The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
40 registered members (berniedd, 555, aleneros, carlprop, Brad_C, Chesterr, 2 invisible), 592 guests, and 66 spiders.
Topics286,097
Posts4,902,480
Members67,560
Most Online2,967
Mar 10th, 2019
Ford evap leak troubles #4693969
03/13/18 09:05 PM
03/13/18 09:05 PM
West Michigan
buck91 Offline OP
buck91  Offline OP
West Michigan
Trying to diagnose a P0457 code on the wife's 2014 Explorer 3.5L GTDI (ecoboost). Started as a warning on the instrument panel to check the fuel cap, which on this car is quite the joke since it has Ford's capless fuel filler. After a while the CEL popped and Forscan Lite shows a P0457 evap leak, likely the fuel filler cap. If I clear the CEL it stays off for a while but always comes back. Tried a little shotgun approach and replaced the charcoal canister vent solenoid; note the purge valve seems to work just fine. Tried the manual filler cleaning procedure which is much touted on youtube with no changes (I was very thorough). No odors or visible leaking of fuel. Some light conversation with the dealer and they swear up and down it can't be the fuel filler neck (well not CAN'T but 99.9% it isn't). Without a smoke machine I am kind of stuck, at this point my next step is to pop the right rear wheelwell out and visualize the filler neck and the vapor hose for obvious signs of damage or leaks. Might have to make a DIY smoke machine, though. I do have a Halloween fog machine would that work? I have some PEX tubing which fits the nozzle, but it seems like that fog likes to condense pretty rapidly.
Below are a couple shots from Forscan. Any thoughts?
P0457:
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Ford evap leak troubles [Re: buck91] #4694003
03/13/18 09:27 PM
03/13/18 09:27 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Is there a way you can plug in or put a cap over the filler as a test? I suspect the filler just going by the size of the leak.
Re: Ford evap leak troubles [Re: buck91] #4694054
03/13/18 10:14 PM
03/13/18 10:14 PM
West Michigan
buck91 Offline OP
buck91  Offline OP
West Michigan
Well, not really. I could disconnect from the vent solenoid. Actually, I did some more digging on my obd2 adaptor and Forscan and I believe I can run the adaptor with my laptop which means I should be able to utilize some of the more advanced features in forscan to check and see a couple things. Its also possible the purge solenoid (which, incidentally, I cannot find ANY part numbers for) would be stuck closed. If I can manually command it to open with the forscan then I could check for vacuum there... Otherwise, I'll have to check for vacuum at the vent solenoid connection. Maybe make a DIY smoker for the tank.
2011 F150 4x4 5.0L
Re: Ford evap leak troubles [Re: buck91] #4694087
03/13/18 10:42 PM
03/13/18 10:42 PM
PR CA, USA
2strokeNorthstar Offline
PR CA, USA
Get a cheap cigar and a piece of hose. Fire it up and blow the smoke in. Works really well. Taste terrible but so does spending $150 on a smoke test. Diagnosed my BMW better than the mechanic. I had to show him where I saw the leak and he had to crank up the pressure to replicate / find it. He thought it was fine with the initial test.
My 01 F150 the EVAP test never completes. Even after years and 1000's of miles. Never fails just never completes. Don't know why.
2001 F150 5.4L 140k miles
2013 Nissan Juke Nismo 80k
2000 Honda S2000 183k
1998 BMW 328i 170k
Re: Ford evap leak troubles [Re: buck91] #4694118
03/13/18 11:33 PM
03/13/18 11:33 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
Filler necks and purge valves are really common on these.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Ford evap leak troubles [Re: buck91] #4694163
03/14/18 01:45 AM
03/14/18 01:45 AM
Staten Island, NY
michaelluscher Offline
Staten Island, NY
FORScan on a laptop has some bidirectional control, you'll probably be able to control the purge/vent solenoid while smoke testing
Halloween smoke machine is a good bet, that's what I use for vacuum leaks
But if it's under 8y/80k miles, this should still be covered under emissions warranty, think about this if any expensive parts are needed
'06 Toyota Camry SE V6 3MZ-FE 100k
'01 Mercury Villager Estate VG33E 52k
'06 Ford Taurus SE Vulcan 60k
'13 Chrysler 300 3.6 Pentastar 230k
Re: Ford evap leak troubles [Re: buck91] #4694245
03/14/18 06:40 AM
03/14/18 06:40 AM
West Michigan
buck91 Offline OP
buck91  Offline OP
West Michigan
88k. 😒
2011 F150 4x4 5.0L
Re: Ford evap leak troubles [Re: buck91] #4694789
03/14/18 04:58 PM
03/14/18 04:58 PM
West Michigan
buck91 Offline OP
buck91  Offline OP
West Michigan
Well for what its worth, after messing with the purge valve duty cycle in Forscan it became apparent that it was stuck. Some moderate tapping with a small hammer and a couple squirts of brake cleaner freed it up. For now. Can't find a replacement part number on a couple different of my go to websites so I'll have to call the dealer...
2011 F150 4x4 5.0L
Re: Ford evap leak troubles [Re: buck91] #4694794
03/14/18 05:09 PM
03/14/18 05:09 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
DG1Z-9G271-B
Only serviced with the line the valve is on.
Re: Ford evap leak troubles [Re: bdcardinal] #4694805
03/14/18 05:30 PM
03/14/18 05:30 PM
West Michigan
buck91 Offline OP
buck91  Offline OP
West Michigan
Originally Posted By: bdcardinal
DG1Z-9G271-B
cheers
Thanks! That thing wasn't listed ANYWHERE. Even the local dealer gave my the vent solenoid p/n.
2011 F150 4x4 5.0L
Re: Ford evap leak troubles [Re: buck91] #4694828
03/14/18 05:45 PM
03/14/18 05:45 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
The description is "tube assembly, also includes VMV valve." VMV is Vapor Management Valve, also knows as the purge valve. Fortunately the tube has quick disconnects on each end.
