Anti-Counterfeiting packaging
by sloinker. 01/17/19 09:13 PM
Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Pennzoil Ultra Plat 5w30 1.4L T Chevy Cruze 10k
by SubieBlue. 01/17/19 08:03 PM
Coated rotors
by supton. 01/17/19 07:51 PM
Good samaritan
by JLTD. 01/17/19 07:15 PM
Doing suspension work. Need alignment?
by HawkeyeScott. 01/17/19 05:45 PM
100mg CBD Cannabis Gel
by Al. 01/17/19 05:36 PM
Electric Car "Green Test"
by redbone3. 01/17/19 05:06 PM
Want to try a uoa
by Dylan1303. 01/17/19 04:56 PM
Happy Birthday, Betty White!
by eljefino. 01/17/19 04:20 PM
Fram Ultra for Ecoboost 2.7
by Purpfox. 01/17/19 04:10 PM
Idle Speed / 1998 Olds 88
by Mark72. 01/17/19 03:28 PM
Heat blanket for your oil filter!
by MrWideTires. 01/17/19 03:24 PM
Proper oil viscosities.
by Bullwinkle007. 01/17/19 03:20 PM
44$ for 5 gals of home heating oil treatment!
by Audios. 01/17/19 03:05 PM
Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
PP 0W-20 vs PP HM 0W-20 - Difference in VI
by The Critic. 01/17/19 02:34 PM
Dickerson888, Frisky, polarisman340, jfradella, Bigyetti83
66964 Registered Users
97 registered members (Astro14, ArrestMeRedZ, AdditiveOCD, 209paulc, 2015_PSD, 40w8, 7 invisible), 1,519 guests, and 35 spiders.
Topics296,753
Posts4,958,255
Members66,964
Most Online2,577
Jan 14th, 2019
2014 Ducati Monster 1200S - Motorex TopSpeed 10w40 #4695102
03/14/18 08:50 PM
03/14/18 08:50 PM
Tampa, FL
frankge Offline OP
frankge  Offline OP
Tampa, FL
My first UOA and post here. I bout this used with 3000 miles, changed oil to Motorex Top Speed 10w40 and then to Mobil1 MX 4T after 3200 miles. Looks like I can try 4500 for next OCI.
Re: 2014 Ducati Monster 1200S - Motorex TopSpeed 10w40 [Re: frankge] #4695139
03/14/18 09:25 PM
03/14/18 09:25 PM
Where the wind comes sweepin'
Reddy45 Offline
Reddy45  Offline
Thanks for sharing. It looks like the oil sheared to a 30 weight oil though (at least based on this https://www.bobistheoilguy.com/viscosity-charts/)
Re: 2014 Ducati Monster 1200S - Motorex TopSpeed 10w40 [Re: frankge] #4695197
03/14/18 10:28 PM
03/14/18 10:28 PM
SE British Columbia, Canada
Snagglefoot Offline
Snagglefoot  Offline
But hey, Blackstone said “ The slightly thin viscosity is harmless” banana
If you want the job done right......do it yourself.
Re: 2014 Ducati Monster 1200S - Motorex TopSpeed 10w40 [Re: frankge] #4695561
03/15/18 10:25 AM
03/15/18 10:25 AM
Tampa, FL
frankge Offline OP
frankge  Offline OP
Tampa, FL
I switched to Mobil1 which is supposed have a better based stock. TopSpeed is a group III and the oil looked pretty good when I changed it. Going to stretch it to 4500 this time. I use a K&N oil filter with neo magnets. I'm not worried about the shear, I wont run a 50wt even in Florida. People run heavy oils because the "if two aspirins is good 3 are better" syndrome. This is a water cooled bike and I do run it pretty hard at times, my previous monster was air-cooled, I ran 50wt in that.
Re: 2014 Ducati Monster 1200S - Motorex TopSpeed 10w40 [Re: frankge] #4697325
03/17/18 06:57 AM
03/17/18 06:57 AM
South Carolina
alarmguy Offline
alarmguy  Offline
South Carolina
Thanks for posting, pass on the exotic oils, think you will see way better results with the Mobile 1 you just chose, or any other regular oils like Valvoline or Castrol.
