Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Pennzoil Ultra Plat 5w30 1.4L T Chevy Cruze 10k
by SubieBlue. 01/17/19 08:03 PM
Coated rotors
by supton. 01/17/19 07:51 PM
Good samaritan
by JLTD. 01/17/19 07:15 PM
Doing suspension work. Need alignment?
by HawkeyeScott. 01/17/19 05:45 PM
100mg CBD Cannabis Gel
by Al. 01/17/19 05:36 PM
Electric Car "Green Test"
by redbone3. 01/17/19 05:06 PM
Want to try a uoa
by Dylan1303. 01/17/19 04:56 PM
Happy Birthday, Betty White!
by eljefino. 01/17/19 04:20 PM
Fram Ultra for Ecoboost 2.7
by Purpfox. 01/17/19 04:10 PM
Idle Speed / 1998 Olds 88
by Mark72. 01/17/19 03:28 PM
Heat blanket for your oil filter!
by MrWideTires. 01/17/19 03:24 PM
Proper oil viscosities.
by Bullwinkle007. 01/17/19 03:20 PM
44$ for 5 gals of home heating oil treatment!
by Audios. 01/17/19 03:05 PM
Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
PP 0W-20 vs PP HM 0W-20 - Difference in VI
by The Critic. 01/17/19 02:34 PM
Dickerson888, Frisky, polarisman340, jfradella, Bigyetti83
66964 Registered Users
128 registered members (4WD, 69Torino, advocate, Aero540T, ammolab, 10 invisible), 1,639 guests, and 49 spiders.
Topics296,750
Posts4,958,214
Members66,964
Most Online2,577
Jan 14th, 2019
Making an old skid steer last? #4693659
03/13/18 03:52 PM
03/13/18 03:52 PM
usa
nyquil_junkie Offline OP
usa
I recently bought an old New Holland Skid steer, L325. The Hydro tank is marked "use only 10W40 SE oil".
Fair enough, I know some use motor oil as hydro fluid.
My question is, for it's upcoming oil tank drain and change, Can I do better? I'd like to boost the charge pressure up a bit, spec says it should run between 90-150 psi. It starts up cold at 120psi and as it gets hot, it drops to about 110/105 and runs there all day long. No leaks, everything works as strong as an ox.
I've never messed with any hydro system this big and complex before and, as it would cost 10x more than I paid for it to replace (if they can even be found) the pumps I'd like to try to keep it as healthy as possible as long as possible. I know after 40 yrs or so, the innards are a bit worn.... it still lifts and carries a full dump of limestone with no problems.
Would replacing the 10W40 SE (SAE now) with something like 10W50+ be stupid or pointless or a good idea? I've had people tell me cut the 10W40 with lucas oil stabilizer or hydro booster but I'm not real keen on that idea. Since oil tech is so much better now than it was in 1978, I'm curious to know how I can get as much life out of these pumps as possible starting with the next oil change.
Should I just stick with the standard 10W40SAE, boost it up to 10W50 or start using some magic mucus made for old hydros of some kind? Or is there some kind of standard hydro fluid that should replace the motor oil it was designed to used?
I'm still learning as I go here, so I'm trying to err on the side of caution.
Re: Making an old skid steer last? [Re: nyquil_junkie] #4693770
03/13/18 05:31 PM
03/13/18 05:31 PM
Upstate NY
Donald Online content
Donald  Online Content
Upstate NY
Use motor oil until you get to know this machine. I would not boost anything.
I would go over it looking for worn parts, bearings, bushings.
2015 Ford F250 w/Powerstroke
Re: Making an old skid steer last? [Re: Donald] #4693785
03/13/18 05:38 PM
03/13/18 05:38 PM
wv
krismoriah72 Offline
wv
Re: Making an old skid steer last? [Re: nyquil_junkie] #4693814
03/13/18 06:05 PM
03/13/18 06:05 PM
usa
usa
Good thread... thanks!
I could ask the manufacture directly but I can't find Cessna/Eaton on the web to contact them as yet.
Re: Making an old skid steer last? [Re: nyquil_junkie] #4694184
03/14/18 02:07 AM
03/14/18 02:07 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
I would consider HDEO 15W40 CD/CE/CF for it's shear stability against PCMO 10W40.
Re: Making an old skid steer last? [Re: nyquil_junkie] #4695110
03/14/18 09:02 PM
03/14/18 09:02 PM
usa
usa
My woman said "it's ran for 40 yrs on the oil on the tank label, why change it?"
She might be on to something.
Re: Making an old skid steer last? [Re: zeng] #4695128
03/14/18 09:18 PM
03/14/18 09:18 PM
usa
usa
So...like Rotella diesel engine oil?
Re: Making an old skid steer last? [Re: nyquil_junkie] #4695250
03/15/18 01:12 AM
03/15/18 01:12 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
You got it, NJ.
Re: Making an old skid steer last? [Re: nyquil_junkie] #4696059
03/15/18 06:57 PM
03/15/18 06:57 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
How would oil make an old piece last longer?
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Making an old skid steer last? [Re: zeng] #4696077
03/15/18 07:25 PM
03/15/18 07:25 PM
usa
usa
You got it, NJ.
Rotella has several kinds... what type would be preferable?
Re: Making an old skid steer last? [Re: nyquil_junkie] #4696162
03/15/18 08:45 PM
03/15/18 08:45 PM
Malaysia
zeng Offline
zeng  Offline
Malaysia
You got it, NJ.
A mineral HDEO 15W40 in Rotella T4 15W40 in your market.
