Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
M1 0W-40
by CT8. 09/20/18 07:37 PM
What controls timing on my 08 Honda?
by Roland. 09/20/18 07:23 PM
The real culprit about 18k
by Ablebody. 09/20/18 06:04 PM
How not to drain a pool.
by StevieC. 09/20/18 05:50 PM
Tranny fluid in Old Ferguson Tractor ?
by Rudy1999 250. 09/20/18 03:39 PM
Direct_Rejection, donatom, Sylent_Snyper, Ajizzle, nicknak
66033 Registered Users
46 registered members (BlakeB, BusyLittleShop, Big O Dave, andyd, Chris142, Blkstanger, 6 invisible), 1,089 guests, and 39 spiders.
Topics290,743
Posts4,849,414
Members66,033
Most Online3,590
Jan 24th, 2017
Page 1 of 5 1 2 5
Mower Only Runs Well On Choke (Lopey Idle) #4692677
03/12/18 05:30 PM
03/12/18 05:30 PM
New England
gathermewool Offline OP
New England
Having issues with a very lopey/rough-running mower. Looking for some help.
Mower:
Cub Cadet CC550
Issue:
Before the tear-down, the mower only ran on choke. Even after it was warmed up, it would stall almost immediately when the choke was released.
Maintenance:
1. Drained all fuel
2. Cleaned carb (looked pretty good)
3. Replaced fuel and air filters
4. Replaced spark plug
5. Replaced gasket
6. Added Berryman's B12
7. Added fresh fuel (just purchased today)
Result:
Now, it stalled when the choke was released, until warmed up. When warmed-up, it will run off-choke, but it's VERY lopey. See video below
Previous thread: New To Me Cub Cadet CC550 - Maintenance Tips
Video:
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Edge 0W-20 + FU filter
Re: Mower Only Runs Well On Choke (Lopey Idle) [Re: gathermewool] #4692683
03/12/18 05:40 PM
03/12/18 05:40 PM
Cedarbrae, Ontario
xxch4osxx Offline
xxch4osxx  Offline
Cedarbrae, Ontario
If it only runs with the choke on, its running lean. You might have to look really close at the carb and make sure all the fuel passageways are clear. One tiny piece of dirt is all it takes.
2015 RAM SXT Crew Cab 5.7 with 6 speed tranny.
2008 Mazda 3 GS Sport Hatchback 5sp MT (Girlfriend's car)
Re: Mower Only Runs Well On Choke (Lopey Idle) [Re: gathermewool] #4692685
03/12/18 05:41 PM
03/12/18 05:41 PM
Iowa
iahawk Offline
iahawk  Offline
Iowa
clean, clean and reclean the carb until it runs well..sometimes it takes a few tries to get it right. Others may suggest saving the trouble and buying a cheap replacement carb..
Re: Mower Only Runs Well On Choke (Lopey Idle) [Re: gathermewool] #4692690
03/12/18 05:44 PM
03/12/18 05:44 PM
New England
New England
I actually did purchase a rebuild kit AND a new carb. The new carb was the wrong one, so it can't be used.
I now have a carb cleaning brush kit. So, even though it looked clean, I'm going to pull it apart and run brushes through every orifice to see if that fixes it.
Re: Mower Only Runs Well On Choke (Lopey Idle) [Re: gathermewool] #4692693
03/12/18 05:47 PM
03/12/18 05:47 PM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
My friend completely disassembles little carbs and ALWAYS finds a crumb of yellowed plastic.
He claims it's always a chunk of tubing eaten away by ethanol.
His small engine gig is what he does well. People love him for it.
Re: Mower Only Runs Well On Choke (Lopey Idle) [Re: gathermewool] #4692697
03/12/18 05:51 PM
03/12/18 05:51 PM
New England
New England
Interesting. It could be that I inadvertently introduced something during reassembly.
I'll pull it apart again soon and see what I find.
Re: Mower Only Runs Well On Choke (Lopey Idle) [Re: gathermewool] #4692719
03/12/18 06:12 PM
03/12/18 06:12 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Take the carb apart and thow it in parts cleaner. Brushes are fine but a strand of thin copper wire works well for poking around in tiny passages.
Once its out of an overnight soak blow every passage out with compressed air from both directions if possible.
https://shop.advanceautoparts.com/p/gunk-carburetor-parts-cleaner-complete-kit-cc3k/7040709-P
Re: Mower Only Runs Well On Choke (Lopey Idle) [Re: gathermewool] #4692742
03/12/18 06:36 PM
03/12/18 06:36 PM
Marshfield , MA
andyd Online content
andyd  Online Content
Marshfield , MA
If it starts and runs and eventually runs even lopy without the choke, the I advise to keep dosing the gas with B 12. I've had B 12 fail to help immediately, I resolved to tear down the carb the following week end. Saturday came, and I gave it one last pull on the way to the bench. It lit first pull. grin2
Thick oil is better grin2
Re: Mower Only Runs Well On Choke (Lopey Idle) [Re: gathermewool] #4692748
03/12/18 06:39 PM
03/12/18 06:39 PM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
The engine runs better with the choke partly on BECAUSE it's getting too much air with the choke all the way off. This is the classic dead giveaway sign of a fuel delivery problem. People on this forum always tell you to clean the carburetor but they don't tell you WHY.
Re: Mower Only Runs Well On Choke (Lopey Idle) [Re: das_peikko] #4692760
03/12/18 06:46 PM
03/12/18 06:46 PM
Central Maryland
HangFire Offline
HangFire  Offline
Central Maryland
xxch4osxx explained why.
Various musings: http://hangfire.net
Re: Mower Only Runs Well On Choke (Lopey Idle) [Re: gathermewool] #4692761
03/12/18 06:46 PM
03/12/18 06:46 PM
North Carolina
spasm3 Offline
spasm3  Offline
North Carolina
You can try letting it set overnight after it runs with some berryman b-12 in the fuel. If it still runs the same, you will need to take the carb apart and clean it. Lots of jets and venturi holes in some. I had the same issue with a generator that sat for 3 years. I use small .014 stylets to clean the various jets and ports.
13 elantra 70k 5w30 QSUD
03 chevy avalanche79k synpwr 10w30
01 saturnsc1 185k synpwr rebuilt
17 mazda cx-5 5600 miles m1 0w30
Re: Mower Only Runs Well On Choke (Lopey Idle) [Re: das_peikko] #4692764
03/12/18 06:48 PM
03/12/18 06:48 PM
Trav Offline
Trav  Offline
The post by xxch4osxx told him why, no further elaboration needed.
Re: Mower Only Runs Well On Choke (Lopey Idle) [Re: gathermewool] #4692772
03/12/18 06:54 PM
03/12/18 06:54 PM
Canada
boraticus Offline
boraticus  Offline
Canada
Thin wire in every jet, hole and gallery followed up with compressed air.
Do that and the carb will run fine provided you got the wire through all of the above.
Re: Mower Only Runs Well On Choke (Lopey Idle) [Re: HangFire] #4692789
03/12/18 07:01 PM
03/12/18 07:01 PM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
I read the post. He didn't say WHY the engine was running lean with the choke off.
It's because the engine is getting too much air for the amount of available fuel at the present time.
Re: Mower Only Runs Well On Choke (Lopey Idle) [Re: boraticus] #4692793
03/12/18 07:03 PM
03/12/18 07:03 PM
North Carolina
spasm3 Offline
spasm3  Offline
North Carolina
This, actually followed up with carb cleaner spray then compressed air.
Page 1 of 5 1 2 5
