Castrol Magnatec $19.44 5QT
by Nickdfresh. 04/18/19 05:15 AM
Semi Synth Gear Oil Seperation?
by J_ODIE. 04/18/19 04:26 AM
Acura/Honda Oil Consumption
by artbuc. 04/18/19 04:15 AM
xW-HTHS grade selection
by OilUzer. 04/18/19 03:28 AM
Oil color different cool versus hot?
by FordCapriDriver. 04/18/19 02:56 AM
Oil Choices
by tiger862. 04/18/19 01:12 AM
Honda/Acura HTO-06
by blackdiamond. 04/17/19 11:24 PM
Remote transmission filter newbie questions
by Zahndkile. 04/17/19 09:31 PM
Ford 3.0L transmission problem
by taztheman. 04/17/19 08:24 PM
PQIA Tax Day 2019 VOA's
by UG_Passat. 04/17/19 08:21 PM
bubbling paint/rust repair
by greenjp. 04/17/19 07:32 PM
2016 ford fusion lug nut size and torque spec?
by Corollaman. 04/17/19 07:32 PM
Better, Worse, or All The Same?
by 2015_PSD. 04/17/19 06:55 PM
Uber/Lyft Destroyed The Taxi Industry.
by Willclark. 04/17/19 06:39 PM
2012 Accord,Pennzoil Platinum High Mileage 10W30
by aquariuscsm. 04/17/19 06:26 PM
Kohler Command Twin 18HP - not charging
by 92saturnsl2. 04/17/19 06:26 PM
PARTS PLUS PH 2876 CUT OPEN
by 53' Stude. 04/17/19 06:18 PM
W_huisman, Arcoril, SpeedThrills, Lg9977, Slikk726
67838 Registered Users
40 registered members (Bailes1992, billt460, A1O, Billbert, bbhero, 6 invisible), 643 guests, and 25 spiders.
Topics287,672
Posts4,932,028
Members67,838
Most Online2,967
Mar 10th, 2019
15 amp Chgr - Hrs to charge #4695487
03/15/18 10:03 AM
03/15/18 10:03 AM
Massachusetts
CarlGR Offline OP
CarlGR  Offline OP
Massachusetts
how long to charge 12 volt battery on 15 amp charger with 100 amp boost. unit is from the 70's and meter only has low/good/boost on screen. Currently screen is on line of low and good.
Carl
2013 Rav4 XLE
2017 Rogue Sport SV
M1 / Castrol Edge 0W-20
Re: 15 amp Chgr - Hrs to charge [Re: CarlGR] #4695506
03/15/18 10:26 AM
03/15/18 10:26 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
How many amps is the battery? If its a "normal" size car battery charge for an hour then test the battery repeat on the hour.
Without knowing what the charger is capable of, the size of the battery and its current state of charge its impossible to give an answer that's even close.
Re: 15 amp Chgr - Hrs to charge [Re: CarlGR] #4695516
03/15/18 10:32 AM
03/15/18 10:32 AM
Massachusetts
CarlGR Offline OP
CarlGR  Offline OP
Massachusetts
Battery is Voltage: 12
Format: BCI Group 24F
Lead Acid Type: Starting
Cold Cranking Amps: 725
charge state is unable to start vehicle without boost
Carl
2013 Rav4 XLE
2017 Rogue Sport SV
Re: 15 amp Chgr - Hrs to charge [Re: CarlGR] #4695523
03/15/18 10:40 AM
03/15/18 10:40 AM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
Assuming say, 80-90% charge is the same as "full" to the layperson, it's a matter of calculating the following:
(0.85 * Nameplate Ah)-(initial SOC * Nameplate Ah)/ 15 = how many hours you need to charge.
It's far more complex in reality. And, usually there is a current decay that makes it much longer to get to a full SOC.
But for "good enough" ballpark, that's sort of your start.
Issue is that most batteries don't provide nameplate Ah values.
For an old school charger like yours, Is not want to be topping the battery.
Id target running two-ish hours for a known low battery (unloaded voltage around 12-12.4v.
Reduce time before checking from there.
Re: 15 amp Chgr - Hrs to charge [Re: CarlGR] #4695526
03/15/18 10:44 AM
03/15/18 10:44 AM
MA
Wolf359 Offline
Wolf359  Offline
MA
Yeah, it depends on the battery. You can convert reserve power to amp hours. Typical batteries are anywhere from 40-80 amp hours. So at 15 amps, anywhere from about 2.5 hours to 6 hours at 15 amps if the battery is fully discharged, less if it's not.
