White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
FRAM end cap differences EG and TG vs XG
by wemay. 01/19/19 09:25 PM
Valvoline modern Engine
by Pinoak. 01/19/19 09:02 PM
30 Vintage Photos
by StevieC. 01/19/19 08:23 PM
Low mileage, when to change oil?
by Metfanant. 01/19/19 08:05 PM
Filter with bypass when OEM has built-in bypass
by rubberchicken. 01/19/19 07:43 PM
Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
dougway, Jetsfan421, Fordman420, 72sbc, ejmiller
66982 Registered Users
20 registered members (billt460, c502cid, Char Baby, DaleRider, 3 invisible), 790 guests, and 30 spiders.
Topics296,866
Posts4,960,386
Members66,982
Most Online2,688
Jan 19th, 2019
Filter changes on our New 2015 Nissan PF #4690385
03/10/18 10:13 AM
03/10/18 10:13 AM
Iowegia - USA
MolaKule Offline OP
MolaKule  Offline OP
Iowegia - USA
The filter books and references state the shorter filter, such as the Purolator x14612 to be a replacement filter for the Nissan 15208 65F0E filter.
However, the longer filter, the x14610 can be installed as well for those wanting a bit more filtering capacity, for these lawn mower and motorcycle size filters. smile
i found that if you have a strong grip, you can reach up through the plastic debris shield and twist the filter off without popping the plastic "snap" pins.
I also discovered that it is a good idea to place a plastic "apron" underneath the filter and on the frame member so that the oil drains into the pan and not onto the member. I cut a 1 gal. plastic freezer bag along its sides and shove it underneath the filter. Works like a charm.
Scars remind us of where we have been, but do not have to dictate where we are going.
Re: Filter changes on our New 2015 Nissan PF [Re: MolaKule] #4690472
03/10/18 11:56 AM
03/10/18 11:56 AM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
On my 2004 Altima V6 I just turn the front wheels all the way to the right, then the plastic side shield can be popped off in 15 sec and have an easy access to the filter and frame rail area. Could also remove the drain plug and drain the oil from the sump without lifting the car off the ground.
The 14610 sized filters fit fine too, no side shield interference.
