flash it unless I was able to monitor and log the affects:
Fuel trims, knock values, boost, turbo dynamics, AFR, etc.
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter (64,774 miles)
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Edge 0W-20 + FU filter (40,803 miles)
Re: Anyone running a tune on the 1.4 turbo? [Re: 901Memphis] #4695990
03/15/18 05:46 PM
03/15/18 05:46 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
The 1.4T isn't bulletproof, but on Cruzetalk.com you'll find all the R&D on this tune and others you care to read. Plenty of people have been running tunes for plenty of miles.
The piston cracking was primarily due to defective parts in the 2011/2012 MY's - it's not an inherent design flaw.
I think the 1.4T has plenty of power to make the Cruze fun, but mine's a stick shift. Ride along with me on the backroads and I'll have you questioning my sanity. If you wanted something that'll smoke the tires off you shoulda sacraficed 5-10 MPG and 10 grand more.
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: Anyone running a tune on the 1.4 turbo? [Re: 901Memphis] #4695996
03/15/18 05:54 PM
03/15/18 05:54 PM
MN
oil_film_movies Offline
MN
How does a tune get by the emissions testing people in your county?
Re: Anyone running a tune on the 1.4 turbo? [Re: oil_film_movies] #4696012
03/15/18 06:09 PM
03/15/18 06:09 PM
Northern Kentucky
Northern Kentucky
What emissions testing?
Re: Anyone running a tune on the 1.4 turbo? [Re: oil_film_movies] #4696144
03/15/18 08:27 PM
03/15/18 08:27 PM
Pennsylbammyvania
dailydriver Offline
dailydriver  Offline
Pennsylbammyvania
Depending on the tuning system/device, one can pull out the aftermarket tune onto a hand held device (or laptop if that's the only choice), and re-install the saved factory tune, for the day of the OBD 2 plug-in test (for those of us who have that in our locales), and then re-install the aftermarket tune after passing.
The problem comes when a DEALER uses those aforementioned detected re-flash/reprogram 'counts' as evidence that the car was tuned or modded (or if there is a severely draconian state inspection system, like Cali's).
I have heard of people passing the OBD 2 state inspection plug-in even with an aftermarket tune still installed in the ECM, but not sure how radically different said tune was from the factory tune.
Ravenol DXG 5W-30
Re: Anyone running a tune on the 1.4 turbo? [Re: oil_film_movies] #4696147
03/15/18 08:28 PM
03/15/18 08:28 PM
New England
New England
Most emissions tests are OBD. A tune can change the ECM parameters and disable certain codes that might be triggered by mods. If there are no codes, it passes. OBD emissions tests are not sophisticated.
