When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
GG16v, fleetwood62, varalakshmi, AllyMac, Saxman657
67569 Registered Users
107 registered members (2015_PSD, 2009Edge, 2whlgeezer, Anduril, andyd, 12 invisible), 2,077 guests, and 58 spiders.
Topics286,160
Posts4,903,317
Members67,569
Most Online2,967
Mar 10th, 2019
OIl Leak Dyes #4692380
03/12/18 11:38 AM
03/12/18 11:38 AM
Chicago
Jooksing Offline OP
Jooksing  Offline OP
Chicago
Whats your experience with oil leak dyes, I borrowed papa's 07 Corolla with 189k. I took it for an oil change and added MMO to the oil and now is seems to be leaking more (dealer said there was an minor leak at the time). I also give the engine bay a wash. Anyways.. the oil is leaking faster now.. Noticeable spot on the asphalt. Tempted to replace the seals etc.. but wanted to try the oil dyes.
ASny brand recommendations? UV required or can naked eye spot it? Can you run it in the oil until next change or better to dump the oil. Car is a beater status at this point, maybe better to leave it be.
Re: OIl Leak Dyes [Re: Jooksing] #4692396
03/12/18 11:55 AM
03/12/18 11:55 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Dye works good you should clean the engine first. Check for obvious leaks first, the valve cover and plug seals (remove the coils and look for oil), front and rear seals would be a good starting point.
This with the light and glasses will work fine.
https://www.amazon.com/ACDelco-10-5045-M...ords=uv+oil+dye
Re: OIl Leak Dyes [Re: Jooksing] #4692418
03/12/18 12:16 PM
03/12/18 12:16 PM
Central NY
rsylvstr Offline
rsylvstr  Offline
Central NY
Leave it and stick with max life
2013 F150 SCrew Lariat 4X4 5.0 3.55
2012 Altima SL that still vibrates.
2018 Polaris Sportsman 850 SP. Polaris fluids and filter.
Re: OIl Leak Dyes [Re: Jooksing] #4692421
03/12/18 12:18 PM
03/12/18 12:18 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
What kind of oil? Has it ever had a HM oil in it?
2004 Corolla 129987
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: OIl Leak Dyes [Re: Jooksing] #4692424
03/12/18 12:23 PM
03/12/18 12:23 PM
New England
Virtus_Probi Offline
New England
Jeez, just use Royal Purple!!!
2014 Forester XT, 95000 miles
Last Change;
M1 0W30 AFE d1G2
Tokyo Roki 15208AA170 filter
Re: OIl Leak Dyes [Re: Jooksing] #4692429
03/12/18 12:31 PM
03/12/18 12:31 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
They dyes all work well. Clean everything, add the dye, drive it, and look. Then you can decide to fix it or use snake oil.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: OIl Leak Dyes [Re: Jooksing] #4692794
03/12/18 07:03 PM
03/12/18 07:03 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Dust it with cornflour?
