My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
Mobil 1 Cartridge Filters On Clearance at WM
by IndyFan. 03/25/19 06:19 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
78 registered members (alphadog, Aichiguy, agpatel, bbhero, AdditiveOCD, 9 invisible), 1,357 guests, and 59 spiders.
Topics286,436
Posts4,908,161
Members67,622
Most Online2,967
Mar 10th, 2019
Diagnostic Fun...... #4690974
03/10/18 11:19 PM
03/10/18 11:19 PM
Fort Worth, Texas
clinebarger Online content OP
clinebarger  Online Content OP
Fort Worth, Texas
Victim: 2007 Corvette 6.0L-LS2 32,xxx miles.
*Symptoms: Random Service Charging system message, Random Service ABS/TCS message, Radio shut down at high RPM, Random HVAC shutdown, Random harsh shift.
*DTC's: P0622 "Generator Field Duty Cycle circuit fault" P0300 "Random/Multiple misfires detected", ALL Class 2 modules have High & Low voltage codes.
*Work performed before it got brought to me: Battery replaced, Several Alternators, Generator control circuit wires replaced, ECM replaced, Ignition Switch replaced, Several ground straps added.
First thing I did was clear the codes & test drive the vehicle, P0622 sets within a 1/2 mile, Voltage PID fluctuates wildly between 10.1 VDC to 15.3 VDC, Generator Field Duty Cycle seems steady per the PID.
Go through the P0622 trouble tree, Inspect all the connector pins, Load test the generator control wires with a halogen headlight bulb, Removed the Alternator & had it tested.
At this point I'm kinda stumped! Break out the old Vantage Pro Oscilloscope to scope the Field circuit.......That's when I knew something was wrong! The waveform looked like a wacky secondary ignition-square wave hybrid that got worse with RPM.
Then I thought on it for a little while.....All I could come up with is Secondary Ignition interference on the Field circuit.....Checked out the spark plug wires, They are factory & look to be in good shape. Took a spray bottle & misted the plug wires with water.
Number 3 plug/wire was arcing against the exhaust manifold, Pulled the plug wire & swapped it with #5, Still arcing!
Pulled #3 plug & this is what I found..........POS E3 with a nice crack in the porcelain.
8 new AC-Delco Iridium plugs is all the car needed. The P0300 was the clue that I ignored because the P0622 was a "fix-first" in my mind.
With the customer at his wits end with this car & the fact he spent a few grand already on part changing/misdiagnostics ......I only charged for the tune-up with hopes to gain future service work.
2001 Chevy Camaro L92/4L80E
Re: Diagnostic Fun...... [Re: clinebarger] #4690980
03/10/18 11:25 PM
03/10/18 11:25 PM
Valencia, CA
Richie Offline
Richie  Offline
Valencia, CA
Good work.
Re: Diagnostic Fun...... [Re: clinebarger] #4690983
03/10/18 11:29 PM
03/10/18 11:29 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
What would cause damage to a spark plug like that?
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
Re: Diagnostic Fun...... [Re: clinebarger] #4690988
03/10/18 11:35 PM
03/10/18 11:35 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Who in their right mind runs E3 plugs? Talk about shielded arc and contained corona ...
Nice save, bet you'll get the work in the future.
O'Scope is a great diagnostic tool smile
Re: Diagnostic Fun...... [Re: clinebarger] #4690994
03/10/18 11:42 PM
03/10/18 11:42 PM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
Before I read you solved the problem I was thinking you need to ask the owner what aftermarket non-oem parts were installed. It looks like the wrong plug can wreak all havok.
Re: Diagnostic Fun...... [Re: Leo99] #4690997
03/10/18 11:46 PM
03/10/18 11:46 PM
Fort Worth, Texas
Fort Worth, Texas
Manufacturing defect, Dropping the plug, Using the wrong socket/rough tool handling....Take your pick! If I had to guess, I would say it was dropped & it hit something with an edge?
Re: Diagnostic Fun...... [Re: clinebarger] #4691016
03/11/18 12:19 AM
03/11/18 12:19 AM
Phoenix
dishdude Online content
dishdude  Online Content
Phoenix
Nice detective work! Amazing how the simplest things can cause the craziest issues in modern cars.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI
Re: Diagnostic Fun...... [Re: clinebarger] #4691026
03/11/18 12:42 AM
03/11/18 12:42 AM
Pennsylbammyvania
dailydriver Offline
dailydriver  Offline
Pennsylbammyvania
GREAT detective work! thumbsup cool
I will stick with NGK Laser Iridiums for my car, they can keep their Brisks, E3s, etc. wink
I CAN see someone cracking the ceramic part of a plug upon installation into an LSx's head, being that you are basically working 'blind', and by feel only when doing this job, on a f-body, or y-body application's extremely tight engine bay.
