Cracked single stage paint
by JHZR2. 09/18/18 01:45 PM
Options versus dealer oil changes
by Schmoe. 09/18/18 01:34 PM
Longevity of Mercon LV in a 2017 Ford Escape?
by mrdctaylor. 09/18/18 01:24 PM
I'm on a Lawn Boy jag
by andyd. 09/18/18 01:13 PM
Old (New) Tires
by ET16. 09/18/18 12:05 PM
iOs 12 for Apple
by madRiver. 09/18/18 12:01 PM
Synthetic oil overrated??
by Ablebody. 09/18/18 12:01 PM
Ferrari Monza SP 1/2
by DeepFriar. 09/18/18 11:58 AM
Any option to "Mark all forums read"
by Rick505. 09/18/18 11:54 AM
1981 280ZX Turbo
by 16HC. 09/18/18 11:12 AM
Muscle car emblems
by Snagglefoot. 09/18/18 10:15 AM
Burn out question
by Fitter30. 09/18/18 10:15 AM
Collector Oil Cans
by Snagglefoot. 09/18/18 10:06 AM
Thoughts on this truck and price.
by ls1mike. 09/18/18 08:39 AM
Canadian Tire Lucas Synthetic Motorcycle Oil 20w50
by Snagglefoot. 09/18/18 07:58 AM
Blast from my past
by 53' Stude. 09/18/18 07:25 AM
Happy Birthday USAF!
by Astro14. 09/18/18 06:35 AM
Ever had a total engine failure?
by Exhaustgases. 09/18/18 02:58 AM
tomkat22, tabar2004, SierraMan, Rennmeister, KeithCoates
66004 Registered Users
106 registered members (1JCB, 53' Stude, 28oz, 2012AccentSE, 2K2AcuraTL, 94astro, 9 invisible), 1,701 guests, and 36 spiders.
Topics290,597
Posts4,847,156
Members66,004
Most Online3,590
Jan 24th, 2017
Page 1 of 3 1 2 3
2006 Acura TSX maintenance items? #4693854
03/13/18 07:46 PM
03/13/18 07:46 PM
VA
maverickfhs Offline OP
VA
So going to work on Acura in the coming days/weeks.
Planning to do following things:
1- Engine oil and filter change 5W30 PP synthetic and A02 Honda OEM filter
2-PSF change with Honda OEM
3- ATF, 3x D&F with Acura DW1
4-Coolant D&F with pep boy's OEM(brand) coolant
5-Air and Cabin filter, need suggestions where should I get it from? Walmart or RA or AAP?
6-Brake fluid, will do with front brakes in a few months.
Anything else you guys would suggest or I should add to my list? Spark Plugs, maybe or Serpentine belt?
Thank you thumbsup
2006 Civic EX 202K/AT
2006 Acura TSX 180K/AT
Re: 2006 Acura TSX maintenance items? [Re: maverickfhs] #4693864
03/13/18 07:51 PM
03/13/18 07:51 PM
Kansan,1911 45ACP fan
Marco620 Offline
Marco620  Offline
Buy the TG or Fram Ultra oil filter. Fram makes the Honda ones now but the XG7317's are the best for under 9.00
Air filter,try and go on autoanything and get a kn cabin filter and aem dryflow air filter, or see if napa is still doing all their filter sales.
15' Civic 179k.0w20 Redline/Archoil9100,Eibach,Yokohama/Borla Exhaust/Tein Suspension/Fu7317/Redline Si-1
Right to work state proud. Non union household
Re: 2006 Acura TSX maintenance items? [Re: maverickfhs] #4693889
03/13/18 08:03 PM
03/13/18 08:03 PM
Los Gatos, CA
JeffKeryk Offline
JeffKeryk  Offline
Los Gatos, CA
We bought a 2006 TSX new and have been loving it for 180K miles.
I now use Mobil1 5w20 High Milage and a Wix or M1 filter.
I believe the Acura dealerships now use 5w20.
Air filters every 1 or 2 years? Cabin AF whenever as well.
ATF spill and fill every 25K miles or so with Honda fluid. MaxLife aint bad either...
Pedal Pump brake fluid flush avery 60K or so.
Plugs at 90K and 170K. Makes a difference. Denso plugs rock. My car had 2 Densos and 2 NGK's from the factory.
At 120K I replaced the water pump, tensioner and belt.
At 160K I replaced the alternator.
Flushed Power steering fluid.
Dang thing runs like new.
Re: 2006 Acura TSX maintenance items? [Re: JeffKeryk] #4693894
03/13/18 08:05 PM
03/13/18 08:05 PM
VA
VA
At 120K I replaced the water pump and tensioner.
You are the GUY to ask questions, what about spark plugs? Ever touched them? I have a HUGE stash of 5W20, once I run out of 5W30, will use 5W20 in it.
What kind of air and cabin air filter have you used?
Re: 2006 Acura TSX maintenance items? [Re: maverickfhs] #4693895
03/13/18 08:07 PM
03/13/18 08:07 PM
Los Gatos, CA
JeffKeryk Offline
JeffKeryk  Offline
Los Gatos, CA
I revised my post after thinking about it. I use Wix filters and stock NGK or Denso plugs. Stock is good.
This is my wife's car. I think she prefers it to her 2018 RX450h.
