Anti-Counterfeiting packaging
by sloinker. 01/17/19 09:13 PM
Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Pennzoil Ultra Plat 5w30 1.4L T Chevy Cruze 10k
by SubieBlue. 01/17/19 08:03 PM
Coated rotors
by supton. 01/17/19 07:51 PM
Good samaritan
by JLTD. 01/17/19 07:15 PM
Doing suspension work. Need alignment?
by HawkeyeScott. 01/17/19 05:45 PM
100mg CBD Cannabis Gel
by Al. 01/17/19 05:36 PM
Electric Car "Green Test"
by redbone3. 01/17/19 05:06 PM
Want to try a uoa
by Dylan1303. 01/17/19 04:56 PM
Happy Birthday, Betty White!
by eljefino. 01/17/19 04:20 PM
Fram Ultra for Ecoboost 2.7
by Purpfox. 01/17/19 04:10 PM
Idle Speed / 1998 Olds 88
by Mark72. 01/17/19 03:28 PM
Heat blanket for your oil filter!
by MrWideTires. 01/17/19 03:24 PM
Proper oil viscosities.
by Bullwinkle007. 01/17/19 03:20 PM
44$ for 5 gals of home heating oil treatment!
by Audios. 01/17/19 03:05 PM
Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
PP 0W-20 vs PP HM 0W-20 - Difference in VI
by The Critic. 01/17/19 02:34 PM
Dickerson888, Frisky, polarisman340, jfradella, Bigyetti83
66964 Registered Users
120 registered members (209paulc, 2015_PSD, 40w8, 4WD, 2009Edge, 12 invisible), 1,572 guests, and 39 spiders.
Topics296,753
Posts4,958,249
Members66,964
Most Online2,577
Jan 14th, 2019
w116 300sd Mercedes oil recommendation #4694354
03/14/18 08:11 AM
03/14/18 08:11 AM
CA
Gito Online content OP
Gito  Online Content OP
CA
It's time to buy oil for my 1979 300sd (w116) with approximately 120k miles.
I've been hearing that Chevron Delo 400 changed their formula awhile back.
I'm not sure exactly when they changed the formula but now that I'm aware about this, I would like to get some updates.
The other day I saw that Orielly had Chevron Delo 400LE on sale for 13.99. Not bad, but should I still be using Delo.
I have read on other forums that Chevron Delo 400 was the good stuff but no longer available. Note: 400 without the LE.
I want to make sure that I'm using the right motor oil.
Any advice is greatly appreciated
Re: w116 300sd Mercedes oil recommendation [Re: Gito] #4694399
03/14/18 08:57 AM
03/14/18 08:57 AM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Any 15w40 will do. My friend that loves those cars and is on the Benz forums likes Walmart super tech.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: w116 300sd Mercedes oil recommendation [Re: Gito] #4694535
03/14/18 11:11 AM
03/14/18 11:11 AM
California
nthach Offline
nthach  Offline
California
The older Mercedes diesels/gassers do fine on 15W-40.
Re: w116 300sd Mercedes oil recommendation [Re: Gito] #4694577
03/14/18 11:44 AM
03/14/18 11:44 AM
CA
CA
So 15-40 Supertech is fine? How is that compared to 15-40 Chevron Delo 400LE? Can I use Shell Rotella T-6 Syn?
Re: w116 300sd Mercedes oil recommendation [Re: Gito] #4694596
03/14/18 12:02 PM
03/14/18 12:02 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
A lot of us that are hardcore into MB diesels use 5w-40...
I run Schaeffer's 5w-40 in one, Rotella 5w-40 in the other.
I run Schaeffers because I had bought it in bulk long ago, and it gets two year OCIs. The other that gets more use gets Rotella.
15w-40 will run just fine in these engines. 5w- just cranks faster/easier in all conditions. Given the price point that 5w-40 has gotten to, I see no reason to not use it...
Re: w116 300sd Mercedes oil recommendation [Re: Gito] #4694629
03/14/18 12:37 PM
03/14/18 12:37 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
While 15w40 might be fine time has moved on, today it is rarely used in Germany anymore for these engines now its mostly 5w40 Mobil recommends a 5w50. These are Euro oils and usually have a higher zinc content.
I suspect this engine may need a zinc additive with newer US oils as that seems to be the most reduced component. Some will say it doesn't have stiff valve springs as an automatic disclaimer for low zinc content but personally I don't buy it.
2cents
Re: w116 300sd Mercedes oil recommendation [Re: Gito] #4694672
03/14/18 01:46 PM
03/14/18 01:46 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
If it's overhead cam, it does not need more than 800 PPM ZDDP. And Chevron now claims 50% less wear with their new oil. That could be grounds for class action law suites if they fail to live up to it ...
They have replaced ZDDP with newer organic chemistry that does not show up on typical UOA's ... I'll bet their new formulations have been severely lab and field tested and they are on top of it smile
Re: w116 300sd Mercedes oil recommendation [Re: Gito] #4694687
03/14/18 02:12 PM
03/14/18 02:12 PM
Gardnerville, Nv
390pi Offline
390pi  Offline
Gardnerville, Nv
Yes, 5w40.
I remember reading a technical article from George Murphy, who was MBZ technical editor IIRC, about timing chain and guide wear with synthetic and non-synthetic oil and what he had observed in engine teardowns of OM616 and OM617 MBZ motors.
He observed that synthetic oil motors had less chain and guide wear.
I still have an '82 240D and run syn 5W40.
2016 Ram 1500 4x4 3.6
2015 Jeep Grand Cherokee AWD 3.0 Diesel
2013 Ford F250 4X4 6.2
2000 Chev Suburban 4X4 2500 6.0
2005 Focus ZX5 track car
Re: w116 300sd Mercedes oil recommendation [Re: BrocLuno] #4694792
03/14/18 04:07 PM
03/14/18 04:07 PM
Trav Offline
Trav  Offline
Cam lobe over bucket or shim I agree but as soon as non roller rocket arms or flat tappets come into the equation having extra zinc in the mix at least 1100 ppm seems to keep them in the best condition. To each their own, you want believe different that's fine too.
https://www.hemmings.com/blog/2012/10/18/tech-101-zinc-in-oil-and-its-effects-on-older-engines/
Re: w116 300sd Mercedes oil recommendation [Re: JHZR2] #4696405
03/16/18 07:01 AM
03/16/18 07:01 AM
CA
CA
Where is Schaeffer's 5w-40 sold?
In store or online?
Re: w116 300sd Mercedes oil recommendation [Re: Gito] #4697023
03/16/18 06:36 PM
03/16/18 06:36 PM
CA
CA
Is Amsoil Heavy-Duty Synthetic Diesel Oil 5W-40 appropriate for my OM617.950?