It is also almost impossible to properly torque the plugs in these apps because of the angles involved. frown
2016 Ford Fiesta ST 14K miles
Ravenol DXG 5W-30
Amsoil Ea15K51 filter
Ravenol MTF-2 in the IB6 transaxle
Re: Diagnostic Fun...... [Re: clinebarger] #4691055
03/11/18 02:30 AM
03/11/18 02:30 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Really good and professional diagnosis.
It's amazing at times what one single, simple issue can do in creating scenarios that have you looking everywhere.
Re: Diagnostic Fun...... [Re: clinebarger] #4691059
03/11/18 03:07 AM
03/11/18 03:07 AM
New Zealand
Silk Offline
Silk  Offline
New Zealand
These days the first thing you do is plug in the scanner...previously we hooked up the scope. A good scop would've picked this up first. As always, the fault is the last thing you look at...regardless of how many things you looked at before you found it.
1987 BMW R65 - Aegis SAE30
2005 Nissan Expert - 5W-40 Castrol Magnatec diesel.
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: Diagnostic Fun...... [Re: clinebarger] #4691070
03/11/18 04:26 AM
03/11/18 04:26 AM
Manchester, England
Olas Offline
Olas  Offline
Manchester, England
Scanner or scope you should always check the ignition system from top to bottom if you have to look any part of it - never just isolated components in the circuit.
Cable ties should hold it
Re: Diagnostic Fun...... [Re: clinebarger] #4691089
03/11/18 05:32 AM
03/11/18 05:32 AM
Margate England
Claud Offline
Claud  Offline
Margate England
Back in the day the mechanic would take a look at the plugs first. Before plug in diagnostics I mean. They would tell him (or her, though female mechanics were very rare back then) how the engine was running and if a particular cylinder was the problem.
But nowadays it might take an hour simply to gain access to them.
I jaguar came into a shop I worked in recently, the driver was complaining of poor response and the eml was on. The plug in diagnosis told of all kinds of faults, then I pointed out I could hear hissing like an air leak - so could everyone else - and found a breather hose had split. It took me maybe a minute to find. I make no claims about being a genius mechanic, but often it pays to look for the obvious, computers will only do as they are told, an air leak or bad plug might be beyond a computers imagination.
Claud
Re: Diagnostic Fun...... [Re: clinebarger] #4691126
03/11/18 07:43 AM
03/11/18 07:43 AM
Lyndhurst NJ
Audios Offline
Audios  Offline
Lyndhurst NJ
Good find, its always so [censored] when someone gets mislead by all the marketing hype and it costs them thousands, especially when the expenses is coming from the mouth of an untrained tech. We had a similar issue, customer with an e46 330xi had misfires across the board. He did plugs and coils already. We changed PCV from a cracked hose, and split housing and was still running poorly, better but no balls on acceleration, and no faults at idle only acceleration. Well Pep Boys told him E3 were the latest and greatest plugs, and guess what caused all of the faults and threw the owner for a loop since he thought the plugs had no affect. A set of OE BKR6EQUP from NGK and the car ran perfectly with 170k.
2002 VW Golf TDI-Mobil 1 5/40 TDT
2007 Mercedes GL320 CDI- M1 0/30 ESP
2005 BMW M3 BMW Twin Power 10/60
2003 BMW M5-Fuchs 5/40
1998 BMW M3/4/5 Fuchs 5/40
Re: Diagnostic Fun...... [Re: clinebarger] #4691172
03/11/18 08:20 AM
03/11/18 08:20 AM
Southern VA
klt1986 Offline
klt1986  Offline
Southern VA
Great job! Hopefully you gained that customers' trust and he will come to you when work needs to be done to his vehicles.
Re: Diagnostic Fun...... [Re: clinebarger] #4691205
03/11/18 08:56 AM
03/11/18 08:56 AM
USA
NHGUY Offline
NHGUY  Offline
USA
But...E3s are great...like the late great SplitFire plugs....they burn cleaner and deliver more hp and MPGs than any conventional plug...really...honestly.....says Green Acres Huckster Mr Haney....lol
