Thoughts on new AMAZON branded oil...?
by PantherFan88. 09/25/18 10:47 PM
Clutch kit?
by andrewp1998. 09/25/18 10:34 PM
Galaxy S8+ weird app when clearing storage
by KrisZ. 09/25/18 10:18 PM
Brake bleeder - cfm ?
by hallstevenson. 09/25/18 09:43 PM
18' Corolla vs 18' Elantra
by wolf_06. 09/25/18 09:41 PM
Using Tc-w3 bad for my car?
by Floydian. 09/25/18 09:25 PM
I'm going to start using type F in my gm autos
by turtlevette. 09/25/18 09:17 PM
Cleaning deceased MIL condo and found $15K cash
by Mr Nice. 09/25/18 09:12 PM
Gluten
by StevieC. 09/25/18 07:55 PM
Amazon Prime delivering inside your house
by StevieC. 09/25/18 07:49 PM
2018 MB C300 M1 0W-40 3,475 Miles
by 2015_PSD. 09/25/18 06:44 PM
02-05 Silverado frame rot
by Oildudeny. 09/25/18 06:38 PM
Aftermarket Back Up Camera
by lancerplayer. 09/25/18 06:20 PM
Service champ filter CUT OPEN
by 53' Stude. 09/25/18 05:05 PM
Pressure washer pump life just 23 hours?
by HawkeyeScott. 09/25/18 05:01 PM
STP S 10590 CUT OPEN
by 53' Stude. 09/25/18 05:00 PM
2003 BMW M5-Unknown oil 2500 mi
by Audios. 09/25/18 04:54 PM
FRAM ULTRA XG 3593A CUT OPEN
by 53' Stude. 09/25/18 04:51 PM
MG 201-7, 7,500 MILES CUT OPEN
by 53' Stude. 09/25/18 04:44 PM
Pat_Roberts, Peppz, Jfa02, ibsfusion, Fearcat707
66070 Registered Users
59 registered members (advocate, boulderdentist, AVB, ABomb369, 4WD, 5 invisible), 862 guests, and 35 spiders.
Topics291,025
Posts4,854,637
Members66,070
Most Online3,590
Jan 24th, 2017
Air Compressor Oil - Cold Weather Suggestions #4691423
03/11/18 12:17 PM
03/11/18 12:17 PM
Madison, Wisconsin
TWG1572 Offline OP
TWG1572  Offline OP
Madison, Wisconsin
I've got a Harbor Freight 21 gallon compressor. It does not like starting up in cooler weather, I usually have to cycle the start/stop lever back and fourth a couple seconds at a time to keep the reset from popping. After several cycles, things loosen up and away it goes. It will start on its own without throwing the reset.
Are there different oils I could consider to get things moving better when cold? Right now, I just have SuperTech 30W ND in it. Or is this just something I'm going to have to resign myself to during winter? I understand it's not the best compressor, but it works for what i need. Unless it's cold.....
Re: Air Compressor Oil - Cold Weather Suggestions [Re: TWG1572] #4691435
03/11/18 12:26 PM
03/11/18 12:26 PM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
Always make sure it is starting from ZERO pressure when it is cold.
If that is't what's going on.... something else is wrong (bad capacitor?)
Re: Air Compressor Oil - Cold Weather Suggestions [Re: TWG1572] #4691445
03/11/18 12:34 PM
03/11/18 12:34 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Re: Air Compressor Oil - Cold Weather Suggestions [Re: TWG1572] #4691458
03/11/18 12:47 PM
03/11/18 12:47 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
It is perfectly OK to use Mobil 1, 5W-30 in that thing.
Re: Air Compressor Oil - Cold Weather Suggestions [Re: TWG1572] #4691484
03/11/18 01:13 PM
03/11/18 01:13 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
17 Chrysler Pacifica Mobil 1 5W30
13 Yamaha XT250 Valv MC 10W40
12 Suzuki S40 Rotella 15W40
10 Acura TSX 2.4 PZL Plat 5W30
06 GMC Sierra Nextgen 10W30
Re: Air Compressor Oil - Cold Weather Suggestions [Re: TWG1572] #4691553
03/11/18 02:22 PM
03/11/18 02:22 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
I've been using Redline PolyComp 30W in my similar sized Craftsman compressor for about 15 years. Always fires up without tripping the reset or breaker even when I lived in Michigan and it was as cold as 0F no issues. Obviously still no issues here in Florida I change it every 5 years as the compressor doesn't run a ton.
