'65 Mini.
by Silk. 03/19/19 02:08 AM
Our trash guy is getting on my nerves.
by Chris142. 03/19/19 01:20 AM
Ecogard trans filter
by pda1122. 03/19/19 12:11 AM
4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
47 registered members (Bailes1992, Agnosto, Astro14, aleneros, alcyon, aba4430, 2 invisible), 609 guests, and 54 spiders.
Topics286,049
Posts4,901,489
Members67,551
Most Online2,967
Mar 10th, 2019
Impact recommendation #4691854
03/11/18 07:51 PM
03/11/18 07:51 PM
PA
Chester11 Offline OP
PA
Hi guys:
DIY only here - so I'm not posting in the tool section. Mainly just lugs and some brake caliper bolts - nothing crazy.
I was gifted a cheap Sears airgun, and it leaks something awful.
I'm thinking of buying a 1/2 in cordless impact, but cannot justify spending buying a Makita or Milwaukee and only using it a few times a year.
I was looking at a Ryobi P261, only because I already have a low capacity 18v battery from my 1/4 impact I use around the house. (I use it to spin bolts on my cars after breaking them loose with a breaker.)
Anyone care to advise here? I'm not opposed to an air tool, but would like something small - the small ones are in the p261 range, so I'm torn.
Thanks.
Re: Impact recommendation [Re: Chester11] #4691874
03/11/18 08:09 PM
03/11/18 08:09 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
A mini air gun should fit your needs perfectly, they don't need a lot of CFM and have great power for their small size. This is one..
https://www.tooltopia.com/aircat-1056-xl.aspx
Re: Impact recommendation [Re: Chester11] #4691886
03/11/18 08:23 PM
03/11/18 08:23 PM
GA
miden851 Offline
miden851  Offline
GA
I used to work at THD; there is a widespread belief that Ryobi closed gap against competition plus they offer a lifetime warranty on their products; assuming your needs you may wanna get Ryobi and save the receipt
I'm using Milwaukee cordless though
2008 Mazda6i GT; @214K miles
2016 Honda CR-V EX-L; @40K miles
Re: Impact recommendation [Re: Chester11] #4691888
03/11/18 08:23 PM
03/11/18 08:23 PM
America's Dairyland
LotI Offline
LotI  Offline
America's Dairyland
Electric plug in impact. Harbor Freight has a good one for $40
Harbor Freight
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
Re: Impact recommendation [Re: Chester11] #4691889
03/11/18 08:24 PM
03/11/18 08:24 PM
MN
14Accent Offline
14Accent  Offline
MN
Get a mini! I bought the Mac AWP050M, and I hardly ever reach for the AWP050 full size I bought previously.
It's basically a rebadged Pronto:
Pronto 1/2 in impact
I absolutely love this little guy. It has PLENTY of power. Axle nuts, crankshaft pulley bolts, lug nuts, caliper bolts, etc. Pair is with a QUALITY universal joint adapter and there's almost no where this little thing won't fit.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: Impact recommendation [Re: Chester11] #4691908
03/11/18 08:47 PM
03/11/18 08:47 PM
Georgia
AVB Offline
AVB  Offline
Georgia
The only problem with that Ryobi is that it is huge for the fairly low power output. Corded impacts tend to be huge too, it will be tough getting to caliper bolts with a corded model.
Re: Impact recommendation [Re: Chester11] #4691952
03/11/18 09:40 PM
03/11/18 09:40 PM
Canada
i_hate_autofraud Offline
Canada
If you use any impact wrench to fully tighten wheel lug nuts, you'll be way over spec and 6 months later
the same tool won't have enough torque to remove the same wheel, you'll have to use a 24" or more breaker bar.
I have 1 high power air impact tool and a lo-power cordless that only goes to 80-90 Ft/Lbs that I use to
mount wheels and finish with a click type torque wrench by hand, so studs aren't stretched or stripped.
The big one removes the wheels and for suspension work where the power is needed!
