I'll be in the market for a car trailer in the near future and am just wanting some outside information about trailers.
My dad's trailer, that he's hauled many $100K+ classic Corvettes on, is going on 30 years old and is what seems to be classified as a utility trailer. 16 ft., 2x 3,500 lb. 5-lug axles, angle iron construction except for the tongue only. It's been towed tens of thousands of miles and loaded pretty darn heavy (over 9K) at times and doesn't show signs of excessive fatigue. It's also balanced such that it tows extremely well.
(Dad's trailer behind now-my '67 Suburban in Helper, UT, on a trip to Rogue River, OR in about 1998. I was approx. 7.)
I've towed a number of "car hauler" type trailers with my '85 GMC and they always seem to exert a lot of drag on the truck and, when empty, beat on the back of the truck pretty badly. One was a U-Haul car hauler (not that big but built like a tank), one a Big Tex 18' 7K, and the other a Big Tex (I think) 20 ft., 14K w/dovetail and attached ramps.
My criteria is at least 18' long, at least 5,500 lb. payload capacity, with a dovetail if possible (haul small sedans somewhat often) but non-attached ramps, and at least 6.5' wide so it can be used to haul the 80's Econoline vans a friend of mine is always dealing in. The industry (as well as my mechanical engineer father-in-law) says the double-stack frame and other beefy areas of a car hauler is warranted, but based on dad's trailer and others I don't buy it. I don't put my equipment through ridiculous abuse so I don't expect it to fall off the Empire State building and come out unscathed. I may wind up using pieces of an old boat trailer I have (lots of 4" C-channel in it) to go into a trailer of my own design so I can achieve the dimensions I want, but I don't possess the knowledge to calculate section modulus? of the different type frames. Input?