Luke
Re: Air Compressor Oil - Cold Weather Suggestions [Re: TWG1572] #4691592
03/11/18 02:59 PM
03/11/18 02:59 PM
Waco, TX
Waco, TX
I don't think the oil is to blame.
There's something wrong electrically - it should start just fine,
or MANY OTHERS with the same or similar compressor would be complaining about it
(and they don't................ so there)
It's just that you got a bad one, that's all.
Re: Air Compressor Oil - Cold Weather Suggestions [Re: TWG1572] #4691620
03/11/18 03:23 PM
03/11/18 03:23 PM
Omaha, NE USA
fisher83 Offline
fisher83  Offline
Omaha, NE USA
I have the same air compressor. The manual that came with mine recommends 30wt when it's warm out and 10wt in the cold so that's what I've been doing. Tractor Supply sells plain non-detergent 10wt oil. I think once I run out of what I have currently I will probably just run a 5w30 or 10w30 synthetic in it year round though.
2015 Toyota RAV4 Limited 41k
2016 Nissan Frontier Pro-4x 18k
Re: Air Compressor Oil - Cold Weather Suggestions [Re: Linctex] #4691742
03/11/18 05:43 PM
03/11/18 05:43 PM
Madison, Wisconsin
TWG1572 Offline OP
TWG1572  Offline OP
Madison, Wisconsin
It was starting at zero pressure. I pulled the relief valve to double check. It does look like starting problems are either related to the check valve (probably not an issue since there was no pressure in the tank) or the capacitor. I guess the capacitor is easy enough to replace if I need to.
It got worse the colder it got, and is getting better as temps are increasing.
I guess I should have RTFM. I didn't even realize that the 10 ND oil was specified for cold weather. That probably would have helped I bet. I see Redline makes one, that might be the easiest just to order.
Re: Air Compressor Oil - Cold Weather Suggestions [Re: TWG1572] #4691799
03/11/18 06:53 PM
03/11/18 06:53 PM
wi
dave123 Offline
dave123  Offline
wi
Best recommendation for for cold weather start up you cannot beat Amsoil PCK 30/40 avalible in qts not cheap but for all weather and more so cold weather itís tops. Yes absolutely the problem you are having is in direct correlation to cold weather.
Re: Air Compressor Oil - Cold Weather Suggestions [Re: TWG1572] #4691812
03/11/18 07:13 PM
03/11/18 07:13 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
is it plugged directly into a wall outlet with stout wiring?
air compressors in the cold take some serious grunt to start.. switch to a syn. oil.
Re: Air Compressor Oil - Cold Weather Suggestions [Re: TWG1572] #4691846
03/11/18 07:44 PM
03/11/18 07:44 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
I ran GC 0w30 in mine so it would start in the winter without tripping my breaker.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Air Compressor Oil - Cold Weather Suggestions [Re: Rand] #4692366
03/12/18 11:21 AM
03/12/18 11:21 AM
Madison, Wisconsin
TWG1572 Offline OP
TWG1572  Offline OP
Madison, Wisconsin
It's plugged directly into the wall. I can't see the wiring, but the rest of the house is done in 14/2 romex. So I have to assume the garage is too.
I'm going to do the synthetic oil change. Just need to decide if I go with the straight 10 oil, or do a 10-30.
Re: Air Compressor Oil - Cold Weather Suggestions [Re: TWG1572] #4693515
03/13/18 02:00 PM
03/13/18 02:00 PM
Illinois
mbers1 Offline
mbers1  Offline
Illinois
I hooked mine up to run 220 volts. Problem solved.
I don't know if that is an option on yours though.
Re: Air Compressor Oil - Cold Weather Suggestions [Re: TWG1572] #4693522
03/13/18 02:09 PM
03/13/18 02:09 PM
Guilford, CT
exranger06 Offline
exranger06  Offline
Guilford, CT
I have a small 4 gallon Campbell Hausfeld compressor. CH actually recommends using Mobil 1 5w30 in it, although the small bottle of oil they included with it is a non-detergent 30w. I used the included oil, and it was horrible trying to start it in cold weather. It tripped the breaker almost every time. After the break-in period, I drained that oil out and switched to Mobil 1 5w30. Night and day difference! It starts up no problem even on the coldest days.
Bottom line: drain that straight weight oil out and fill it up with a 5w30 synthetic oil.
2006 Ford Ranger Sport
1992 Honda Accord EX
2004 Honda CR-V LX
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
