The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
30 registered members (DoubleWasp, berniedd, dishdude, Agnosto, 4 invisible), 623 guests, and 66 spiders.
Topics286,097
Posts4,902,476
Members67,560
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
"Micro" rounds that are heavier? #4690534
03/10/18 02:15 PM
03/10/18 02:15 PM
New Jersey
JHZR2 Offline OP
Global Moderator
JHZR2  Offline OP
Global Moderator
New Jersey
I saw the "micro" .38 spl rounds that are actually flat (bullet doesn't extend past the case) to minimize headspace in there and optimize powder burn. Unfortunately Cabela's was out, but I'm interested in trying them.
I was checking out the other defensive options, and noted the 150gr "micro" 9mm. Optimized for short barrels.
Then I saw this:
Seemed to not be that great from a Shield.
Lucky Gunner did better in an M&P9c
Only one of those seems to have a big channel. The rest may have expanded and stopped, but not necessarily did the same type of damage. Not sure if a gel block has some effect on that after the first firing.
It just seems to me to be counter intuitive to go heavier in a short barrel when the length of burn is minimized. Is the heavier bullet used for more length, so a trick like the micro .38 is applied in a bullet where length is necessary for feeding?
Seems to me that a 124gr would be minimum, with a 115 or even +P variants being better.
I know some on here have mentioned how modern ammo like HST and gold dots are so good that differences aren't really there. But I'd assume that's really for service size pistols (Interestingly, another test I saw showed that the 150gr micro bullets worked well in a full size).
So really, the interest to me is if anyone is aware of the real logic going heavy in a 9mm bullet optimized for micro bullets. I get 1/2 mv^2 and the fact that speed is essential for bullets to open up. So mass is not the major player here. Id have thought that a 115ish long, deep seated +p design would be best.
Re: "Micro" rounds that are heavier? [Re: JHZR2] #4690544
03/10/18 02:29 PM
03/10/18 02:29 PM
Florida
hatt Offline
hatt  Offline
Florida
Heavier bullets lose less velocity as a percentage in shorter barrels vs lighter bullets. Heavier bullets also penetrate more to make sure you meet that spec. I'd run the same thing in my Shield that run in larger guns.
2013 F150 5.0, Delo XLE CK-4 10W-30, Baldwin B7449
2010 Camry 2.5, PP 10W-30, Mobil1 M1C-251A
Re: "Micro" rounds that are heavier? [Re: JHZR2] #4690562
03/10/18 02:46 PM
03/10/18 02:46 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
I go for 124 gr for the higher velocity, which makes it shoot a bit flatter and gives better expansion.
Re: "Micro" rounds that are heavier? [Re: JHZR2] #4690571
03/10/18 02:53 PM
03/10/18 02:53 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
I have loaded ~ 150 grain SWC's in 9 x 19mm ( originally cast for .38 Special / .357 Mag ) .
Wyr
God bless
Re: "Micro" rounds that are heavier? [Re: JHZR2] #4690574
03/10/18 02:56 PM
03/10/18 02:56 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Another review of the Micro HST.
Re: "Micro" rounds that are heavier? [Re: JHZR2] #4690597
03/10/18 03:30 PM
03/10/18 03:30 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Interesting!!
I'm always looking for the "ultimate short-barrel 9mm round"
Re: "Micro" rounds that are heavier? [Re: hatt] #4690636
03/10/18 04:09 PM
03/10/18 04:09 PM
New Jersey
JHZR2 Offline OP
Global Moderator
JHZR2  Offline OP
Global Moderator
New Jersey
Understand both. But in the above video, they over penetrated from a shield, due to no expansion. So they didn't accelerate enough for loss to be an issue.
In here they didn't penetrate as far as the 147 and 147 +P, and all three of those rounds were claimed to be inconsistent from a Glock 43:
The shield is 3.1", glock 43 3.4" and m&p 9c is 3.5" iirc. That's off the top of my head and potentially incorrect. But could it be that these "micro" rounds are optimized really for 3.5" pistols, not shorter variants? It just seems to me the performance isn't compelling. I'd think that a lighter bullet would accelerate more with less powder burn, and since engagement distance (arguably) isn't really a meaningful parameter for self defense with a micro pistol, speed would be optimized to ensure energy and ability to open.