In my market, it's a Shell Rimula R4 X 15W40
Re: Making an old skid steer last? [Re: CT8] #4697599
03/17/18 12:07 PM
03/17/18 12:07 PM
usa
usa
My theory? Better additives might protect old worn parts and extend its usefulness for a while. I'd think its better to try that before it starts showing real signs of wear.
But I dunno... its why I asked.
Re: Making an old skid steer last? [Re: nyquil_junkie] #4700209
03/19/18 08:12 PM
03/19/18 08:12 PM
KansasCity
twoheeldrive Offline
KansasCity
I think you might need an oil with ZDDP in it.
My mini skid steer (circa 2005) came with a big sticker on the hydraulic oil tank that said: USE 15W-40 or 10W-30 DIESEL ENGINE OIL ONLY.
Well, in 2011, they (Toro) changed the spec when the HDEO oil formulation changed. Now the spec calls for Mobilfluid 424 or the equivalent.
So... I would be wary of using modern engine oil in that equipment. Apparently, hydraulic pumps like zink.
Here's what they sent out:
October 2011
Dear Toro Customer:
The purpose of this letter is to inform you of a change in Toro’s hydraulic oil
recommendation for your Sitework Systems product(s). This is necessary due to a
change in the formulation for the latest diesel motor oil API specification, CJ-4.
It has a reduced amount of ZDDP anti-wear additive and no longer meets the hydraulic system
requirements for Sitework Systems products.
Approved Hydraulic Fluids:
Toro Premium All-Season Hydraulic Fluid (Mobil DTE-15M Special), which is blended
for and available from The Toro Company through your dealer. This fluid is now
our factory original equipment hydraulic oil and contains a red dye to help in
locating oil leaks that may occur.
Premium Transmission/ Hydraulic Tractor Fluid (Mobil 424 Tractor Fluid), also
available from The Toro Company through your dealer, and other sources.
Previous specification diesel engine oil, API Specification CH-4 or CI-4
These fluids are compatible and can be mixed together. In the event
that none of these fluids is readily available please contact your local Sitework Systems dealer for possible
alternative “industry equivalent” fluid.
The information provided in the equipment Operator’s Manual no longer lists the correct
information on the type of hydraulic fluid to use. Included with this letter are two decals
with the new hydraulic fluid recommendation. Place one on the Operator’s Manual
cover and one on the unit by the hydraulic oil fill cover to remind you of this change.
Sincerely,
Toro Customer Care
... using Mobil 1 since 1976.
Re: Making an old skid steer last? [Re: nyquil_junkie] #4701543
03/21/18 06:51 AM
03/21/18 06:51 AM
Middle of Iowa
DriveHard Offline
DriveHard  Offline
Middle of Iowa
Run a modern hydraulic fluid of the weight equivalent to the engine oil you are using now. I think that would be around a ISO 100. That should be more shear stable...although would effect your cold temp operation if you use it during the winter very much...were you may have to switch to a lighter grade in the winter months. I would never suggest motor oil in a hydraulic system.
Do not turn up the charge pump pressure unless you want reduced performance. Turning up charge pump pressure will burn more fuel, put higher heat load on the system, and do nothing to increase the life of the components. If anything, it can reduce the life of some parts of the system. If your system reliefs are referenced to case pressure...you can actually reduce your tractive effort by increasing charge pressure, requiring more system pressure to do the same work...further stressing components. If there is not a low loop problem, the charge pressure is just fine.
A charge pump in your hydraulic system is not like the oil pump in your car. It does not supply positive pressure to bearings or camshafts. Most lubrication in a hydraulic pump is passive, or pressurized and balanced by system pressure.
Smile, it increases your face value
2013 Fiat 500 Abarth mod heavy (my DD)
2018 Alfa Romeo Stelvio TI Sport (wife's)
2011 Silverado Crew Cab LT 6.2L/6spd (tow pig)
2007 Nissan Xterra (trail toy)
Re: Making an old skid steer last? [Re: nyquil_junkie] #4704656
03/23/18 07:26 PM
03/23/18 07:26 PM
usa
usa
I don't see any ISO 100 but is this stuff suitable?
https://www.tractorsupply.com/tsc/produc...il?cm_vc=-10005
It says the SAE Viscosity is 10W30. If I can find what they call UNiversal Tractor Fluid of that ISO is that good?
Odd thing, the skid steers tank label says use only 10W40, the operators manual says use Dextron ATF. I don't know why they don't agree on that. What was in it when I got it looks and smells like motor oil not ATF. ATF s a lot thinner than motor oil so that one really confused me. Why suggest ATF in the book but label the tank to take 10W40?
There is no way to turn it up on this thing as far as I see. It just has the book specs of what is the normal range, so I stuck an oil gauge on it as the pressure sensor and buzzer doesn't work, (I put it on like the service manual says to for testing, on the pressure sensor line) the spec says its suppose to go off )the buzzer and the light) under 50PSI. The spec range of the charge pump says between 90-150 PSI so... I watch the gauge. I was under the impression that midway between 90-150 would be optimal but as long as it runs about 110-120 all the time, I guess I won't worry about it. I'm not too proud to admit I have really no idea what that charge pressure is or means. All I know is the book says "between 90-150". LOL
I wouldn't know if it did... what are the signs of a low loop problem? As far as I can tell it runs perfectly fine, no struggle digging or lifting or driving. Works like a bear for as old as it is. Let me know what that is and I'll watch for it.
My thinking was this thing is old, oils are different than they were back in the 70s, so what it was getting with 70s era motor oil is probably not what its getting with 21st century motor oil. Thus my questions and confusion.