Re: 2006 Acura TSX maintenance items? [Re: JeffKeryk] #4693902
03/13/18 08:13 PM
03/13/18 08:13 PM
VA
VA
Awesome man, by any chance do you know if it uses Iridium or Platinum?
I'll add spark plugs to the list and might get Wix from NAPA.
Re: 2006 Acura TSX maintenance items? [Re: maverickfhs] #4693914
03/13/18 08:25 PM
03/13/18 08:25 PM
Austin, TX
MaximaGuy Offline
MaximaGuy  Offline
Austin, TX
With 175K (much like the Highlander in my signature) things I got to are
a) Front and rear struts (with new boots)
b) Front engine mount (worth replacing all of them if you have the money)
c) D&F OEM coolant as you have already on the list
d) Cleaning MAF and TB
e) If you know what you are doing get to the Fuel filter
f) Lube all window tracks (every 30K miles)
g) If you know what you are doing replace the O2 sensors (they have become lazy, they worth is 150K)
h) Replace the plugs
g) If you had the money replace the LCA and LBJ
Good luck and the TL-TypeS was the best vehicle I have ever driven, front-wheel drive and they leave the BMW 3 series far behind in handling.
2018 MB GLE350
2011 Lexus ES350
2006 Toyota Highlander 4WD
Re: 2006 Acura TSX maintenance items? [Re: MaximaGuy] #4693919
03/13/18 08:28 PM
03/13/18 08:28 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
What do both of those stand for?
Re: 2006 Acura TSX maintenance items? [Re: maverickfhs] #4693921
03/13/18 08:28 PM
03/13/18 08:28 PM
Athens, GA
ctechbob Offline
ctechbob  Offline
Athens, GA
Should be irridium. Pretty much anything Honda of that vintage will be using them.
Everything else on your list looks good. Pay a little more money for a good quality air filter and then whatever cabin filter you want and you should be good to go. The K-series engine is a good one. I think it was someone on Jalopnik that dyno'ed one at 500k and it hadn't lost but a few HP over new.
https://jalopnik.com/see-how-much-horsepower-this-500-000-mile-honda-really-1784944558
2008 Acura TL Type S - 140k
2003 Honda Accord V6 - 220k
2000 Honda Accord I4 - 310k
Current Oil - Milesyn SXR5W30
Current Filter - Partsmaster 61334
Re: 2006 Acura TSX maintenance items? [Re: SatinSilver] #4693926
03/13/18 08:31 PM
03/13/18 08:31 PM
VA
VA
Lower Control Arm and Lower Ball Joint
Re: 2006 Acura TSX maintenance items? [Re: ctechbob] #4693928
03/13/18 08:32 PM
03/13/18 08:32 PM
VA
VA
Yeah, I have seen yotube videos of that guy, it's insane what he has done laugh
Re: 2006 Acura TSX maintenance items? [Re: maverickfhs] #4693932
03/13/18 08:40 PM
03/13/18 08:40 PM
USA
slacktide_bitog Online content
slacktide_bitog  Online Content
USA
Doesn't your TSX have the MM? If so, you can follow its suggestions with no problems smile
The A02 is basically a Fram Orange PH7317. And since even the orange cans now have a silicone ADBV, you might as well save a little money and buy the Fram. Alternatively, you can step up to the TG or even Ultra if you desire a more premium filter. I lusually like Wix, but I don't like what Wix makes for this application because the media cartridge is much smaller due to the design of the bypass they use.
Do you plan on using the OCI suggested by the MM?
Nothing wrong with Honda's DW1, but Maxlife is a very popular full synthetic ATF at a great price. I also like Castrol's synthetic ATF when it is on sale.
Walmart also carries Prestone Honda PSF at a great price, if you ever need any. Is changing the PSF necessary? I know some Hondas of this era were recalled for some seals in the PS system causing a leak.
For the air filter, get OEM
For the cabin filter, get Micronair HN03104C. It's a charcoal/carbon filter, and US-made. Micronair is the OE supplier, but Honda does not offer a cabin filter with charcoal from the Honda or Acura dealer.
If the spark plugs haven't been replaced, replace them. Use only the OE-spec Denso or NGK iridium (or perhaps the Denso TT)
Re: 2006 Acura TSX maintenance items? [Re: maverickfhs] #4693937
03/13/18 08:44 PM
03/13/18 08:44 PM
VA
VA
I actually have a bunch of OEM A02 oil filters laying around, so as DW1 fluid - so I am kind of set there.
Air filter and Cabin filter, for now planning to go Wix, if price is same, maybe Honda OEM. I'll check Micronair HN03104C, thanks for the tip.
Might as well do the spark plugs too!
Re: 2006 Acura TSX maintenance items? [Re: maverickfhs] #4693945
03/13/18 08:51 PM
03/13/18 08:51 PM
VA
VA
BTW, any thoughts on Fram air and cabin filter from Walmart? Worth it or not at all?
Re: 2006 Acura TSX maintenance items? [Re: maverickfhs] #4693977
03/13/18 09:07 PM
03/13/18 09:07 PM
Los Gatos, CA
JeffKeryk Offline
JeffKeryk  Offline
Los Gatos, CA
NGK # 6994 LASER IRIDIUM Premium Spark Plugs IZFR6K-11
I think this is the Denso:
Denso (3377) SKJ20DR-M11 Iridium Spark Plug
Page 1 of 3 1 2 3
