4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
Is this a battery issue or starter issue or ?
by simple_gifts. 03/18/19 06:24 PM
f250 - Friction modifier needed... which brand
by NattyBoh. 03/18/19 05:35 PM
Michelin's New All-Weather Tire for HD Pickups
by SubLGT. 03/18/19 04:36 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
88 registered members (4WD, AlaskaMike, 2010Civic, AdditiveOCD, agpatel, 69Torino, 10 invisible), 1,579 guests, and 68 spiders.
Topics286,042
Posts4,901,379
Members67,551
Most Online2,967
Mar 10th, 2019
Change to Mobil 1 on older engine #4695556
03/15/18 11:21 AM
03/15/18 11:21 AM
33463
quick_16 Offline OP
quick_16  Offline OP
33463
My wife drove a entry level 2009 Toyota Camry until we gave it to our daughter and she wrecked it at 155,000 miles. I have always done the maintenance on all our cars. I swapped over to Mobil 1 at 90,000 miles and shortly after that the 4 cylinder eng started burning oil. It was using 2,qts over the 10,000 oil change interval. I think it was valve seals because it would puff out a blast on the daily cold start. Im convinced the oil swap caused this. I changed the oil sense new every 5000 before swapping to Mobil 1. I made the oil same swap on my Honda Fit and no issues.
I replaced the 09 Camry with a 2010 Camry that was almost identically and has 155,000 miles. It was a used car with minimal maintenance records. No clue what oil had been used, but it uses zero oil. Id like to put Mobil 1 in this one at the next change and move to a 10,000 mile change interval, but Im concerned what happened before may repeat.
Has anyone experienced this issue on the big Toyota 4 cylinder engines?
Re: Change to Mobil 1 on older engine [Re: quick_16] #4695559
03/15/18 11:24 AM
03/15/18 11:24 AM
Venezuela, South America
Emanuel Offline
Emanuel  Offline
2 qts over a 10k OCI is pretty good, I wouldnt be concerned
Re: Change to Mobil 1 on older engine [Re: quick_16] #4695580
03/15/18 11:41 AM
03/15/18 11:41 AM
US
JLTD Offline
JLTD  Offline
US
Did it burn any oil before the M1?
You didn't mention the grade/weight of oil used; with that many miles you might benefit from moving up, for example from 0w20 to a 5w30..
I use the overseas owner's manual to choose my oil.
Using AMSOIL
Hers: 2008 Jeep Liberty 138k, SS 5w30/Amsoil
His: 2015 4Runner 45k, OE 5w30/Wix
Re: Change to Mobil 1 on older engine [Re: quick_16] #4695581
03/15/18 11:41 AM
03/15/18 11:41 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
It could be doing some cleaning in the ring area, today oils have good cleaning abilities. Give it a few more OCI it may get better.
Re: Change to Mobil 1 on older engine [Re: quick_16] #4695591
03/15/18 11:48 AM
03/15/18 11:48 AM
The Northeast
mclasser Offline
mclasser  Offline
The Northeast
You could try M1 HM.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: Change to Mobil 1 on older engine [Re: quick_16] #4695664
03/15/18 01:11 PM
03/15/18 01:11 PM
texas
danez_yoda Offline
danez_yoda  Offline
texas
Try a different synthetic with fewer cleaners to start. The M1 might have cleaned some gunk that was pluggin a oil leak path.
You can also increase oil weight to the max your engine recommends.
My wifes sienna V6 with 10K mile burns less than 1/2 qt on M1 AFE 0w20. 2qts seems high.
Re: Change to Mobil 1 on older engine [Re: quick_16] #4695668
03/15/18 01:14 PM
03/15/18 01:14 PM
Phoenix, AZ
Nick1994 Online content
Nick1994  Online Content
Phoenix, AZ
A 2010 isn't an older engine.
I've got my Camry and Jeep on Mobil 1, no issues.
2015 Hyundai Sonata 2.4L 92k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: Change to Mobil 1 on older engine [Re: Trav] #4695700
03/15/18 01:40 PM
03/15/18 01:40 PM
US
JLTD Offline
JLTD  Offline
US
Good point I didn't remember to make. M1 does clean well and I switched an older vehicle (95k) over to synthetic and it leaked a little for about 3000 miles.
