So going to work on Acura in the coming days/weeks.
Planning to do following things:
1- Engine oil and filter change 5W30 PP synthetic and A02 Honda OEM filter
2-PSF change with Honda OEM
3- ATF, 3x D&F with Acura DW1
4-Coolant D&F with pep boy's OEM(brand) coolant
5-Air and Cabin filter, need suggestions where should I get it from? Walmart or RA or AAP?
6-Brake fluid, will do with front brakes in a few months.
Anything else you guys would suggest or I should add to my list? Spark Plugs, maybe or Serpentine belt?
Thank you
Thank you
