MolaKule
Staff member
The filter books and references state the shorter filter, such as the Purolator x14612 to be a replacement filter for the Nissan 15208 65F0E filter.
However, the longer filter, the x14610 can be installed as well for those wanting a bit more filtering capacity, for these lawn mower and motorcycle size filters.
i found that if you have a strong grip, you can reach up through the plastic debris shield and twist the filter off without popping the plastic "snap" pins.
I also discovered that it is a good idea to place a plastic "apron" underneath the filter and on the frame member so that the oil drains into the pan and not onto the member. I cut a 1 gal. plastic freezer bag along its sides and shove it underneath the filter. Works like a charm.
