New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
6.2 f250 6.4 ram 2500 towing with a gasser
by FLORIDA. 03/24/19 05:55 PM
T5 15w40 for my bike?
by Degreaser. 03/24/19 05:47 PM
Studded tires in warm weather
by y_p_w. 03/24/19 05:28 PM
ST 15W40
by mobilaltima. 03/24/19 05:02 PM
I need a filter cutter person
by Marco620. 03/24/19 03:21 PM
VIRGIN BOSCH D+ 3421 CUT OPEN
by 53' Stude. 03/24/19 02:45 PM
My first cut. Donaldson P502503
by BeerCan. 03/24/19 02:25 PM
Sludge and Facebook's infinite wisdom
by RDY4WAR. 03/24/19 02:05 PM
Gear lube 75W90 Synthetic GM# 88900401
by rcbob. 03/24/19 01:47 PM
Rislone Rebates
by Nickdfresh. 03/24/19 01:42 PM
IndyCar Classic at COTA
by bdcardinal. 03/24/19 12:29 PM
STP 500 at Martinsville
by bdcardinal. 03/24/19 12:27 PM
Source For Microfiber Towels
by Wrenchturner44. 03/24/19 12:26 PM
SUPREME C3-X SYNTHETIC 5W-30
by 21Rouge. 03/24/19 12:17 PM
Jcountry, CMichael, dude59, Petrolhead, stp
67608 Registered Users
107 registered members (ArrestMeRedZ, addyguy, 2004tdigls, arowbat, 2002 Maxima SE, 11 invisible), 2,226 guests, and 65 spiders.
Topics286,351
Posts4,906,907
Members67,608
Most Online2,967
Mar 10th, 2019
Mixing Rotella t5 10w-30 #4690720
03/10/18 06:12 PM
03/10/18 06:12 PM
New England
PaulManDude Offline OP
New England
Can I mix Rotella t5 10w-30 with something like a 0w-20 to thin it out a bit and make a thinner 30 weight? Rotella 10w-30 is very heavy, almost like a 40 weight, correct? Would the cold flowing properties still be a 10 weight?
Horn went “Beep”
Engine purred
Friendliest sounds
You ever heard
Re: Mixing Rotella t5 10w-30 [Re: PaulManDude] #4690728
03/10/18 06:19 PM
03/10/18 06:19 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Not all that close to 40 ... It looks and feels heavy to the thin oil crowd. Looks and feels about right to the thick crowd smile
If I wanted to thin it out some, I'd just use some Shell SAE 10, or something along those lines. Jobber should have Rotella 10 or 20 mono-grades in stock smile
Re: Mixing Rotella t5 10w-30 [Re: PaulManDude] #4690750
03/10/18 06:48 PM
03/10/18 06:48 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
When you mix you end up with an unknown. It will probably be thinner at 100C but the cold end will be unknown
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Mixing Rotella t5 10w-30 [Re: PaulManDude] #4690778
03/10/18 07:30 PM
03/10/18 07:30 PM
USA
slacktide_bitog Offline
USA
Shell now makes a Rotella T6 5w30, which may suit your needs better smile
Re: Mixing Rotella t5 10w-30 [Re: PaulManDude] #4690784
03/10/18 07:43 PM
03/10/18 07:43 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
"10W" does not mean it is a 10-weight oil, in fact there is no SAE 10 grade oil. Within the somewhat messy confines of this thread you will see that the "W" is a cold-cranking rating, not a weight. Mixed oils do not guarantee any cold cranking specification will be met:
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4672607/1
Plus when you mix oils (especially those of widely different chemistries) you also produce a mixture that has no certifications. There's no guarantee it will meet any of the certs or standards that any of the individual oils may individually meet. Do like slacktide_bitog mentioned and buy an oil that meets your engine certification requirements and is appropriate for the anticipated operating conditions.
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: Mixing Rotella t5 10w-30 [Re: kschachn] #4690886
03/10/18 09:30 PM
03/10/18 09:30 PM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
I'll bet that doesn't happen in real life very often, though.
