Are my rotors warped?
by Dylan1303
06/18/18 05:44 PM
Ultimate Fast Finish on sale at CDN tire.
by irv
06/18/18 05:23 PM
96 Civic 5w20 Castrol GTX Ultraclean UOA
by researcher
06/18/18 04:52 PM
VOA Castrol Magnatec D1G2, 5w30
by researcher
06/18/18 04:38 PM
Unused dented silicone Fram PH8316 cut open
by slacktide_bitog
06/18/18 04:28 PM
Bring back Merkava_4
by mjoekingz28
06/18/18 04:28 PM
Same grade with differing low start temps
by mjoekingz28
06/18/18 04:24 PM
Self defense
by Camprunner
06/18/18 03:13 PM
Any apple experts here?
by maverickfhs
06/18/18 02:50 PM
Cost-no-object 75W-90 GL-5 for a differential?
by d00df00d
06/18/18 02:34 PM
Pittsburgh Dad, this guy is a trip
by Rat407
06/18/18 02:06 PM
14 Jeep GC 5.7, PP 5w20 & 0w20
by Vigg
06/18/18 01:52 PM
Sell me on a SSD drive...........
by ZZman
06/18/18 01:07 PM
need some ideas on my issue
by matrass
06/18/18 12:36 PM
Put Pennzoil Platinum Euro L in a Honda.
by dunlop0078
06/18/18 12:36 PM
BMW V8 Oil Consumption Fix
by doc540
06/18/18 11:25 AM
More info on Valvoline Modern Engine Oil
by buster
06/18/18 11:07 AM
Shelf life of synthetic 2 stroke engine oil ?
by ScottMill
06/18/18 10:34 AM
Oil sample extraction
by Tikka
06/18/18 10:30 AM
Re-using building materials esp nails
by andyd
06/18/18 08:57 AM
WtsTacoma01, Orion62, Revd, blinky1041, mostdecent
65262 Registered Users
102 registered (4WD, Aero540T, AmericaWestCMH, 08z06, AndyB, AandPDan, 13 invisible), 1617 Guests and 41 Spiders online.
65262 Members
67 Forums
285534 Topics
Page 1 of 2 1 2 >
#4690760 - 03/10/18 06:02 PM Under Valve Cover: 2000 LS1 @ 120,000 miles
MrHorspwer Offline
Loc: Michigan
Previous owner said he used Mobil 1 10W30 exclusively. Before him... who knows.
Coming apart for a new cam, valve springs, timing set, rocket trunnions, and oil pump.
#4690767 - 03/10/18 06:15 PM Re: Under Valve Cover: 2000 LS1 @ 120,000 miles [Re: MrHorspwer]
Throt Offline
Loc: Jacksonville, FL
I can't find a bad thing to say.
For 120,000 miles, I feel it looks superb.
'18 Cadillac ATS AWD, 2.0L T-GDI, 3500, Factory Fill/Filter, his (lease)
'17 Elantra, 2.0L, 21,000, QS Ult. 0w20 w/ FU, hers (lease)
#4690773 - 03/10/18 06:22 PM Re: Under Valve Cover: 2000 LS1 @ 120,000 miles [Re: MrHorspwer]
OVERKILL Offline
Loc: Ontario, Canada
Looks fantastic!
2016 Durango Limited
2016 Grand Cherokee SRT
#4690786 - 03/10/18 06:49 PM Re: Under Valve Cover: 2000 LS1 @ 120,000 miles [Re: MrHorspwer]
Cujet Offline
Loc: Jupiter, Florida
High lift cam? Roller Rockers? All the normal hot rod stuff?
Looks really good. Mobil 1 always delivers.
#4690894 - 03/10/18 08:35 PM Re: Under Valve Cover: 2000 LS1 @ 120,000 miles [Re: Cujet]
MrHorspwer Offline
Loc: Michigan
Bigger camshaft? Yes. Not a radical step up, just a mild bump. New valves springs are to accommodate the cam swap.
Roller rockers? Funny thing about that... it has roller rockers now. I'm getting rid of them. Early LS engines had a nasty habit of spitting the needle bearings out of the rocker arms and down into the engine. The solution is to replace the loose needle bearings in the roller tunnion with a set of caged needle bearings or get rid of the roller trunnion altogether and replace it with a bronze bushing. I'm doing the latter.
Everything else is being done just because I'm in there.
#4690898 - 03/10/18 08:39 PM Re: Under Valve Cover: 2000 LS1 @ 120,000 miles [Re: MrHorspwer]
incognito_2u Offline
Loc: Long Island, N.Y.
