Schaeffer's oil
Phila, PA
I understand that Schaeffers 9000 Full Syn contains high levels of Moly. Are there any downsides to this level of moly, such as ring deposits or other issues? Is this moly tri-nuclear or something different?
Also some have commented higher lead using Schaeffer's 9000 oil. Is this for real or a rumor/myth? I was impressed with the million mile engine tear down, as far as low wear and cleanliness.
JLTD, I was wonder what oil and weight you are running in your 4Runner? Have you tried different brands and weights and have a preference?
PM on the way.
My pleasure. / hijack
As far as the moly clogging things, from my understanding, it doesn't. I've seen a couple of UOAs here on it and they looked really good.
There are NO disadvantages to Schaeffers micron moly in their oil. In fact quite the contrary. Increased fuel economy and engine life being two of the biggest advantages.
Are you allowed to confirm which type of moly is used in your oils (or at least the 9000 series)?
Schaeffers is constantly searching for the most advanced additive technologies and tweeking micron moly formulas while working directly with additive manufacturers. Additionally with a variety of organo,soluble ,synthetic moly compounds used in Schaeffers greases and gear oils.
When is Schaeffer's introducing a Dexos1 Gen2 formulation?
By summer
PLEASE keep us informed!
Only time you have to worry about moly is in wet clutch motorcycle engines as it will cause slipping. In a car engine, there's no problem with that.
FWIW
My son has an electrical contracting company, a well drilling company, and farms in S. Indiana - it gets hot and cold here. Run Schaeffer's in everything except a couple of antique tractors, a Deere 520 and 820 diesel. No issues, including a few Chevy pickup diesels. Uses their grease and hydraulic fluids as well. 239 and 274 5% moly grease in everything. Very pleased with the performance.
I believe Schaeffers is a quality product. Is there any retailers who sale it?
You can look at their site. Ive found one salesman in local and i order thru him and pick it up at their warehouse next day.
Thanks the closest place is about 30 miles away and the prices their wanting to charge for a change is criminal.