Re: Mixing Rotella t5 10w-30 [Re: Linctex] #4690887
03/10/18 09:32 PM
03/10/18 09:32 PM
Ontario, Canada
OVERKILL Online content
OVERKILL  Online Content
Ontario, Canada
What doesn't? No mix is certified, by mixing you modify the formula that was approved, ergo, your "new" product is approved to absolutely no standard.
2016 Grand Cherokee SRT - Ravenol SSL 0w-40, FRAM Ultra
Re: Mixing Rotella t5 10w-30 [Re: PaulManDude] #4690912
03/10/18 09:49 PM
03/10/18 09:49 PM
Chicago suburbs
AP9 Offline
AP9  Offline
Chicago suburbs
It's a nonlinear relationship. As mentioned earlier, that will drop the viscosity @ 100°C significantly more than the cold-temp viscosity. Mixing 1:1, it would end up closer to a "10W20" than a "5W20" or "5W30"
1996 Chevrolet Impala SS - M1HM 5W-30, M1-201 filter
2018 Toyota 4Runner TRD Off-Road Premium - CITGO SUPERGARD 0W-20 dexos1 Gen2, factory filter
Re: Mixing Rotella t5 10w-30 [Re: OVERKILL] #4690915
03/10/18 09:54 PM
03/10/18 09:54 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Without specific insider knowledge of the formulation I'd say the argument could better be made that it happens every time.
1994 BMW 530i, 241K
Re: Mixing Rotella t5 10w-30 [Re: OVERKILL] #4691107
03/11/18 07:00 AM
03/11/18 07:00 AM
1/2 hr N.E. of Detroit
Triple_Se7en Offline
Mixing doesn't hurt a thing. It has the same odds to improve things - as it does to flat-line. There's absolutely no proof mixing harms or lowers the life of the engine.
My engines are proof of that after almost 25 years of mixing. I'm even more proof.... being I am first & last owner of my vehicles. I've taken 18 year-old vehicles to junkyards badly rusted. Still have a clear dipstick - still only use a half-quart in OCI - still do not smoke. Engines are in great shape.... outside of the rest of the vehicle parts.
Mix-away..... blend away....... get better benefit of your hard-earned money by blending 50-50 for the same money that you paid for that 25-33% synthetic blend that bottlers gave you.
My current blend is 5w-30 Formula Shell conventional with Quaker State Ultimate Durability synthetic. One bought for 1.79qt at Menards and one bought for 2.13qt equivalent at Meijer.
2019 Hyundai SantaFe 2.4 factory fill QS 5w20 / Factory OEM oil filter
04 Chev Colorado 3.5 QS / Valv syn 5w30 blend K&N filter
03 Chev Malibu 3.1 QS / Valv Syn 5w30 blend Fram EG filter
Re: Mixing Rotella t5 10w-30 [Re: Triple_Se7en] #4691248
03/11/18 09:44 AM
03/11/18 09:44 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
My engines are proof of that after almost 25 years of mixing. I'm even more proof.... being I am first & last owner of my vehicles. I've taken 18 year-old vehicles to junkyards badly rusted. Still have a clear dipstick - still only use a half-quart in OCI - still do not smoke. Engines are in great shape.... outside of the rest of the vehicle parts..
The first part is correct but the second half of your statement is pure silliness. You're nothing but a blind formulator with no knowledge of additive chemistry at that point.
1994 BMW 530i, 241K
Re: Mixing Rotella t5 10w-30 [Re: PaulManDude] #4691315
03/11/18 10:38 AM
03/11/18 10:38 AM
Balearic Islands , Spain
FordCapriDriver Offline
If you wanted to water id won a bit perhaps add some of that new Rotella 5W-30
1975 Ford Capri II Ghia 3000 V6, - Shell Helix HX3 20W-50 w/ 20% Rimula R4X 15W-40 HDEO.
1988 Ford Escort XR3i Cabrio, - Shell Rimula R4X 15W-40, w/ 30% Helix 3 20W-50.