Re: "Micro" rounds that are heavier? [Re: Linctex] #4690647
03/10/18 04:30 PM
03/10/18 04:30 PM
TX
KJSmith Offline
KJSmith  Offline
TX
Interesting!!
http://shopwilsoncombat.com/9mm-95-gr-Ba...o/A9-95-TACXP/#
Re: "Micro" rounds that are heavier? [Re: KJSmith] #4690659
03/10/18 04:51 PM
03/10/18 04:51 PM
New Jersey
JHZR2 Offline OP
Global Moderator
JHZR2  Offline OP
Global Moderator
New Jersey
Interesting!!
The lucky gunner tests don't have this but do have 115gr, which does excellent from their M&P9c.
Re: "Micro" rounds that are heavier? [Re: JHZR2] #4690698
03/10/18 05:52 PM
03/10/18 05:52 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
This is why I just go for either the 9mm HST 124 gr or Gold Dot 124 gr in standard load.
Re: "Micro" rounds that are heavier? [Re: JHZR2] #4690749
03/10/18 06:47 PM
03/10/18 06:47 PM
Florida
hatt Offline
hatt  Offline
Florida
Looks like a poorly designed round. Another reason I don't do the bleeding edge latest and greatest.
Re: "Micro" rounds that are heavier? [Re: hatt] #4690820
03/10/18 08:25 PM
03/10/18 08:25 PM
New Jersey
JHZR2 Offline OP
Global Moderator
JHZR2  Offline OP
Global Moderator
New Jersey
I think you said you have a shield - what do you run? I was under the impression that some of the last-gen rounds were poorer performing. At least with respect to short barrel guns that can't make full design velocity.
Just generally curious. Primarily my interest is in service size pistols - I do live in NJ after all. I just happened upon this round looking for those "sunk" .38spl rounds. But may be useful to others. I found the mass to be curious so it's a matter of curiosity to me.
Re: "Micro" rounds that are heavier? [Re: JHZR2] #4690871
03/10/18 09:16 PM
03/10/18 09:16 PM
Florida
hatt Offline
hatt  Offline
Florida
I'm using old Winchester 147 HPs that I had a supply of. I don't carry it much. When I get around to placing an ammo order I'm going to buy 124 +p Gold Dots.
Re: "Micro" rounds that are heavier? [Re: JHZR2] #4691045
03/11/18 01:30 AM
03/11/18 01:30 AM
North of you Idaho
KneeGrinder Offline
KneeGrinder  Offline
North of you Idaho
[quote=JHZR2]I saw the "micro" .38 spl rounds that are actually flat (bullet doesn't extend past the case) to minimize headspace in there and optimize powder burn. Unfortunately Cabela's was out, but I'm interested in trying them.
Seems to me that a 124gr would be minimum, with a 115 or even +P variants being better.[quote]
For 9mm, by far the lighter projectiles 124's are the preferred followed by 115's for velocity and foot pounds of energy. The heavier 147's are noticeably lower on foot pounds of energy due to the loss in velocity, but do penetrate a little deeper. 124's +p, Federal HST, Speer Gold Dot, Winchester Ranger.
As for the 38 Special, the projectiles you reference are called "Wad Cutters" and "Hollow Base Wad Cutters"
They are used for target shooting purpose only. The reason they are seated flush with the end of the case is to burn fast burning powder more efficiently. They are only used at lower velocities, and the hollow base has a very narrow range because the base is hollow and expands, if you put too much powder behind it the base will melt and lead your barrel in a few shots. Lead will splatter! The "Non" hollow base wad cutter will be a double ended bullet, you can load it either end facing out, thats why they call them double end wad cutters. I use them a lot! They punch perfect round holes.
08 Tribeca 86k PUP 5w30 wix
06 Accord Hybrid 134k PPHM 0w20 wix
02 Chevy k3500 99k Delvac 1 esp 5w40 wix
00 F350 136k Delvac 1300 15w40 wix
Re: "Micro" rounds that are heavier? [Re: JHZR2] #4691195
03/11/18 08:44 AM
03/11/18 08:44 AM
New Jersey
JHZR2 Offline OP
Global Moderator
JHZR2  Offline OP
Global Moderator
New Jersey
Ive seen the deep-seated wadcutters. What I was looking at for .38spl was these:
JHPs in a deep seated configuration to optimize powder burn. I did not that there are other non defense variants of this configuration.
Page 1 of 3 1 2 3
