Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
TPMS Units Honda
by Chester11. 03/21/19 01:58 PM
Another brake question
by supton. 03/21/19 01:54 PM
BOUGHT WRONG OIL FILTER
by IBelieveinlube. 03/21/19 01:47 PM
miscible ester, using is as oil additive ?
by pep808. 03/21/19 01:23 PM
LT Oil Temps
by StillLearning. 03/21/19 12:44 PM
What kind of lug nut is this?
by LeakySeals. 03/21/19 12:38 PM
Need help finding a riding mower with $1,500 budget
by MetalSlug. 03/21/19 11:55 AM
Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Got a busted crankshaft!
by Chris142. 03/21/19 11:18 AM
Bad Motorcraft Plug?
by tmorris1. 03/21/19 10:47 AM
SAE 20 non-detergent oil
by fleetwood62. 03/21/19 10:39 AM
PSF3 in older Kia?
by Jetsfan421. 03/21/19 09:48 AM
USB WiFi adapter recommendations?
by Quattro Pete. 03/21/19 09:44 AM
m1,ep and valvoline.
by avi1777. 03/21/19 09:39 AM
Caliper recommendation?
by supton. 03/21/19 09:08 AM
Honda st1300 LED light
by Zuraxus. 03/21/19 08:26 AM
Paperboy, Flinch, AlanGonzales, Jrealstreeter, DarkFrontier
67576 Registered Users
105 registered members (1WildPig, 2012AccentSE, 2K2AcuraTL, 69Torino, 1leater, aircooled, 10 invisible), 2,130 guests, and 172 spiders.
Topics286,196
Posts4,903,998
Members67,576
Most Online2,967
Mar 10th, 2019
Chevy 1.4L Turbo and Octane #4694355
03/14/18 09:13 AM
03/14/18 09:13 AM
Pennsylvania
beastykato Offline OP
Pennsylvania
My girlfriend has a Chevy Trax and it's a decent little car, but a little bit underpowered. It's also heavy so the mpg suffers a little bit because of the engine struggling to pull it along.
So, that's why I ask if this little turbo will see any benefit from a higher octane fuel? We plan to run a couple tanks of 89 just to see if there is any noticeable difference and if it makes any more power.
I know in vehicles like my Ridgeline, the V6 will indeed change it's fuel mapping to take advantage of higher octane and even change shift points, as was confirmed by various people/engineers on Ridgeline forums. That manual also states this, albeit with a little less detail.
So, if anyone is familiar with this engine or has credible links to show that higher octane benefits the 1.4l I'd definitely like to read/hear about it.
To be clear, I'm not starting an octane argument, I know that 87 octane technically has more energy and that it's not of lesser quality. I simply am curious whether this ECU and engine can take advantage of a higher octane.
Re: Chevy 1.4L Turbo and Octane [Re: beastykato] #4694358
03/14/18 09:21 AM
03/14/18 09:21 AM
New England
Virtus_Probi Online mad
Virtus_Probi  Online Mad
New England
With modern knock control systems, it's likely that most engines can benefit at least a little from higher octane and it might even be more likely for a turbo. I worked on the electronics for a closed-loop knock system to be used by one of the US Big 3 over 20 years ago and the intent was to keep the engine on the very edge of knocking, sometimes knocking so lightly that the driver could not even sense it.
I would guess that the systems used today are even better than the one I worked on, and I got to see it run in a car on a dyno and was amazed by how well it worked. The gain might be so tiny that you won't even notice it, but why not give it a try just to see what happens? I would recommend trying 91 or 93 first to see if you can feel a difference. 93 is recommended for my car and that is usually 50-60 cents per gallon more than regular where I live...my wife is a penny pincher and always has to comment on the cost delta whenever I fill up with her in the car.
