It's imperative to clean the jets and galleries in the carb. A piece of fine flexible wire and compressed air is best for that.
That's a cheap Chinese spark plug. Suggest you buy a NGK, Champion, Bosch or Denso plug and trash that plug.
Don't sweat a bit of soot on the piston. It's nothing. Once the carb problems are straightened out and the engine is running well, the soot will burn off.
By the way, you'll find your maintenance work much easier if you get the mower up about 18" to 24" off of the floor. Much easier on the back and easier to see things.