Back in the '70s, we had a big RV with big wheels over torqued by the garage, on I-75 I felt a slight
but odd wobble in the front, we stopped for a look-see and ONLY 3 studs and nuts left on a front wheel!!
Close call!
Re: Impact recommendation [Re: Chester11] #4691967
03/11/18 10:01 PM
03/11/18 10:01 PM
The land of USA-made Subies!
SubieRubyRoo Offline
Harbor Freight has a multitude of various-sized air impacts to fit any "try-it" budget. My brother being a mechanic by trade has a Blue Point as one of his favorites, but I'm not dropping $800 on an impact, EVER.
I got the 1/2" standard anvil Earthquake from Harbor for like $74, rated at like 750 ft-lbs removal torque. Does it really do that much? Maybe, maybe not. But it's removed everything I've ever touched with it, and the middle of 3 tighten settings comes out right at 100 ft-lbs so it's great for doing aluminum wheels. I put two drops of oil in it every time I use it, and it's lasted about 5 years so far. Not a bad bargain in my book!
Re: Impact recommendation [Re: Chester11] #4692055
03/12/18 02:48 AM
03/12/18 02:48 AM
NJ
JLawrence08648 Offline
NJ
I bought a corded Milwaukee in 1980, never regretted it. Though it's powerful, on a rare occasion I have to use a breaker bar. I'm thinking about buying a cordless to use for mower blades.
Re: Impact recommendation [Re: Chester11] #4692070
03/12/18 03:55 AM
03/12/18 03:55 AM
Fernandina Beach FL
Dan55 Offline
Dan55  Offline
Fernandina Beach FL
The Ryobi looks like a good choice and you could upgrade the battery in future.
2016 Lexus NX200T 2017 Mustang Conv Eco Prem
Re: Impact recommendation [Re: Trav] #4692084
03/12/18 04:53 AM
03/12/18 04:53 AM
NY
demarpaint Offline
demarpaint  Offline
NY
I have one and it works nicely. Plenty of power, light and small.
God Bless Our Troops
Re: Impact recommendation [Re: JLawrence08648] #4692535
03/12/18 02:55 PM
03/12/18 02:55 PM
Central Virginia
Silverado12 Offline
Silverado12  Offline
Central Virginia
Hex drives work well for small projects. The Milwaukee is pretty good. I have a DeWalt 20V and it works decent. I think it should get blades off a mower unless they're rusted up.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: Impact recommendation [Re: JLawrence08648] #4692629
03/12/18 04:36 PM
03/12/18 04:36 PM
Trav Offline
Trav  Offline
That was made when Milwaukee was still running its own show, although they had been sold to Amstar at that time Amstar didn't interfere with production. You cant compare the original to what they sell today.
Re: Impact recommendation [Re: Chester11] #4692929
03/12/18 08:51 PM
03/12/18 08:51 PM
MN
ZebRuaj Offline
ZebRuaj  Offline
MN
I have been using the Ryobi in question for about 18 months now. Works just fine for a home mechanic. Has yet to have a problem with lug nuts nor suspension nuts and bolts.
It's a great add on tool if you already have some of the Ryobi 18v One+ tools and batteries.
If you believe the tool forums, the P261 and the Craftsman C3 version are clones of themselves. Pictures do look pretty identical.
If you find it struggling, you may want to pick up the 4 mAh battery. Rumor is the bigger battery gives it a bit more juice.
There is supposedly an even high power Lithium Ion battery in the works for Ryobi One+.
I have an Aircat 1055-TH for when I need a little more oomph or need to get into tighter places.
~Shade tree mechanic for friends and family.
Re: Impact recommendation [Re: Chester11] #4696031
03/15/18 07:30 PM
03/15/18 07:30 PM
PA
PA
thanks for all the help guys.
Harbor Freight has a 1/2 mini air gun on sale for $89 if anyone is interested. Also a pretty good deal on a 3/8 cordless impact ($129). you can add the 20% off coupon also.
Basically disposable tools....
