Cellphone Reliability
by Warstud. 12/15/18 03:29 PM
No email notification of replies anymore?
by atikovi. 12/15/18 03:07 PM
Crane EE 5301 Humidifier
by maverickfhs. 12/15/18 02:38 PM
I have sinned
by 901Memphis. 12/15/18 01:57 PM
Milwaukee m12 in vanhaus ratchet
by pda1122. 12/15/18 01:19 PM
Klein dikes
by Donald. 12/15/18 01:03 PM
Help Soldering 3.5mm mono microphone plug
by Brybo86. 12/15/18 01:02 PM
Small Trolling Motors
by wings&wheels. 12/15/18 12:49 PM
Toyota Corolla, good and bad?
by jongies3. 12/15/18 12:35 PM
Mixing oils
by bfleeman. 12/15/18 10:51 AM
Ebay 10% off Tech 15% off everything else*.
by demarpaint. 12/15/18 10:39 AM
Milwaukee Fuel M12 Ratchet 1/4” vs 3/8”
by Snagglefoot. 12/15/18 10:16 AM
Hifly Hf 805
by chrisri. 12/15/18 10:00 AM
Preferred 5.3L L83 Oil Filter
by zfasts03. 12/15/18 09:58 AM
sonata plastic fork starter failed three times.
by JustinH. 12/15/18 09:17 AM
HVAC Problems
by WTJackalope. 12/15/18 09:15 AM
Rough Idle after short trip
by Datarock. 12/15/18 09:07 AM
Homelite 360
by mobilaltima. 12/15/18 09:04 AM
Lovin' the Etec!
by IndyFan. 12/15/18 06:10 AM
Air Impact Wrench
by BenZahel. 12/15/18 05:19 AM
Spkrdctr, torchredone12, JNG, Edmundo, NEKGuy
66688 Registered Users
73 registered members (Altydoc, 77GrandPrix, 2002 Maxima SE, Audios, 53' Stude, 9 invisible), 1,785 guests, and 37 spiders.
Topics295,115
Posts4,928,027
Members66,688
Most Online2,553
Oct 27th, 2018
Bosch 3311 #4690537
03/10/18 01:21 PM
03/10/18 01:21 PM
Tennessee
goodtimes Offline OP
Tennessee
U code year Bosch Premium used on my lawn mower. No defect. Nice adbv, just a good design, perfect centering. Round holes in spiral center tube. These had a high efficiency rating too, don't remember what. Should have left it on another few years, or forever. Replaced with Delco pf1233.
Re: Bosch 3311 [Re: goodtimes] #4690598
03/10/18 02:32 PM
03/10/18 02:32 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Originally Posted By: goodtimes
.... used on my lawn mower. Should have left it on another few years, or forever.
I agree; lawnmower engines will honestly last their whole life on one filter.
They really do not pump a lot of oil.....
Re: Bosch 3311 [Re: Linctex] #4690614
03/10/18 02:49 PM
03/10/18 02:49 PM
Tennessee
Tennessee
I thought so too but not so sure now. When the filter was removed NO oil came out, right after running. The center tube drained immediately, as filter base is down. There was oil in the dirty side of the filter which I drained out by opening the adbv. So the oil pump has to fill the center tube and galleries on every start. Which means in a downward facing oil filter, like this one, a smaller filter and smaller center tube is better. Which explains why some mower filters are these short things. A long filter will take a lot longer to fill.
The running time of my mower isn't a lot, and I only changed the filter due to age and tear scare. The Delco will be on only a couple years, has nitrile.
Re: Bosch 3311 [Re: Linctex] #4690637
03/10/18 03:09 PM
03/10/18 03:09 PM
out there
spasm3 Offline
spasm3  Offline
out there
I have always wondered what volume a small ope engine ran through the filter. I assume my zero turn engine( kawasaki fr651v) is still splash lubed even if it has a filter.
I've thought about putting a 3600 ( longer than the stock 3614) fram ultra on it and leaving it for several years.
13 elantra 72k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 7300 miles m1 0w30
Re: Bosch 3311 [Re: spasm3] #4690759
03/10/18 06:01 PM
03/10/18 06:01 PM
Tennessee
Tennessee
It may be unwise to put larger filters on power equipment if the base is pointing down. Probably the oe size is best. I think my mower engine only uses pressure lubrication, full flow. The engine manual diagrams should show the construction of the oiling circuit and if there are splash dippers.
Re: Bosch 3311 [Re: goodtimes] #4690874
03/10/18 08:23 PM
03/10/18 08:23 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Well, they pump full reasonably fast. Some have an oil switch/light
You should always start the engine at low RPM and let it warm up for a minute befotre putting under a load, anyway.
These engines are pretty under rated (for their size) and usually low compression. They can start and run at idle for quite a while with no "oil starvation" concerns.
Re: Bosch 3311 [Re: goodtimes] #4691001
03/10/18 10:50 PM
03/10/18 10:50 PM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
I replaced the PH3614 size ecore oil filter on my Toro ZTR with Kohler engine with a PH3600 size filter, a CQ Blue 51516 manufactured by Wix, several years ago and have had zero problems. This engine has the oil filter mounted vertically base end up, and the owners'manual specifies prefilling a new filter prior to installation. I change out oil & filter every 2 years, OM says to change oil every 50 engine hours and oil filter every 100 engine hours. The oversize filter makes an oil change an even 1.5 quarts. I used to use the same conventional 10W-30 Exxon Superflow I used in my truck at that time but now use 10W-30 Havoline Pro DS Synthetic I bought on clearance at AAP when I could still get a rebate from Chevron. Mower is about 12 years old now and runs as strong as when we first bought it.
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
Re: Bosch 3311 [Re: goodtimes] #4691250
03/11/18 08:45 AM
03/11/18 08:45 AM
out there
spasm3 Offline
spasm3  Offline
out there
My mower filter is horizontally mounted. The engine has a gerotor oil pump. The oil pressure spec's are 43psi to 85 psi. So i think the 3600 filter should be fine.