2014 Forester XT, 95000 miles
Last Change;
M1 0W30 AFE d1G2
Tokyo Roki 15208AA170 filter
Re: Chevy 1.4L Turbo and Octane [Re: beastykato] #4694362
03/14/18 09:25 AM
03/14/18 09:25 AM
Canyon County Idaho
CT8 Online content
CT8  Online Content
Canyon County Idaho
Try 91 or 93 octane if your area has it. 89 is not a big enough step up to test for any benefits. Higher octane is your friend with higher compression / supercharged engines.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Chevy 1.4L Turbo and Octane [Re: CT8] #4694366
03/14/18 09:30 AM
03/14/18 09:30 AM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Just starting using some 89 and 93 Shell in the Matrix and what a difference. Runs much better. Read the owner's manual that states to use 87 or higher. In parentheses it says research 96 octane. So not a requirement but at it's age I think it helps. Esp for short trips where the extra detergents can sit on the parts. For long trips I'll fill up with 87. But for around town 87 or 93 now. The Camy will get the same higher octane. Every week put in $10 worth of high octane. Since it doesn't see a lot of miles each week. Sure beats filling it up completely with 93 octane. Kind of budgeting thing with the high octane and makes the added cost much more palatable.
Re: Chevy 1.4L Turbo and Octane [Re: beastykato] #4694377
03/14/18 09:43 AM
03/14/18 09:43 AM
SE British Columbia, Canada
Snagglefoot Online content
Snagglefoot  Online Content
Just out of curiosity. Can that motor accept E-85?
If you want the job done right......do it yourself.
Re: Chevy 1.4L Turbo and Octane [Re: beastykato] #4694385
03/14/18 09:49 AM
03/14/18 09:49 AM
NJ
DevilsRule Offline
DevilsRule  Offline
NJ
I have a Cruze with the 1.4T. Super unleaded(91-93 octane) will give you 10-14 more HP per GM engineers. My experience is noticeably more power and better throttle response.
Re: Chevy 1.4L Turbo and Octane [Re: beastykato] #4694397
03/14/18 09:54 AM
03/14/18 09:54 AM
Grand Rapids, MI
WishIhadatruck Offline
Grand Rapids, MI
I have a 2014 Cruze with the same 1.4T motor. Below freezing, it makes little difference. Once you get up in the 30's, it definitely runs better on 89 octane. By late spring I run 93 octane. Honestly, I don't know how they can even say it runs properly on 87 octane, it doesn't in warmer weather. If it is in the 80's or 90's it will actually retard the timing and bypass the turbo as you accelerate leaving you with little power. It starts out fine pulling into traffic then when I hit about 2000 rpm it feels like it is dying. 93 octane cures all of this.
As for fuel economy, I have found that if you just look at the computer in the car, you'll never see much of a difference. If you actually track gallons purchased per actual miles per tank and calculate it yourself, you will see a difference. The computer is reasonably accurate with 93 octane. If the weather is hot, my computer can say 42 mpg for the tank and I might only get 37 mpg by my calculations if I'm running 87 octane. With 93 octane in that scenario I would get at least 41 mpg calculated if the computer said 42.
In Michigan I run 87 Octane if below freezing constantly.
I run 89 Octane up to about 60 - 70 degrees and 93 octane above that.
You can get away with 89 all summer long, but it feels a little smoother with 93 octane.
1996 Buick Roadmaster Wagon
2014 Cruze Eco Manual
2003 2500 Suburban, 8.1L
Re: Chevy 1.4L Turbo and Octane [Re: Snagglefoot] #4694401
03/14/18 09:58 AM
03/14/18 09:58 AM
Pennsylvania
Pennsylvania
The manual for her car (2017 Trax) states "Do not use any fuel labeled E85 or FlexFuel. Do not use gasoline with ethanol levels greater than 15% by volume."
And thanks for the responses guys. Looks like we will be giving 91+ a try for a few tanks to see if we get any noticeable difference in power/mpg.
