Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
New plants around the yard
by gregk24. 03/19/19 03:24 PM
New Nissan Titan XD w/5.6l oil choices
by josephp732. 03/19/19 03:20 PM
Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
88 registered members (01rangerxl, 2015_PSD, aaronc7, 69GTX, ABCarr, 8 invisible), 1,458 guests, and 59 spiders.
Topics286,092
Posts4,902,411
Members67,560
Most Online2,967
Mar 10th, 2019
What to do with that used coolant...stabilise wood #4695285
03/15/18 04:43 AM
03/15/18 04:43 AM
'Stralia
Shannow Online content OP
Shannow  Online Content OP
'Stralia
Had a gallon of used coolant that I disposed of thoughtfully.
Looking for home made wood preservatives for the posts on my carport, found the following
http://acbs-bslol.com/restoration/service-department/d97woodrot/
Quote:
Commercial Products sold as a treatment for dry wood to prevent further rot are most ineffective against established rot in wet wood. There are two inexpensive and commonly available materials which will kill rot in wood. and prevent its recurrence. First, there are the Borates (Borax, Boric acid mixtures,) which have demonstrated to prevent new wood from rotting and killing rot organisms and wood-destroying insects in infested wood. Second, there is ethylene glycol, most readily available as automotive antifreeze/coolant, For killing rot spores and wood-destroying organisms, nothing works better than ethylene-glycol antifreeze, unless it is antifreeze mixed with borates. Glycol is toxic to a broad spectrum of organisms, from staphylococcus bacteria to mammals.
http://forum.woodenboat.com/showthread.php?186402-Ethylene-glycol-(auto-antifreeze)-treated-wood-safey
Quote:
There is a simple demonstration of all of the above statements. Take a piece of hardwood and drill holes in it that are an easy sliding fit for hardwood dowels. I used a piece of one-inch oak about three inches wide and drilled 25/64" D. holes 7/8" deep in the edges; the holes were an easy fit for the 3/8" by 1 1/2" spiral-grooved maple dowels I had on hand. For each treatment tested, I used a medicine dropper to apply five drops of the material being tested to the rim of the hole so that the liquid ran down the wall of the hole. Here are the results of a test begun December 19, 1987.
Water: Within about 30 seconds, the dowel was bound tightly. After about 24 hr., it was easily slid out. Water swelled the dowel and the oak piece, but quickly dried out.
Glycol: After about 30 minutes, the dowel was tight. It still is after a month. Glycol antifreeze diffuses into the cell walls and swells the wood permanently.
Glycerol: The less hygroscopic, larger molecule, more viscous glycerol took about 8 hours to interact with the cell walls of the wood to make the dowel tight. It has stayed tight.
Re: What to do with that used coolant...stabilise wood [Re: Shannow] #4695410
03/15/18 08:50 AM
03/15/18 08:50 AM
Battle Creek, MI
SVTCobra Offline
SVTCobra  Offline
Battle Creek, MI
AVE on YouTube has an older video where he is replacing a handle on a hammer and demonstrates using antifreeze to permanently hold the handle in the metal end. That would reinforce your second quote.
Think twice, speak once.
Re: What to do with that used coolant...stabilise wood [Re: Shannow] #4695764
03/15/18 02:56 PM
03/15/18 02:56 PM
'Stralia
'Stralia
AVE is great...
Re: What to do with that used coolant...stabilise wood [Re: SVTCobra] #4697009
03/16/18 07:24 PM
03/16/18 07:24 PM
'Stralia
'Stralia
Re: What to do with that used coolant...stabilise wood [Re: Shannow] #4697249
03/17/18 01:47 AM
03/17/18 01:47 AM
'Stralia
'Stralia
Re: What to do with that used coolant...stabilise wood [Re: Shannow] #4788079
06/16/18 08:47 AM
06/16/18 08:47 AM
MD
ET16 Offline
ET16  Offline
MD
Very interesting!
