Supertech VS Redline - Project Farm
by StevieC. 03/18/19 03:01 PM
How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
Indyfordfan, toplscuda, swrve, TomRx, Ozdave
67548 Registered Users
111 registered members (1978elcamino, Alfred_B, ABerns, Agnosto, 2015_PSD, 17 invisible), 2,431 guests, and 63 spiders.
Topics286,019
Posts4,900,954
Members67,548
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
2015 Mini Copper Battery Replacement Coding #4693209
03/13/18 09:01 AM
03/13/18 09:01 AM
CA
2008wrx Offline OP
2008wrx  Offline OP
CA
Anyone folks here replaced one without coding? Also, can i put "non" (AGM (absorbed glass mat)) battery? Thanks
Re: 2015 Mini Copper Battery Replacement Coding [Re: 2008wrx] #4693224
03/13/18 09:24 AM
03/13/18 09:24 AM
KY
MCompact Offline
MCompact  Offline
KY
II always do it. You might get by without registration by going with an identical replacement, but if you are changing the type of battery I'd DEFINITELY have the battery registered.
Mine:
2014 M235i
2009 Cooper Clubman
1999 Wrangler Sahara
1995 318ti Club Sport
Wife's:
2015 X1 xDrive28i M Sport
Son's
2009 328i
Buy what makes you smile...
Re: 2015 Mini Copper Battery Replacement Coding [Re: 2008wrx] #4693236
03/13/18 09:36 AM
03/13/18 09:36 AM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
Why would you want to not do it? Id personally not cheap out - penny wise pound foolish. If youw ant to run an experiment, youll find out how well the battery lasts without doing so.
I believe there are non-BMW/mini scan tools that will code a battery replacement. Not sure if they will re-code a new size or type, but both are parameters to be coded in if battery type is changed.
Assuming that the same type of battery is just replaced, that is a simpler coding.
Re: 2015 Mini Copper Battery Replacement Coding [Re: 2008wrx] #4693240
03/13/18 09:38 AM
03/13/18 09:38 AM
CA
The Critic Offline
The Critic  Offline
CA
No, the battery needs to be registered to the vehicle due to the “smart” charging system that adjusts the charging profile as the battery ages. If a battery is replaced without registration, the lifespan will be shortened due to the aggressive charging that will take place.
Vehicle coding is not required as long as you match the aH rating to the current one registered and you do not change the battery type. This can be tricky because the battery in the vehicle now may not have the correct aH rating if it has been replaced before. Also, I would not use a non-AGM battery if the battery is inside of the vehicle.
2011 Toyota Prius 1.8L - 185K - SuperTech Dexos Full Syn 0W-20
2007 Honda Accord 2.4 - 135K - Mobil 1 EP HM 5W-30
Re: 2015 Mini Copper Battery Replacement Coding [Re: 2008wrx] #4693250
03/13/18 09:51 AM
03/13/18 09:51 AM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
It must be registered, and if not exactly the same type/A.Hr rating as original, must also be coded.
Both can easily be done with the Carly app and dongle.
http://www.mycarly.com/product/bmw-app/
I have heard of batteries exploding if not registered/coded properly.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: 2015 Mini Copper Battery Replacement Coding [Re: 2008wrx] #4693282
03/13/18 10:20 AM
03/13/18 10:20 AM
CA
2008wrx Offline OP
2008wrx  Offline OP
CA
thanks
Re: 2015 Mini Copper Battery Replacement Coding [Re: 2008wrx] #4693333
03/13/18 11:17 AM
03/13/18 11:17 AM
NM, USA
pkunk Offline
pkunk  Offline
NM, USA
All the newer Minis with the IB system (a box on the Neg terminal-purple arrow) need to have the replacement battery coded (registered with the cars computer), and you should use a AGM replacement.
8200 ft elevation in the Sangre de Cristos
2008 Mini Cooper Clubman (toad)
2000 Mercedes ML320
1994 Dodge 2500 Cummins
1999 Ford F53 V10 Coachman Motorhome 34ft
Re: 2015 Mini Copper Battery Replacement Coding [Re: 2008wrx] #4693394
03/13/18 12:21 PM
03/13/18 12:21 PM
Rockwall, Texas
Old Mustang Guy Online content
Old Mustang Guy  Online Content
Rockwall, Texas
I had no knowledge of this. Are there other car makes that require coding?
Re: 2015 Mini Copper Battery Replacement Coding [Re: Old Mustang Guy] #4693397
03/13/18 12:23 PM
03/13/18 12:23 PM
CA
The Critic Offline
The Critic  Offline
CA
Newer VW/Audi products do.
OP, if you are in NorCal, I have a Maxisys Elite and I can handle the registration for you.
Re: 2015 Mini Copper Battery Replacement Coding [Re: 2008wrx] #4693398
03/13/18 12:23 PM
03/13/18 12:23 PM
California
nthach Online content
nthach  Online Content
California
In that Mini, use an AGM battery - JCI is now bringing them over from Germany for some brands, Deka is supplying O’Reilly.
Get it coded too, I’d wouldn’t experiment with expensive BMW power distribution/body control modules. I think Carista’s app with a authentic ELM327 dongle can do that.
Re: 2015 Mini Copper Battery Replacement Coding [Re: 2008wrx] #4693410
03/13/18 12:34 PM
03/13/18 12:34 PM
NM, USA
pkunk Offline
pkunk  Offline
NM, USA
I believe you can register the battery through the left stalk pushbutton just like changing door lock/window/ turnsignal etc. Look in your owners manual. I'd tell you how but mine is older and doesn't require it
2000 Mercedes ML320
Re: 2015 Mini Copper Battery Replacement Coding [Re: The Critic] #4693428
03/13/18 12:49 PM
03/13/18 12:49 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
BMW also, but Mini is BMW so there you go. We had a sales guy with an older 5 series that needed battery registration. He someone managed to get a battery from Autozone and started yelling at us that the alternator boiled the battery.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: 2015 Mini Copper Battery Replacement Coding [Re: 2008wrx] #4693438
03/13/18 12:55 PM
03/13/18 12:55 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
You could get a Foxwell NT510 for $150 to do that job as well as regular OBD and a few other functions.
I just looked it up, google for the best price.
NT510
https://www.youcanic.com/video/230118815259833
Re: 2015 Mini Copper Battery Replacement Coding [Re: Old Mustang Guy] #4693583
03/13/18 03:30 PM
03/13/18 03:30 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
I'm guessing it's going to be on every new vehicle within 7 years to squeeze a small fraction of one MPG better fuel economy.
Me: 13' VW GTI 3 door 6 speed manual
Re: 2015 Mini Copper Battery Replacement Coding [Re: pkunk] #4693609
03/13/18 04:03 PM
03/13/18 04:03 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
Wow, this is where the Germans are clearly smoking cheap rave drugs. That's such a bad idea it's almost offensive.
There's no replacement...'scosity for natural viscosity
Page 1 of 3 1 2 3
