'65 Mini.
by Silk. 03/19/19 02:08 AM
Our trash guy is getting on my nerves.
by Chris142. 03/19/19 01:20 AM
Ecogard trans filter
by pda1122. 03/19/19 12:11 AM
4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
34 registered members (Bailes1992, ChrisD46, ArrestMeRedZ, ctechbob, billt460, Dave9, 2 invisible), 551 guests, and 56 spiders.
Topics286,049
Posts4,901,475
Members67,551
Most Online2,967
Mar 10th, 2019
Starter Brushes #4690963
03/10/18 11:02 PM
03/10/18 11:02 PM
AZ
junksta Offline OP
junksta  Offline OP
AZ
What type of solder should I use on starter brushes? Searched a lot but either its not mentioned or gets too technical for me. I have 96tin 4silver, 422deg melting point on hand.
2012 Kia Sedona- QSUD
1990 Daihatsu Rocky
Re: Starter Brushes [Re: junksta] #4691021
03/11/18 12:38 AM
03/11/18 12:38 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Rosin core "electronics" solder.
Re: Starter Brushes [Re: junksta] #4691022
03/11/18 12:39 AM
03/11/18 12:39 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Re: Starter Brushes [Re: junksta] #4691025
03/11/18 12:41 AM
03/11/18 12:41 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Re: Starter Brushes [Re: junksta] #4691125
03/11/18 07:43 AM
03/11/18 07:43 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
You do not want anything plumbing related or brazing or silver solder. Just rosin core solder and use a soldering iron or gun.
2015 Ford F250 w/Powerstroke
Re: Starter Brushes [Re: junksta] #4691139
03/11/18 07:55 AM
03/11/18 07:55 AM
hawthorne, Ca.
46Harry Offline
46Harry  Offline
hawthorne, Ca.
Use a solder meant for electronics work which has a rosin core either in the 60/40 or 63/37 formulation. The use of anything else will cause a connection failure in short order. Also make sure that you use a soldering iron or gun with a high enough wattage to completely heat the solder and surrounding metal or you will end up with a cold solder joint which is guaranteed to have an early failure.
Re: Starter Brushes [Re: junksta] #4691144
03/11/18 07:59 AM
03/11/18 07:59 AM
Battle Creek, MI
SVTCobra Offline
SVTCobra  Offline
Battle Creek, MI
I would also suggest buying some rosin flux. Most plumbing flux is acid based (at least what I could find) and even "electrical flux" at big box stores if found is still acid flux. Acid flux causes corrosion and isn't that big of a deal in plumbing but electronics obviously a different story.
https://www.sra-solder.com/rosin-paste-flux-135-in-a-2-oz-jar
Think twice, speak once.
Re: Starter Brushes [Re: SVTCobra] #4691149
03/11/18 08:05 AM
03/11/18 08:05 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
That's a tiny bit low, but HEY - if your starter ever sees 421*F you are doing something WRONG!
Why do suggest this over the (very common) standard of Rosin CORE solder?
Re: Starter Brushes [Re: junksta] #4691214
03/11/18 09:02 AM
03/11/18 09:02 AM
missouri
ragtoplvr Offline
ragtoplvr  Offline
missouri
dont listen to these folks. They are not in the business.
60 40 will NOT hold up. Not even on alternator brushes.
3.5% usually does not holdup unless the starter is from the 60 or older. Flux must be completely removed after solder. this solder is OK for alternator brushes.
15% silver strip (Phos copper brazing alloy). Flux is not needed and a spot welder is best.
these days everything has been so reduced in size high heat is common.
Someone will be along to say they used it and it was fine. If a rebuilder used that low temp solder the warranties would put them out of the business.
Rod
Re: Starter Brushes [Re: Linctex] #4691238
03/11/18 09:30 AM
03/11/18 09:30 AM
Battle Creek, MI
SVTCobra Offline
SVTCobra  Offline
Battle Creek, MI
Maybe I'm not good at it but the soldering I do I find works better when I use flux first instead of just heating up wires and melt the solder.
