4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
Is this a battery issue or starter issue or ?
by simple_gifts. 03/18/19 06:24 PM
f250 - Friction modifier needed... which brand
by NattyBoh. 03/18/19 05:35 PM
Michelin's New All-Weather Tire for HD Pickups
by SubLGT. 03/18/19 04:36 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
71 registered members (ad_infinitum, 4WD, 2010Civic, Agnosto, 6 invisible), 1,414 guests, and 65 spiders.
Topics286,042
Posts4,901,391
Members67,551
Most Online2,967
Mar 10th, 2019
2011 Sienna coolant change, drain and refill ? #4695573
03/15/18 11:35 AM
03/15/18 11:35 AM
New Jersey
mister_two Offline OP
New Jersey
Van has just over 90k miles, almost 8 years old, coolant has never been changed. Planning to change the coolant this weekend before a long trip to FL. Should I just drain and refill? I have 3 gallons of Pentofrost A4 ready in the garage along with a couple gallons of distilled water. Or should I drain and refill with distilled water and run the car to flush out the remaining coolant? I see Chrisfix videos on youtube and he flush the system with distilled water a couple of times before refilling with coolant. Is that really necessary?
2000 Accord SE 211k
2000 S2000 45k
2011 Sienna XLE 88k
Re: 2011 Sienna coolant change, drain and refill ? [Re: mister_two] #4695621
03/15/18 12:27 PM
03/15/18 12:27 PM
Twin Cities MN USA
Inspecktor Offline
Inspecktor  Offline
Twin Cities MN USA
Modern coolants don't degrade like the old formulas. If the coolant in the radiator looks clean, I would just drain and refill as long as the Pentofrost is compatible. If not, flush with distilled water and mix the new 60-40 and run it.
2001 Ranger 3.0 168,000 mi
2006 Dakota 4.7 156,000 mi
1986 GL1200A 73,500 mi
2001 Buick LeSabre Limited 292,000 mi
Re: 2011 Sienna coolant change, drain and refill ? [Re: mister_two] #4695670
03/15/18 01:15 PM
03/15/18 01:15 PM
San Antonio, TX
E150GT Offline
E150GT  Offline
San Antonio, TX
I did a drain and fill on my wifes yaris at 100K. The original coolant was a little darker but clean so I didnt feel like a distilled water flush was necessary. I did however use the same factory coolant that was in there. I might do a distilled flush if I was changing over coolant brands.
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 57k 10w30
2006 Buick Lucerne CXL 3.8 31k 5w30
Re: 2011 Sienna coolant change, drain and refill ? [Re: mister_two] #4695676
03/15/18 01:16 PM
03/15/18 01:16 PM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
Originally Posted By: mister_two
... I see Chrisfix videos on youtube and he flush the system with distilled water a couple of times before refilling with coolant. Is that really necessary?
I just depends on what you want to do and are comfortable with. Yes, doing a distilled flush series before using new AF will give you the longer/full recommended service interval.
The issue with that is, A4 like majority oem Asian AFs is a premix. Unless you plan on finding and using the block drain(s) you'll have a difficult time getting a 50% AF concentration. Depending on drain location(s) it can be a pain. Other way is to run the new A4 premix through the system with d&fs until you reach 50% concentration as tested by and AF tester/hydrometer. That is a wasteful process.
My advice, just do a radiator d&f with A4 premix and shorten up the service interval. Do it again in 2-3 years.
Re: 2011 Sienna coolant change, drain and refill ? [Re: mister_two] #4695688
03/15/18 01:26 PM
03/15/18 01:26 PM
California
nthach Offline
nthach  Offline
California
Just do a drain and fill unless you see flotsam draining out of the radiator. Japanese cooling systems typically run pretty clean if you stick to OEM or pHOAT coolants.
Re: 2011 Sienna coolant change, drain and refill ? [Re: mister_two] #4695697
03/15/18 01:35 PM
03/15/18 01:35 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
I have a method that I consider to be a poor boy flush. I drain the coolant from the rad. I close the drain valve (or in a newer car, put the lower rad hose back on). I fill the rad with distilled water (it's cheap). I then take it for a ride and turn the heater on until the engine is at operating temp and the heater is blowing hot. I go home, have a beer and let it cool off. I then drain the rad again. Now, if I feel like it, I dump in distilled water again and repeat. When I drain the rad for the third time it's pretty clear. I then put in the full strength coolant equal to about 60% of the system and top off with distilled water. I then take it for another ride to get rig of any air bubbles and touch up the tank with 50/50. I have on hand a few extra empty jugs to store the the coolant from the three times I drained the radiator. I dispose of the fluid at the local recycle place. I never bother with the block drains and I don't bother with a flush compound but I guess I could. Done for 5 years. My oldest car has 17 years on it, and has had 3 poor boy flushes like this. Still on the original radiator and water pump.
If you want the job done right......do it yourself.
Re: 2011 Sienna coolant change, drain and refill ? [Re: mister_two] #4695788
03/15/18 03:20 PM
03/15/18 03:20 PM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
If it's Toyota pink it's good for 150k. But I would do it anyways at 100k and I would not swap it out with something else. Toyota makes the best coolant on the market IMHO
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 162k ST HM 10w30
05 Malibu Classic 108k Unk
Re: 2011 Sienna coolant change, drain and refill ? [Re: mister_two] #4695792
03/15/18 03:21 PM
03/15/18 03:21 PM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
The answer is no it's not necessary because of the chemistry of the factory coolant.
Re: 2011 Sienna coolant change, drain and refill ? [Re: mister_two] #4695794
03/15/18 03:22 PM
03/15/18 03:22 PM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
For Toyota, you just need to do a drain and fill.
The Toyota coolant is silicate free.
  • 2017 Toyota Sienna
Re: 2011 Sienna coolant change, drain and refill ? [Re: mister_two] #4696435
03/16/18 08:33 AM
03/16/18 08:33 AM
McGregor TX
mrdctaylor Offline
mrdctaylor  Offline
McGregor TX
Drain/fill is all I've ever done with my 2002 Tacoma since new. I used to use red, now I use the pink. I've yet to touch the cooling system on my 2012 Highlander, but that's all I plan to do to it too.
02 Tacoma 3.4L, 225K, Magnatec 10W30
12 Highlander 3.5L, 104K, Napa Syn 0W20
17 Escape 2.0L, 37K, Hav ProDS 5W30
02 Trailblazer 4.2L, 186K, Edge HM 10W40