Using AMSOIL
Re: Change to Mobil 1 on older engine [Re: quick_16] #4695780
03/15/18 03:12 PM
03/15/18 03:12 PM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
Your opinion of old differs from mine. I have a 2006 Escalade with 160k on it and I don't consider it old. I think 2k+ anything has much better engine design with much tighter tolerances than the 1990s. That being said it still comes down to maintenance. If the engine was poorly maintained and is burning oil because the rings and valve seals are worn out running Mobil 1 will only make the consumption worse than it already is. If you have a well-maintained engine from the 2K era that doesn't burn any oil by all means Mobil 1 is the way to go. No need to choose high mileage oil just because of the miles. If you see any mild consumption initially running synthetic oil don't worry about it that's pretty normal. It should get better over time as you get a new glaze. You could also opt for a little bit thicker synthetic because of the flow. A 10 W 30 might help or even 0w 40. But I would just be patient with 5w 30 or whatever the manual calls for. See what happens over 2/3 or oil changes
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 162k ST HM 10w30
05 Malibu Classic 108k Unk
Re: Change to Mobil 1 on older engine [Re: quick_16] #4695803
03/15/18 03:26 PM
03/15/18 03:26 PM
Pennsylvania
bugeye Offline
bugeye  Offline
Pennsylvania
I switched to Mobil ! on a new to us Volvo 5 cylinder with 91000 miles. The car was serviced at a local iffy lube with the cheapest oil per receipts from the previous owner. Some cleaning as evidenced by the first few oil changes. Deposits in the oil filter and general crud when looking in the oil fill have cleaned up by the Mobil 1. Uses ~ 1 quart at oil change, 5000 miles. No leaks.
Re: Change to Mobil 1 on older engine [Re: quick_16] #4695905
03/15/18 05:16 PM
03/15/18 05:16 PM
San Rafael, CA
dogememe Offline
dogememe  Offline
San Rafael, CA
Heard too many stories of M1 causing oil consumption. Why not use Valvoline Maxlife Full Synthetic? Same price as M1 HM pretty much!
2010 Ford Escape 2.5 ~94K Miles: Royal Purple 5W-30 + Wix 51348
2008 Ford Crown Vic P71 4.6 ~167K Miles: AMSOIL SS 0W-30 + Wix 51372
1995 Chevy Silverado 5.7 ~277K Miles: Delo 10W-30 + ACDelco PF52
Re: Change to Mobil 1 on older engine [Re: dogememe] #4695919
03/15/18 05:32 PM
03/15/18 05:32 PM
1/2 hr N.E. of Detroit
Triple_Se7en Offline
My Colorado never used much oil UNTIL I introduced it to Valvoline Maxlife Full Synthetic. How ironic in-that I'm replacing the Valvoline with Mobil-1.
2019 Hyundai SantaFe 2.4 factory fill QS 5w20 / Factory OEM oil filter
04 Chev Colorado 3.5 QS / Valv syn 5w30 blend K&N filter
03 Chev Malibu 3.1 QS / Valv Syn 5w30 blend Fram EG filter
Re: Change to Mobil 1 on older engine [Re: Triple_Se7en] #4695926
03/15/18 05:42 PM
03/15/18 05:42 PM
KS
FordBroncoVWJeta Offline
KS
I love hearing these stories all day at work. "Different Motors like Different brands". You just got to find what your engine likes.
2017 Volkswagen Jetta 1.4T - 2015 Honda CRV 2.4 - 2012 Volkswagen Jetta 2.0 - 2007 Chevy Trailblazer 4.2 - 2001 Pontiac Sunfire 2.2
Re: Change to Mobil 1 on older engine [Re: dogememe] #4695948
03/15/18 06:01 PM
03/15/18 06:01 PM
Trav Offline
Trav  Offline
Why would you want to introduce seal swellers into the system unless you have a problem?
Re: Change to Mobil 1 on older engine [Re: JLTD] #4695992
03/15/18 06:51 PM
03/15/18 06:51 PM
33463
quick_16 Offline OP
quick_16  Offline OP
33463
No not a drop
