Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
33 registered members (carlprop, das_peikko, alcyon, clinebarger, csandste, Ag76), 715 guests, and 67 spiders.
Topics286,442
Posts4,908,224
Members67,622
Most Online2,967
Mar 10th, 2019
Anyone running a coolant filter on a gas engine #4695185
03/14/18 11:13 PM
03/14/18 11:13 PM
Waco, TX
Linctex Offline OP
Linctex  Offline OP
Waco, TX
Lots of diesel guys do....
Is Anyone running a coolant filter on a gasoline engine?
Re: Anyone running a coolant filter on a gas engine [Re: Linctex] #4695193
03/14/18 11:24 PM
03/14/18 11:24 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
I've never heard of such a thing. What needs to be filtered out of coolant?
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: Anyone running a coolant filter on a gas engine [Re: Linctex] #4695195
03/14/18 11:26 PM
03/14/18 11:26 PM
Virginia
mattwithcats Offline
Virginia
WIX Filters - 24019 Heavy Duty Filter Mounting Base, Pack of 1 https://www.amazon.com/dp/B000CSINYU/ref=cm_sw_r_cp_tai_6sfKAb5DG2G1K
Filter is 24070 for the large, 24069 for the small coolant filter
Stay away from the 24071-24075, they contain additives...
Also can be found at Napa...
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Anyone running a coolant filter on a gas engine [Re: Leo99] #4695227
03/15/18 12:54 AM
03/15/18 12:54 AM
Fort Lauderdale, FL
DoubleWasp Online content
DoubleWasp  Online Content
Fort Lauderdale, FL
Unless an engine was manufactured and maintained 100% correctly, there is a lot that might need to be filtered out of coolant.
In my case, rust flakes, stop leak flakes, and whatever the heck else I have seen that I can't identify.
My case was also one of a poorly maintained cooling system. Florida has a lot of vehicle owners who subscribe to the "you don't need antifreeze in Florida" mentality, not realizing they are inviting electrolytic corrosion.
I flushed all of the offending engines "until clear" many times, and the scum always came back.
Friend of mine had it so bad, that he could count of his heater core blocking after 6 months, even after doing CLR and citric acid flushes. Coolant filter saved him from ever having to do that again. We poked out the rubber "orifice" limiter, and ran it as a full flow filter leading into his heater core. The filter would plug about every 2 months instead, until it finally stopped after 4 filter changes.
Casting sand escaping from the casting after manufacture is another problem that can occur. Chrysler and Ford have had their own adventures with this. Lot of Jeep owners install coolant filters to prevent this from blocking their heater cores.
Some cars (Honda) get blocked cores for no good reason at all, and have TSBs advising CLR flush to fix this problem. Coolant filter stops that from ever happening.
Basically, a coolant filter is something for the trash to clog, rather than your heater core, if there is indeed trash in your system. Apparently, even though most vehicles will never need such a thing, no vehicle is automatically excluded from this, mostly due to casting sand issues.
Re: Anyone running a coolant filter on a gas engine [Re: Linctex] #4695253
03/15/18 02:29 AM
03/15/18 02:29 AM
San Antonio, TX
das_peikko Online content
das_peikko  Online Content
San Antonio, TX
I didn't know there was such a thing. I sure wish there was a way to catch the "debris" that gets stuck to the inside wall of the reservoir tank.
Re: Anyone running a coolant filter on a gas engine [Re: Linctex] #4695412
03/15/18 08:50 AM
03/15/18 08:50 AM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
If you have an older gas engine (or diesel) that had neglected green AF in it, a coolant filter can help catch all the silicate drop out that collects in the nooks & crannies of a cooling system, that can be difficult to completely remove without flushing numerous times. On a newer gas engine, unless coolant has been mixed (like Dex with something else), I don't think it would catch a lot.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Anyone running a coolant filter on a gas engine [Re: Linctex] #4695680
03/15/18 01:20 PM
03/15/18 01:20 PM
San Antonio, TX
E150GT Offline
E150GT  Offline
San Antonio, TX
Ive always wanted to do it in my truck but I never have.
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 57k 10w30
2006 Buick Lucerne CXL 3.8 31k 5w30
Re: Anyone running a coolant filter on a gas engine [Re: Linctex] #4695745
03/15/18 02:27 PM
03/15/18 02:27 PM
TN
MinamiKotaro Offline
TN
I've got one on the Saturd and the old van. The one on the van removed about a pound of "mud" in about a week. I'm not even exaggerating, the canister was nearly full. I'm no expert but it was probably good to get that stuff out.
1967 VW Beetle: Delo 15w40/ST4386
2004 Saturn Ion: Magnatec 5w30/DW5436
2014 Polaris Ranger 570: Delo 5-40/Wix 51356
Re: Anyone running a coolant filter on a gas engine [Re: Linctex] #4695867
03/15/18 04:23 PM
03/15/18 04:23 PM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
I ran one on my Gen Coupe 2L for a year. It didn't need it and I took it off. Got one for sale. smile
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Anyone running a coolant filter on a gas engine [Re: Linctex] #4696152
03/15/18 09:31 PM
03/15/18 09:31 PM
Waco, TX
Linctex Offline OP
Linctex  Offline OP
Waco, TX
EXACTLY.
I have washed mine out twice, and I keep thinking "where does all this scummy goo keep coming from?"
I have been given (I love free stuff!) and aluminum base (11/16" thread?) and a brand new Fram PR3909.
It DOES appear to have an additive "pill" inside the filter.... Is that a bad thing?
I use plain green coolant 50/50, and usually flush and fill every 3 years.
I always pull the reservoir and try to clean it out the best I can.
Dis you post that in a thread here a few months ago?
I seem to recall that - and I was SURPRISED to see THAT MUCH gunk!!!
Re: Anyone running a coolant filter on a gas engine [Re: Linctex] #4696174
03/15/18 10:07 PM
03/15/18 10:07 PM
Waco, TX
Linctex Offline OP
Linctex  Offline OP
Waco, TX
I have been reading a bit online.....
Apparently, a coolant filter with a Supplemental Coolant Additive (SCA) included inside is a BAD thing - - it can cause silicates to drop out of the coolant and make a nasty sludge (usually caught by the filter, though?)
I really don't know EXACTLY what coolant is in my engine (I know it is not G-05)....
It's just plain yellow bottle Prestone. I don't know if that compatible with the filter or not.
Re: Anyone running a coolant filter on a gas engine [Re: Linctex] #4696178
03/15/18 10:11 PM
03/15/18 10:11 PM
Waco, TX
Linctex Offline OP
Linctex  Offline OP
Waco, TX
https://www.aftermarketsuppliers.org/councils/FMC/filter-faqs/heavy-duty-coolant-filter
Q: What happens if the coolant system is overcharged with additives?
A: Over charging or over concentrating a coolant system with additives will result in the formation of solids. These solids will form deposits that drop out and clog passage ways in the system preventing proper heat transfer. These solids are also very abrasive and will permanently damage surfaces they come in contact with. If a coolant filter is in use, it will be quickly plugged up.
Q: Should I consider using coolant filters on gasoline engines?
A: Yes. The overall up time and usability of gasoline engines can be greatly increased by treating the coolant systems used with gasoline engines the same way diesel systems are.
Due to the total capacity of most gasoline engine coolant systems, the use of a liquid SCA and an additive free filter is recommended.
Re: Anyone running a coolant filter on a gas engine [Re: DoubleWasp] #4696297
03/16/18 04:06 AM
03/16/18 04:06 AM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
Yes, generally it's BITOG OCD, but when it something that comes in handy for a certain application, it definitely comes in handy.
Plain, simple Garak.
