Ford Truck (Humor)
by StevieC. 01/20/19 10:10 PM
Lucas and fresh oil
by Ls1z. 01/20/19 09:42 PM
NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Catch Can on the Caravan (250km)
by StevieC. 01/20/19 01:21 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
103 registered members (ammolab, 4WD, advocate, AndyB, 69GTX, 69Torino, 9 invisible), 1,660 guests, and 33 spiders.
Topics296,899
Posts4,961,201
Members66,997
Most Online2,688
Jan 19th, 2019
Page 2 of 4 1 2 3 4
Re: Low Ash Content [Re: RogerBacon] #4692997
03/12/18 08:54 PM
03/12/18 08:54 PM
PA
d00df00d Online content
d00df00d  Online Content
PA
My Mercedes requires 229.51 which is hard to find and expensive.
Canadian Tire carries Pennzoil Euro L 5w-30 which meets this spec, but yeah, not exactly cheap.
This seems to be a pretty good oil but I can not find the sulphated ash spec. Mobile 1 ESP is the best I found at .6
It's probably right around 0.8%. Most MB 229.51 oils are very close to that. So are a lot of low-ash oils, for that matter. Maybe even most of them. Mobil 1 ESP Formula 5W-30 is an exception.
2008 BMW M3
Re: Low Ash Content [Re: Linctex] #4693027
03/12/18 09:51 PM
03/12/18 09:51 PM
Illinois USA
IllinoisSparky Offline
Illinois USA
Walmart was selling 5 quart jugs the other day for $13 each. I grabbed three.
WOW. I wish I was that lucky. Good catch.
I would have picked up about 4 of them for my stash - good for 2 OC on my MB diesel.
04 Ford Explorer PP 5W-30/Puro PSL
99 MB CLK320 Castrol 0W-40/M1 filter
08 MB SL550 M1 0W-40/MB
09 BMW X5 3.0i Dealer 5W-30/BMW
11 MB E350 Bluetec MB 5W-30/MB
Re: Low Ash Content [Re: RogerBacon] #4693068
03/12/18 11:12 PM
03/12/18 11:12 PM
Colorado Springs
edyvw Online content
edyvw  Online Content
Colorado Springs
If a diesel requires a low ash content oil because of the DEF filter, would it matter what the ash content was if the motor did not burn any oil? My Mercedes requires 229.51 which is hard to find and expensive. It does not burn ANY oil, so why does it need it. I will still run the good oil but I was just wondering.
There is a thing called evaporation loss or NOACK.
MB229.51 is particularly hard on NOACK, not allowing above 10%. BMW LL-04 or VW504.00/507.00 allow more then that.
NOACK and amount of ash (%) are the ones that matter when it comes to DPF pollution.
For Ontario, try to find 5W30 oils, preferably Mobil1 5W30 ESP due to lower then usual ash content (0.6%) and ver low NOACK (5.6%).
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
Re: Low Ash Content [Re: Kamele0N] #4693071
03/12/18 11:16 PM
03/12/18 11:16 PM
Colorado Springs
Colorado Springs
you have many DPF specs wich are almost side by side...
Quote:
GM Dexos 2
The GM Dexos 2 specification is meant to be the replacement for both GM-LL-A-025 (gasoline) and GM-LL-B-025 (diesel) specifications for the European market. Oils meeting GM Dexos 2 are required for vehicles manufactured from MY2011 onward but they are also backward compatible with older models. This specification is built on the ACEA C3 standard but also contains elements from the ILSAC GF-4 deposit formation test and low-temperature sludge build-up test.
Quote:
BMW Longlife-04 (BMW LL-04)
Special BMW approval for fully synthetic long-life oil. Viscosities are SAE 0W-30, 0W-40, 5W-30 and 5W-40. Usually required for BMWs equipped with a diesel particulate filter (DPF). Can also be used where a BMW Longlife-98 or BMW Longlife-01 oil is recommended.
Quote:
MB 229.51
Low SAPS Long Life engine oil for diesel engines with particle filter meeting emission EU-4 -> standards.
VAG is a little different and above other standards....it has stringest norms regarding wear and piston deposits....especially @LL interval
Quote:
VW 507.00
Low SAPS oils suitable for Euro 4 engines and almost all VAG diesel engines from 2000 onwards with extended service intervals, unitary injector pumps and also Pumpe-Düse ("PD") engines. Excludes V10, R5 engines and VW Commercial vehicles without fitted DPF (diesel particulate filters) – these must use a 506 01 specification oil.
https://www.oilspecifications.org/
So if you can get any other oil with specs above you can easily go away with that....especially that will not be a problem because you tend to change your oil sooner over the pond smile
MB229.51 is slightly more stringent then VW504.00/507.00 when it comes to piston deposits. VW504.00/507.00 is more stringent wear wise BUT ONLY in 0/5W30 grades. VW504.00/507.00 is NOT applicable in 0/5W40 grades, and MB229.5 as well as BMW LL-04 is.
Re: Low Ash Content [Re: RogerBacon] #4693083
03/12/18 11:58 PM
03/12/18 11:58 PM
Europe
SonofJoe Offline
SonofJoe  Offline
Europe
I'd agree with Brother Weasley with one caveat...