Re: Chevy 1.4L Turbo and Octane [Re: beastykato] #4694463
03/14/18 10:54 AM
03/14/18 10:54 AM
Michigan
MrHorspwer Offline
MrHorspwer  Offline
Michigan
it made a difference for Edmunds and their Sonic.
https://www.edmunds.com/chevrolet/cruze/...vs-premium.html
Re: Chevy 1.4L Turbo and Octane [Re: beastykato] #4694470
03/14/18 11:10 AM
03/14/18 11:10 AM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
That's the same engine as my Cruze has. Many owners claim premium is the only way to go - I've tried all grades: it runs noticeably worse on regular, but I've never been able to detect the difference between plus and premium.
Change the (synthetic) oil frequently, observe the other maint. points (plugs @ 60K, air filter @ 40K, etc.) and learn about the common failures of the engine (PCV, water pump, water outlet, etc.) and it should be good to you.
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: Chevy 1.4L Turbo and Octane [Re: beastykato] #4694471
03/14/18 11:11 AM
03/14/18 11:11 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
my 9:1 comp Nissan with PI needs a little 93 mixed in to make power and low end.
Never drove anything in the past decade that didn't benefit from a little mix in.
These engine are very high output/L Jeepers, My Rouge make same HP as my 4bbl 5.0 Mustang. If it was a 5 litre it would make 350 HP - so Yes IT NEEDs SOME HELP with better fuel.
Good luck finding Premium that isn't STALE though.
2019 VW Jetta S,6M OCI#0 1136mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: Chevy 1.4L Turbo and Octane [Re: beastykato] #4694587
03/14/18 12:57 PM
03/14/18 12:57 PM
Pennsylbammyvania
dailydriver Offline
dailydriver  Offline
Pennsylbammyvania
That's a shame, since my car's setup (also DI turbo, relatively high CR @ 10:1) has been proven to give a little more power even on the factory tune with some E85 (up to a 20% TOTAL content) mixed in with the 93 E10 (THANK YOU Ford O.A.R. system!! drive).
Sadly for me, the last E85 station within 50 miles one way from me closed down last summer. frown
2016 Ford Fiesta ST 14K miles
Ravenol DXG 5W-30
Amsoil Ea15K51 filter
Ravenol MTF-2 in the IB6 transaxle
Re: Chevy 1.4L Turbo and Octane [Re: beastykato] #4694595
03/14/18 01:02 PM
03/14/18 01:02 PM
Suomi
Bjornviken Offline
Bjornviken  Offline
Suomi
Use Shell 98 v-power
Re: Chevy 1.4L Turbo and Octane [Re: Bjornviken] #4694621
03/14/18 01:23 PM
03/14/18 01:23 PM
Pennsylbammyvania
dailydriver Offline
dailydriver  Offline
Pennsylbammyvania
It's only 93 max here (by OUR octane ratings system), and usually has up to 10% ethanol content in most areas.
But it IS what I use, exclusively in this car. wink
Ravenol DXG 5W-30
Re: Chevy 1.4L Turbo and Octane [Re: dailydriver] #4694635
03/14/18 01:50 PM
03/14/18 01:50 PM
New England
New England
I would try running a mixed tank of 93/E85 if the latter was available anywhere around me...I did find something on the web a while ago about it being available at some portside facility in Charlestown MA, but I doubt that was retail.
I did try running about 1/3 of a tank of 100 octane racing gas (unleaded) with the rest 93 and the butt dyno reported no change...same thing with 94 octane in Canada (car actually ran somewhat poorly for that tank).
BTW, FWIW, I read somewhere that the 3.5l V6 in the mid-2000s Lexus RX350 was advertised as 270HP while nearly the same engine in the RAV4 was advertised as 268HP because premium was recommended for the former and regular gas for the latter. A real difference for that engine (2GR-FE, PFI then but I think updated to DI and about 300HP now), but a quite small one.
Last Change;
M1 0W30 AFE d1G2
