Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
41 registered members (carlprop, bbhero, Ag76, ArrestMeRedZ, Agnosto, 5 invisible), 923 guests, and 59 spiders.
Topics286,170
Posts4,903,517
Members67,572
Most Online2,967
Mar 10th, 2019
Valve lash adjustment #4693608
03/13/18 04:02 PM
03/13/18 04:02 PM
MA.
Camprunner Offline OP
MA.
Good friend of mine has an Acura/Honda RDX same as a Honda Pilot it's at leased 10 years old with 200,000 miles V6. It is running real rough so he took it to our local Honda dealer and they said the valves are out of adjustment and to do the job it takes 6 hours and will cost $700.00 does this price sound correct?
Re: Valve lash adjustment [Re: Camprunner] #4693624
03/13/18 04:14 PM
03/13/18 04:14 PM
New England
Virtus_Probi Offline
New England
The RDX is sort of an upgraded CR-V, did you mean this vehicle is an MDX (sort of an upgraded Pilot)?
2014 Forester XT, 95000 miles
Last Change;
M1 0W30 AFE d1G2
Tokyo Roki 15208AA170 filter
Re: Valve lash adjustment [Re: Camprunner] #4693626
03/13/18 04:14 PM
03/13/18 04:14 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Call a couple other dealerships and see what they quote for the job. They are probably quoting flat rate from their shop rate book.
Re: Valve lash adjustment [Re: Camprunner] #4693629
03/13/18 04:20 PM
03/13/18 04:20 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Too much. Find an independent garage that works on Hondas or a decent shop that works on anything. A valve adjustment isn't rocket science. Any mechanic worth his salt can do one.
Me: 13' VW GTI 3 door 6 speed manual
Re: Valve lash adjustment [Re: Camprunner] #4693632
03/13/18 04:29 PM
03/13/18 04:29 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Sounds about right for the V6 engine, the V6 rear bank is a PITA, the price is okay if it includes the plenum, VC gasket and tube seals. Up to 2012 they used an L4 IIRC.
Re: Valve lash adjustment [Re: Camprunner] #4693665
03/13/18 04:59 PM
03/13/18 04:59 PM
Virginia
GlazeB Offline
GlazeB  Offline
Virginia
Seems a bit high! Before I left the dealer it was 3 hours total putting it at 300$ not including parts. Those dealer valve cover gaskets are made of gold..... lol
Just checked Alldata and it says 3.0 hours for the repair fyi smile
2006 Toyota Corolla 270k
2005 Toyota Tacoma 137k
2008 Honda Pilot 101k
1978 Jeep Cj7
Re: Valve lash adjustment [Re: GlazeB] #4693676
03/13/18 05:09 PM
03/13/18 05:09 PM
Trav Offline
Trav  Offline
I just checked book time is 4.6 hrs for the V6 inc valve cover removal not incl upper plenum at 1.4 hrs. Whats the discrepancy?
Re: Valve lash adjustment [Re: Camprunner] #4693682
03/13/18 05:17 PM
03/13/18 05:17 PM
South Carolina
eyeofthetiger Offline
South Carolina
How did they know the valve clearance was out of spec unless they checked it?
Anyway, it might take 3 hours if you tie one hand behind your back. The hardest part is fitting the feeler gauge in there on the rear bank.
2017 Ford Fiesta 1.0T - Valvoline SynPower 5W-20, Motorcraft FL910S
1988 GMC K1500 4.3/700R4 - Supertech 15W-40, Fram TG3980
1986 Ford Ranger 2.0 - uhh
Re: Valve lash adjustment [Re: Camprunner] #4693686
03/13/18 05:20 PM
03/13/18 05:20 PM
USA
mk378 Offline
mk378  Offline
USA
Do not keep driving like that because a valve can burn, if it hasn't already. If it runs rough while driving not only when idling, it is probably another problem or more than just valve adjustment.
Re: Valve lash adjustment [Re: mk378] #4693700
03/13/18 05:29 PM
03/13/18 05:29 PM
South Carolina
South Carolina
I would suspect running rough with 200,000 miles is more likely a burned valve. I would not trust this dealer's diagnosis unless they explain it thoroughly. After the $700 valve adjustment doesn't fix it, they might say oh, it's a burned valve and a clogged catalytic converter - that'll be another $2000.
Re: Valve lash adjustment [Re: eyeofthetiger] #4693726
03/13/18 05:55 PM
03/13/18 05:55 PM
Trav Offline
Trav  Offline
Fluctuating vacuum cold at idle gradually smoothing out as temps increase. It does take longer than 3 hours.
This can be checked with a mechanical gauge or OBD lean fuel trim once the engine goes into closed loop but not quite full operating temp.
As valve clearance increases with aluminum heads (opposite of iron) the FT or vac gauge will stabilize as the valves seal.
Edit: There are other ways to test inc leak down hot/cold but I doubt they went that far. It could be a burned valve for sure but these engines are known for this as they get high miles and rarely have a burned one, the sodium filled stems dissipate the face heat pretty well.
Re: Valve lash adjustment [Re: Trav] #4693773
03/13/18 06:33 PM
03/13/18 06:33 PM
Suburban Washington DC
atikovi Offline
atikovi  Offline
Done it on a Saturn Vue a few times which has the same engine and the rear exhausts are a pain to reach.
Re: Valve lash adjustment [Re: atikovi] #4693893
03/13/18 08:04 PM
03/13/18 08:04 PM
North Texas
ARB1977 Offline
ARB1977  Offline
North Texas
Impressive clean internals.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: Valve lash adjustment [Re: ARB1977] #4693900
03/13/18 08:10 PM
03/13/18 08:10 PM
atikovi Offline
atikovi  Offline
Yep, pretty nice for 224,000 miles.
Re: Valve lash adjustment [Re: atikovi] #4694138
03/14/18 12:10 AM
03/14/18 12:10 AM
South Carolina
South Carolina
That looks more like 2240 miles. What oil/filter/OCI?