Looking forward to the next UOA.
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
Re: 2014 Ducati Monster 1200S - Motorex TopSpeed 10w40 [Re: frankge] #4724603
04/12/18 10:07 AM
04/12/18 10:07 AM
China
dole Offline
dole  Offline
China
this oil looks pounded hard, knocked down 30percent of viscosity.
Re: 2014 Ducati Monster 1200S - Motorex TopSpeed 10w40 [Re: frankge] #4729450
04/16/18 09:56 PM
04/16/18 09:56 PM
Colorado, USA
Bonz Offline
Bonz  Offline
Colorado, USA
I assume this Monster is a liquid cooled model? Not one of the older air cooled?
There are not many oils that stay in the grade in a shared sump engine especially a model like this with V twin torque pulses crunching the oil between gears in the transmission.
Re: 2014 Ducati Monster 1200S - Motorex TopSpeed 10w40 [Re: frankge] #4732503
04/19/18 07:39 PM
04/19/18 07:39 PM
Florida /Texas
Mackelroy Offline
Mackelroy  Offline
Florida /Texas
Tops speed is a groupIII, and you belive mobil1 is a group Iv?
One key note, Mobil1 mc oils, used to have a lot higher flash points years ago, the base oil aint the same.
As to your 50 weight comment, add 1 quart of 50 weight in your favorite 10w40 brands, and you'll have a better chance of holding 40 weight.
Re: 2014 Ducati Monster 1200S - Motorex TopSpeed 10w40 [Re: frankge] #4733445
04/20/18 06:29 PM
04/20/18 06:29 PM
China
dole Offline
dole  Offline
China
Looks OK, thanks.
Iron and Aluminium a bit high, I reckon its to do with the bike per se.
Re: 2014 Ducati Monster 1200S - Motorex TopSpeed 10w40 [Re: frankge] #4734000
04/21/18 09:13 AM
04/21/18 09:13 AM
Colorado, USA
Bonz Offline
Bonz  Offline
Colorado, USA
DOH!!! I see this is the liquid cooled Monster, my bad for asking that question when I should have been paying full attention.
Mobil 1 4T 10w40 had a huge dose of zinc/phosphorus (1750/1600 ppm) up until March 2017 when I noticed a change. It shows a significant drop in zinc/phosphorus for this oil (1200/1100 ppm). This continues to show in the most recent Feb 2018 update (link below).
Link: scroll to page 4. https://mobiloil.com/~/media/amer/us/pvl/files/pdfs/mobil-1-oil-product-specs-guide.pdf
M1 20w50 V-Twin continues to have the higher zinc/phosphorus content, however is a heavier wt than you say you want to run.
I am not sure how zinc and phosphorus are valued in a Ducati valvetrain using desmodromic direct actuation, however a heavier oil with higher zinc and phosphorus in my bikes in a warmer climate isn’t anything I would shy away from, IMO.
Re: 2014 Ducati Monster 1200S - Motorex TopSpeed 10w40 [Re: frankge] #4735593
04/22/18 06:57 PM
04/22/18 06:57 PM
pa
benjy Offline
benjy  Offline
pa
my friend + former ducati dealer + savy tech noted ducati radiators could be bigger for their power levels but in the interest of small + light they are not! he also noticed the change in Mobil I oils from years past when they WERE all PAO + prolly a bit of Ester, but like most Amsoil included the oils use cheaper group III base oils to compete + take advantage of the ruling allowing group III refined CRUDE oils advertised + sold as "synthetic"!!
Re: 2014 Ducati Monster 1200S - Motorex TopSpeed 10w40 [Re: frankge] #4749060
05/06/18 07:30 AM
05/06/18 07:30 AM
Tampa, FL
frankge Offline OP
frankge  Offline OP
Tampa, FL
I do not consider Mobil1 a group IV base, just a good oil that's recommended and not as expensive (necessary) as the boutique oils. Its not a money thing as I don't ride this like a commuter and would spend $15/qt if there was a significant advantage. I might consider mixing the 40 and 50 if the next test proves its necessary. I do run this pretty hard time to time but overall I'm a little older now and "less" of a punk on the bike wink