Theoretically, if you're not burning any oil, you're not pushing any ash out in to the exhaust, so you won't ever plug your DPF (except with soot of course). I'd also agree that all engines burn some oil even if 'some' is a very small number.
However I'd contend that this small amount of oil, is more likely to be additive-free (and therefore ash-free) light base oil that's been stripped out of the crankcase by the action of hot blow-by and the re-evaporation of condensed, unburnt/partially burnt diesel fuel (as opposed to fully formulated, ash containing oil that flows upwards passed the rings or into the combustion chamber through leaking valve seals).
Burning a small amount of oil might yet be consistent with putting no ash down your exhaust pipe.
Re: Low Ash Content [Re: SonofJoe] #4693084
03/13/18 12:13 AM
03/13/18 12:13 AM
Colorado Springs
Colorado Springs
Ash constantly finds its way to DPF and it is possible to measure with certain OBD devices. I think results are provided by differential pressure sensor.
For example, using Carly for BMW I can monitor ash build up in my car.
Also, same OBD device can tell you frequency of DPF regeneration and soot level. In that way one can figure out where is bad fuel and where is good fuel since DPF regeneration frequency differs between fuel suppliers (Shell having least frequent DPF regenerations at least here in CO).
NOACK is what matters here and that is why MB 229.51 is so specific on NOACK and Ash %.
Re: Low Ash Content [Re: edyvw] #4693091
03/13/18 01:02 AM
03/13/18 01:02 AM
Europe
SonofJoe Offline
SonofJoe  Offline
Europe
Yep. Good point. Never played with OBD before but I can imagine that if your car's fitted with the appropriate sensors, you can measure stuff like differential pressure across the DPF which would give you an indication of how your filter is plugging over time.
Fully agree with your comments on Noack. Less than 10% is where I'd be pitching for.
Re: Low Ash Content [Re: RogerBacon] #4693114
03/13/18 04:08 AM
03/13/18 04:08 AM
'Stralia
Shannow Online content
Shannow  Online Content
'Stralia
Interesting to see what the non combustible deposits in DPFs look like...metallic oxides, aka "dirt"
Re: Low Ash Content [Re: RogerBacon] #4693368
03/13/18 10:55 AM
03/13/18 10:55 AM
Rijeka, EU
chrisri Offline
chrisri  Offline
Rijeka, EU
Even if a diesel engine doesn't appear to use oil, it certainly does. However diesel fuel does not evaporate as effectively as patrol/gasoline do and burnt oil is replaced by fuel.
I have experimented with high SAPS, mid SAPS HDEOs (1.0% ash) and had DPF problems later on. Can't say it is directly connected, but I've learnt my lesson.
Mid SAPS formulas have stricter requirements than FS , in right conditions they will perform just as as good or better.
02 Nissan Terrano 2.7.TDi Motul 15w40
06 FIAT Stilo MW 1.9 Multijet SHU 5w40
07 Opel Vectra SW 1.9 CDTI 150 MST 5w40
Re: Low Ash Content [Re: SonofJoe] #4693625
03/13/18 03:14 PM
03/13/18 03:14 PM
Colorado Springs
Colorado Springs
BMW being so complex, with Carly for BMW I can monitor some 100+ parameters.
Re: Low Ash Content [Re: edyvw] #4694326
03/14/18 07:41 AM
03/14/18 07:41 AM
Great Lakes
Quattro Pete Offline
Great Lakes
Will Carly app work with most generic OBDII bluetooth dongles or does it require a proprietary one?
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: Low Ash Content [Re: RogerBacon] #4694814
03/14/18 04:35 PM
03/14/18 04:35 PM
Ontario
RogerBacon Offline OP
Ontario
I asked Shell for the ash content of Pennzoil Platinum Euro. Here is the reply.
Hello Roger,
Pennzoil Platinum Euro L 5W-30 Full Synthetic Oil Motor Oil with Pureplus Technology is the product covers the MB-Approval 229.31 and 229.51 spec. See attached TDS.
The Sulphated Ash Content is an internal oil formula information that can not be share with the public.
Thank you very much.
Best regards,
Jeampy K.
Shell Canada, Technical Information Center
I guess I stay with Mobile 1
Re: Low Ash Content [Re: RogerBacon] #4694856
03/14/18 05:11 PM
03/14/18 05:11 PM
Colorado Springs
Colorado Springs
Hello Roger,
Best regards,
Jeampy K.
Probably around 0.8%. BMW LL-04 max. is 0.8% so I would say it is around that.
It does not meet VW504.00/507.00 and that spec. is very stringent on after treatment equipment. That spec. allows ash up to 1.5%, but considering emission requirements of that spec. it is usually below 0.8%.
Considering it does not meet that spec. I would say it is in 0.8% range.
Re: Low Ash Content [Re: Quattro Pete] #4694858
03/14/18 05:13 PM
03/14/18 05:13 PM
Colorado Springs
Colorado Springs
Yep, it is proprietary one:
Carly for BMW
Re: Low Ash Content [Re: edyvw] #4695037
03/14/18 07:47 PM
03/14/18 07:47 PM
Ontario
Ontario
I think if it was any good, they would publish it like everyone else.
Page 2 of 4 1 2 3 4
