Would Like the Manual Transmission to Make a Comeback?
by Speak2Mountain. 09/21/18 11:39 AM
Leaf Mulcher
by kwijibo. 09/21/18 11:32 AM
Pizza dough too crusty
by zorobabel. 09/21/18 11:26 AM
Lubegard Red or Platinum
by diyjake. 09/21/18 11:01 AM
Storing Car Outside
by Delta. 09/21/18 10:47 AM
Looking at a cheap commuter!
by ryan2022. 09/21/18 09:46 AM
Does Your 3.5EB Make Oil
by Gene K. 09/21/18 09:07 AM
F150 Front Differential
by hatt. 09/21/18 08:45 AM
EU version of Subaru 2.5 FB engine
by IMPALA08. 09/21/18 08:40 AM
New “rules” changing your choice of car?
by daves87rs. 09/21/18 06:04 AM
WIX51334XP Oil Filters
by CB900F2. 09/21/18 05:14 AM
Signal Oil Company radio advertising
by 21Rouge. 09/21/18 04:07 AM
Anyone "Wim Hof"ing ?
by Shannow. 09/21/18 02:35 AM
New R1250GS and R1250RT
by 02SE. 09/21/18 12:55 AM
Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
ScottRousell, Direct_Rejection, donatom, Sylent_Snyper, Ajizzle
66034 Registered Users
101 registered members (Ablebody, Al, 209paulc, aquariuscsm, askani79705, 69Torino, 5 invisible), 1,744 guests, and 39 spiders.
Topics290,760
Posts4,849,822
Members66,034
Most Online3,590
Jan 24th, 2017
Vacuum pump for w116 300sd #4691991
03/11/18 10:45 PM
03/11/18 10:45 PM
CA
Gito Offline OP
Gito  Offline OP
CA
Looking for a good vacuum pump to check for vacuum line leaks.
Just want a good quality hand help pump that will last.
I own a 1979 300sd Mercedes w116 with door lock and brake booster problems.
Any advice is greatly appreciated
Re: Vacuum pump for w116 300sd [Re: Gito] #4692004
03/11/18 11:08 PM
03/11/18 11:08 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Being cheap I would go to harbor freight .
Wyr
God bless
Re: Vacuum pump for w116 300sd [Re: Gito] #4692007
03/11/18 11:13 PM
03/11/18 11:13 PM
Georgia
AVB Offline
AVB  Offline
Georgia
Harbor Freight does sell a Mityvac unit.
Re: Vacuum pump for w116 300sd [Re: Gito] #4692010
03/11/18 11:17 PM
03/11/18 11:17 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
Mityvac is just fine for troubleshooting MB diesels.
Have you verified that the mechanical pump is working properly? Some failures can dump metal into your engine. Rebuild kits are available...are the vacuum valves and dash pots all correct? It's fairly straightforward to isolate subsections and troubleshoot.
Good luck!
Re: Vacuum pump for w116 300sd [Re: Gito] #4692016
03/11/18 11:26 PM
03/11/18 11:26 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I have this metal one from Mityvac, it does vac and pressure, great buy for $50.
http://www.tooldiscounter.com/ItemDispla...ASABEgL-hvD_BwE
Re: Vacuum pump for w116 300sd [Re: Gito] #4692132
03/12/18 06:49 AM
03/12/18 06:49 AM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
Might check for excessive blowby-my old one had issues building up enough vacuum to overcome crankcase pressure!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Vacuum pump for w116 300sd [Re: Trav] #4692221
03/12/18 08:32 AM
03/12/18 08:32 AM
NE,Ohio
Rand Online content
Rand  Online Content
NE,Ohio
if you dont need all those adapters
hf has a mityvac pump for about 30$ after coupon
https://www.harborfreight.com/mityvac-vacuum-pump-39522.html
The kit trav linked has quite a few more accessories but I'm not sure if those are needed for the additional $20
Re: Vacuum pump for w116 300sd [Re: JHZR2] #4692240
03/12/18 08:50 AM
03/12/18 08:50 AM
CA
Gito Offline OP
Gito  Offline OP
CA
Good luck!
As for the door locks not working, I discovered a broken vacuum line (yellow with green stripe) broken off at the door hinge area (drivers side).
Even before this line cracked, I was having trouble with the passenger door lock closing all the way.
Would like to test my cars mechanical vacuum pump. Want to pick up a good hand held vacuum pump to test.
Re: Vacuum pump for w116 300sd [Re: bullwinkle] #4692248
03/12/18 08:56 AM
03/12/18 08:56 AM
CA
Gito Offline OP
Gito  Offline OP
CA
Will check for blow-by today. Are we talking about just removing the oil cap and checking for oil spilling or shooting out while the engine is running?
Re: Vacuum pump for w116 300sd [Re: Gito] #4692356
03/12/18 11:13 AM
03/12/18 11:13 AM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
That's a good start... When full hot, open the oil filler cap and see if it will just sit there (vibrating a bit of course), dancing, or being pushed clear off in an instant...
Have you done a compression test recently? Do PM on the GPs, ream and do a compression test at the same time... Its a worthy endeavour, IMO. But probably after a valve adjustment too!
Re: Vacuum pump for w116 300sd [Re: Rand] #4692371
03/12/18 11:26 AM
03/12/18 11:26 AM
Trav Offline
Trav  Offline
Look closer the adapter are just an added bonus, this unit is metal and can switch between pressure and vacuum the one from HF is plastic. It is definitely worth the extra $20, its a much higher quality and useful tool and rebuild parts are available.
Unless it is being bought as a disposable one time use tool the longevity alone of the metal unit may make it cheaper in the long run.
Re: Vacuum pump for w116 300sd [Re: Gito] #4692957
03/12/18 09:05 PM
03/12/18 09:05 PM
Georgia
AVB Offline
AVB  Offline
Georgia
The metal one is definitely a good buy at $50 and more durable. I have owned one of the plastic ones for 7 or 8 years without a problem. It was all that I could find locally at the time, but I haven't found a reason to replace it.