Re: 15 amp Chgr - Hrs to charge [Re: CarlGR] #4695527
03/15/18 10:44 AM
03/15/18 10:44 AM
Great Lakes
Quattro Pete Offline
Great Lakes
Need to know Ah value.
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: 15 amp Chgr - Hrs to charge [Re: CarlGR] #4695530
03/15/18 10:46 AM
03/15/18 10:46 AM
Massachusetts
CarlGR Offline OP
CarlGR  Offline OP
Massachusetts
Thanks all. Appreciate help.
Carl
2013 Rav4 XLE
2017 Rogue Sport SV
Re: 15 amp Chgr - Hrs to charge [Re: CarlGR] #4695533
03/15/18 10:49 AM
03/15/18 10:49 AM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
Chargers are a bit better now than 40 years ago. Maybe ask for one for your birthday!. smile
If you want the job done right......do it yourself.
Re: 15 amp Chgr - Hrs to charge [Re: JHZR2] #4695640
03/15/18 12:42 PM
03/15/18 12:42 PM
Texas
440Magnum Offline
440Magnum  Offline
Texas
FWIW, if the battery label doesn't list its amp-hour rating but only gives "reserve capacity" in minutes, the amp-hour rating is approximately 0.416 times the reserve capacity. IOW, AH=RC/2.4
For example, if the battery lists a RC of 100 minutes, then its roughly a 42 amp-hour battery.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
Re: 15 amp Chgr - Hrs to charge [Re: CarlGR] #4695696
03/15/18 01:35 PM
03/15/18 01:35 PM
california
wrcsixeight Offline
wrcsixeight  Offline
california
A group 24 battery is generaly 75 to 85 amp hours.
I'd not necessarily believe a 15 amp charger is capable of 15 amps.
No voltmeter and no ammeter is like no speedometer and no mile markers or clock.
but in this case it is like how long does it take to go from a to b, not knowing where a or b or located, or the speed one will travel.
So, my answer is yes
LA 318 Roller Cam
Pennzoil Platinum 10w-30 HM
Fram ultra XG8A
Fram Ultra XG16 on remote transmission filter mount
Re: 15 amp Chgr - Hrs to charge [Re: Snagglefoot] #4695713
03/15/18 01:48 PM
03/15/18 01:48 PM
MN
tmorris1 Offline
tmorris1  Offline
MN
Not really for lead acid. Supplying current to a battery is pretty much the same now as 40 years ago.
Re: 15 amp Chgr - Hrs to charge [Re: CarlGR] #4695781
03/15/18 03:13 PM
03/15/18 03:13 PM
CA
CharlieBauer Offline
CA
A 15 amp smart charger would take about 8 hours to charge a dead 85Ah battery. 5 hours for bulk and the rest for absorption.
It ain't what you don't know that gets you into trouble. It's what you know for sure that ain't so.
- mistakenly attributed to Mark Twain
Re: 15 amp Chgr - Hrs to charge [Re: tmorris1] #4696020
03/15/18 07:18 PM
03/15/18 07:18 PM
Snagglefoot Offline
Snagglefoot  Offline
Smart chargers are worth the money. That 70ís charger belongs with the platform shoes. Not to be unkind. smile
Re: 15 amp Chgr - Hrs to charge [Re: Snagglefoot] #4696504
03/16/18 09:34 AM
03/16/18 09:34 AM
MN
tmorris1 Offline
tmorris1  Offline
MN
I agree they are worth it, but they are not anything magical. They do the same thing as the old ones except they are smarter on when to shut off. They don't really charge any better. My point was an old charger will probably just charge just as well as a new one, but you will have to babysit it more.
Re: 15 amp Chgr - Hrs to charge [Re: CarlGR] #4696605
03/16/18 11:18 AM
03/16/18 11:18 AM
Massachusetts
CarlGR Offline OP
CarlGR  Offline OP
Massachusetts
If I was to replace the circa 70's charger, what 15 amp auto charger (medium grade)with approx 50A starting ability would you look to buy. The schumacher sc1359A for $51.52 look good but I'm reading quite a bit bad info on that maker.
Carl
2013 Rav4 XLE
2017 Rogue Sport SV