Before my last 2 fills of PUP, I exclusively used Mobil one........glad to see it worked out for you!
2006 Jeep Commander 3.7 V6 -108k (PUP/XG3600)
2006 Toyota Corolla 1.8 VVTi -76k (PPHM/XG3600)
1999 Toyota Corolla 1.8 -77k (PUP/XG4386)
#4690918 - 03/10/18 08:59 PM Re: Under Valve Cover: 2000 LS1 @ 120,000 miles [Re: MrHorspwer]
Pajero Offline
Loc: Rio Rancho, NM
WOW! Impressively cleaned. For many years I wasn't an Exxon Mobile fan. But, I've never seen a dirty engine with Mobil 1.
Respectfully,
Pajero!
Always remember "Planned obsolescence."
1994 Montero SR 3.5 DOHC, 133,xxx
Fram Ultra/ Snorkel with Pre-filter
K-9-Co-pilot
#4690927 - 03/10/18 09:06 PM Re: Under Valve Cover: 2000 LS1 @ 120,000 miles [Re: MrHorspwer]
clinebarger Offline
Loc: Fort Worth, Texas
Stay away from the JUNK Comp Cam Trunnion kits!
2001 Chevy Camaro L92/4L80E
2010 Toyota Corolla 2ZR-FE/Auto
#4690956 - 03/10/18 09:54 PM Re: Under Valve Cover: 2000 LS1 @ 120,000 miles [Re: MrHorspwer]
SubieRubyRoo Offline
Loc: Winchester, Indiana
Jesel shafts FTW!
I've always loved LS engines... after I got over my hatred for them. I used to be a 5.0 guy, and once I realized the LS has much more in common with a 5.0 than it did SBC, it was true love.
My brother and I built a 404-cube, 12.3:1 LS3 with some goodies for his 2000 Camaro SS with a 400 trans. Best pass I made in it was [email protected] starting in 2nd gear (oops, dang ratchet shifter), with just a 275 drag radial and stock everything else, including full interior and a cage. Like I said... true love!
#4690998 - 03/10/18 10:47 PM Re: Under Valve Cover: 2000 LS1 @ 120,000 miles [Re: MrHorspwer]
BrocLuno Online   content
Loc: Kalifornia Kollective
Good on you. Bronze bushing is teh way to go smile
Whoever though that needle bearing roller rockers were a good idea on the street should have been shot long ago. Lost needle bearings have eaten plenty of engines ...
I a race motor, they are a high maintenance item. Usually replaced after X number of passes/laps.
Epoxy a plate magnet into the bottom of the pan so any loose Fe bits that fall stay at the bottom and do not circulate.
#4691078 - 03/11/18 04:48 AM Re: Under Valve Cover: 2000 LS1 @ 120,000 miles [Re: MrHorspwer]
SR5 Offline
Loc: Down Under
That's a good looking engine for the miles. Well done.
Penrite Vantage 10W40 SN & A3/B4 + Wesfil-Cooper Z154
#4691099 - 03/11/18 06:17 AM Re: Under Valve Cover: 2000 LS1 @ 120,000 miles [Re: MrHorspwer]
demarpaint Offline
Loc: NY
It looks great.
God Bless Our Troops
#4691106 - 03/11/18 06:57 AM Re: Under Valve Cover: 2000 LS1 @ 120,000 miles [Re: MrHorspwer]
FordCapriDriver Offline
Loc: Balearic Islands , Spain
That's a 10/10.
1975 Ford Capri II Ghia 3000 V6, - Valvoline VR1 20W-50
1988 Ford Escort MkIV 1.6 Xr3i Cabrio, - Shell Rimula R4X 15W-40 HDEO.
#4691110 - 03/11/18 07:15 AM Re: Under Valve Cover: 2000 LS1 @ 120,000 miles [Re: MrHorspwer]
TinyVoices Offline
Loc: Vienna, VA
Pac 1218 springs and an ls6 cam?
1993 Toyota MR2 Hardtop N/A - 157k miles - Valvoline Max Life 5w30
2006 Toyota Matrix XR AWD (Fiancee) - 126k miles - Valvoline Max Life 5w30
#4691123 - 03/11/18 07:40 AM Re: Under Valve Cover: 2000 LS1 @ 120,000 miles [Re: TinyVoices]
MrHorspwer Offline
Loc: Michigan
Cam Motion Titan 1 and PAC 1219
Page 1 of 2 1 2 >
